Noticed that all containers lost their network.
There was an auto refresh of the LXD snap.
I found in the logs an error starting dnsmasq:
Jul 23 23:41:18 XXXX lxd.daemon[1926887]: => Stop reason is: snap refresh
Jul 23 23:41:18 XXXX lxd.daemon[1926887]: => Stopping LXD
Jul 23 23:41:18 XXXX lxd.daemon[1820897]: => LXD exited cleanly
Jul 23 23:41:19 XXXX systemd[1]: Stopped Service for snap application lxd.daemon.
Jul 23 23:41:24 XXXX systemd[1]: Listening on Socket unix for snap application lxd.daemon.
Jul 23 23:41:24 XXXX systemd[1]: Starting Service for snap application lxd.activate…
Jul 23 23:41:24 XXXX lxd.activate[1927251]: => Starting LXD activation
Jul 23 23:41:24 XXXX lxd.activate[1927251]: ==> Loading snap configuration
Jul 23 23:41:24 XXXX lxd.activate[1927251]: ==> Checking for socket activation support
Jul 23 23:41:24 XXXX lxd.activate[1927251]: ==> Setting LXD socket ownership
Jul 23 23:41:24 XXXX lxd.activate[1927251]: ==> Checking if LXD needs to be activated
Jul 23 23:41:25 XXXX systemd[1]: Started Service for snap application lxd.daemon.
Jul 23 23:41:25 XXXX lxd.daemon[1927311]: => Preparing the system
Jul 23 23:41:25 XXXX lxd.daemon[1927311]: ==> Loading snap configuration
Jul 23 23:41:25 XXXX lxd.daemon[1927311]: ==> Setting up mntns symlink (mnt:[4026533847])
Jul 23 23:41:25 XXXX lxd.daemon[1927311]: ==> Setting up kmod wrapper
Jul 23 23:41:25 XXXX lxd.daemon[1927311]: ==> Preparing /boot
Jul 23 23:41:25 XXXX lxd.daemon[1927311]: ==> Preparing a clean copy of /run
Jul 23 23:41:25 XXXX lxd.daemon[1927311]: ==> Preparing a clean copy of /etc
Jul 23 23:41:25 XXXX lxd.daemon[1927311]: ==> Setting up ceph configuration
Jul 23 23:41:25 XXXX lxd.daemon[1927311]: ==> Setting up LVM configuration
Jul 23 23:41:25 XXXX lxd.daemon[1927311]: ==> Rotating logs
Jul 23 23:41:25 XXXX lxd.daemon[1927311]: ==> Setting up ZFS (0.7)
Jul 23 23:41:25 XXXX lxd.daemon[1927311]: ==> Escaping the systemd cgroups
Jul 23 23:41:25 XXXX lxd.daemon[1927311]: ==> Escaping the systemd process resource limits
Jul 23 23:41:25 XXXX lxd.daemon[1927311]: ==> Disabling shiftfs on this kernel (auto)
Jul 23 23:41:25 XXXX lxd.daemon[1927311]: => Re-using existing LXCFS
Jul 23 23:41:25 XXXX lxd.daemon[1927311]: => Starting LXD
Jul 23 23:41:25 XXXX lxd.daemon[1927311]: t=2019-07-23T23:41:25+0200 lvl=warn msg=“CGroup memory swap accounting is disabled, swap limits will be ignored.”
