Hello.
Recently i have updated my arch system to the latest available version. Additionally, i updated snap lxd package and now i can’t start my privileged container.
I suppose that it can be related with new warning that lxd reports every time:
WARNING: cgroup v2 is not fully supported yet, proceeding with partial confinement
I have managed to start restored container, but it loses it’s privileged setting and i can’t even upgrade it:
$ lxc config get xpraclient-arch security.privileged
In result of update inside container i receive this error:
/bin/sh: line 1: /dev/null: Operation not permitted
From container:
# ls -la /dev/null
crw-rw-rw- 1 nobody nobody 1, 3 Apr 5 07:51 /dev/null
If i enable security.privileged, then container becomes unusable.
And at this point running restart doesn’t work as expected - container is acting like there was no such command and to finalize it i need to shutdown it from inside.
sudo tail -f /var/snap/lxd/common/lxd/logs/lxd.log
t=2021-04-05T16:38:38+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210318-xpra-4.1.1-good pool=xpraclientTPool project=default
t=2021-04-05T16:38:38+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210319-xpra-4.1.1-better pool=xpraclientTPool project=default
t=2021-04-05T16:38:38+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210319-xpra-4.1.1-better pool=xpraclientTPool project=default
t=2021-04-05T16:38:38+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210320-export pool=xpraclientTPool project=default
t=2021-04-05T16:38:38+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210320-export pool=xpraclientTPool project=default
t=2021-04-05T16:38