Jul 23 23:41:26 XXXX lxd.daemon[1820897]: mount namespace: 7
Jul 23 23:41:26 XXXX lxd.daemon[1820897]: hierarchies:
Jul 23 23:41:26 XXXX lxd.daemon[1820897]: 0: fd: 8: memory
Jul 23 23:41:26 XXXX lxd.daemon[1820897]: 1: fd: 9: rdma
Jul 23 23:41:26 XXXX lxd.daemon[1820897]: 2: fd: 10: perf_event
Jul 23 23:41:26 XXXX lxd.daemon[1820897]: 3: fd: 11: hugetlb
Jul 23 23:41:26 XXXX lxd.daemon[1820897]: 4: fd: 12: devices
Jul 23 23:41:26 XXXX lxd.daemon[1820897]: 5: fd: 13: net_cls,net_prio
Jul 23 23:41:26 XXXX lxd.daemon[1820897]: 6: fd: 14: freezer
Jul 23 23:41:26 XXXX lxd.daemon[1820897]: 7: fd: 15: pids
Jul 23 23:41:26 XXXX lxd.daemon[1820897]: 8: fd: 16: cpu,cpuacct
Jul 23 23:41:26 XXXX lxd.daemon[1820897]: 9: fd: 17: blkio
Jul 23 23:41:26 XXXX lxd.daemon[1820897]: 10: fd: 18: cpuset
Jul 23 23:41:26 XXXX lxd.daemon[1820897]: 11: fd: 19: name=systemd
Jul 23 23:41:26 XXXX lxd.daemon[1820897]: 12: fd: 20: unified
Jul 23 23:41:26 XXXX lxd.daemon[1820897]: lxcfs.c: 152: do_reload: lxcfs: reloaded
Jul 23 23:41:26 XXXX dnsmasq[1927530]: failed to create listening socket for fe80::10ec:79ff:fece:d368%lxdbr0: Address already in use
Jul 23 23:41:27 XXXX dnsmasq[1927540]: failed to create listening socket for fe80::10ec:79ff:fece:d368%lxdbr0: Address already in use
Jul 23 23:41:28 XXXX dnsmasq[1927544]: failed to create listening socket for fe80::10ec:79ff:fece:d368%lxdbr0: Address already in use
Jul 23 23:41:29 XXXX dnsmasq[1927546]: failed to create listening socket for fe80::10ec:79ff:fece:d368%lxdbr0: Address already in use
Jul 23 23:41:30 XXXX dnsmasq[1927633]: failed to create listening socket for fe80::10ec:79ff:fece:d368%lxdbr0: Address already in use
Jul 23 23:41:30 XXXX dnsmasq[1927634]: failed to create listening socket for fe80::10ec:79ff:fece:d368%lxdbr0: Address already in use
Jul 23 23:41:31 XXXX dnsmasq[1927644]: failed to create listening socket for fe80::10ec:79ff:fece:d368%lxdbr0: Address already in use
Jul 23 23:41:32 XXXX dnsmasq[1927646]: failed to create listening socket for fe80::10ec:79ff:fece:d368%lxdbr0: Address already in use
Jul 23 23:41:33 XXXX dnsmasq[1927648]: failed to create listening socket for fe80::10ec:79ff:fece:d368%lxdbr0: Address already in use
Jul 23 23:41:34 XXXX dnsmasq[1927650]: failed to create listening socket for fe80::10ec:79ff:fece:d368%lxdbr0: Address already in use
Jul 23 23:41:35 XXXX dnsmasq[1927715]: failed to create listening socket for fe80::10ec:79ff:fece:d368%lxdbr0: Address already in use
Jul 23 23:41:36 XXXX dnsmasq[1927717]: failed to create listening socket for fe80::10ec:79ff:fece:d368%lxdbr0: Address already in use
Jul 23 23:41:36 XXXX dnsmasq[1927718]: failed to create listening socket for fe80::10ec:79ff:fece:d368%lxdbr0: Address already in use
Jul 23 23:41:37 XXXX dnsmasq[1927720]: failed to create listening socket for fe80::10ec:79ff:fece:d368%lxdbr0: Address already in use
Jul 23 23:41:38 XXXX dnsmasq[1927722]: failed to create listening socket for fe80::10ec:79ff:fece:d368%lxdbr0: Address already in use
Jul 23 23:41:39 XXXX dnsmasq[1927724]: failed to create listening socket for fe80::10ec:79ff:fece:d368%lxdbr0: Address already in use
Jul 23 23:41:40 XXXX dnsmasq[1927794]: failed to create listening socket for fe80::10ec:79ff:fece:d368%lxdbr0: Address already in use
Jul 23 23:41:41 XXXX dnsmasq[1927796]: failed to create listening socket for fe80::10ec:79ff:fece:d368%lxdbr0: Address already in use
Jul 23 23:41:42 XXXX dnsmasq[1927798]: failed to create listening socket for fe80::10ec:79ff:fece:d368%lxdbr0: Address already in use
Jul 23 23:41:42 XXXX dnsmasq[1927800]: failed to create listening socket for fe80::10ec:79ff:fece:d368%lxdbr0: Address already in use
Jul 23 23:41:43 XXXX lxd.daemon[1927311]: t=2019-07-23T23:41:43+0200 lvl=eror msg=“Failed to bring up network” err="Failed to run: dnsmasq --strict-order --bind-interfaces --pid-file=/var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.pid --except-interface=lo --no-ping --interface=lxdbr0 --quiet-dhcp --quiet-dhcp6 --quiet-ra --listen-address=10.0.122.1 --dhcp-no-override --dhcp-authoritative --dhcp-leasefile=/var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.leases --dhcp-hostsfile=/var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts --dhcp-range 10.0.122.2,10.0.122.254,1h -s lxd -S /lxd/ --conf-file=/var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.raw -u lxd: " name=lxdbr0
But dnsmasq wasn’t running and i don’t have dhcpd installed either.
doing a snap restart lxd fixed it.
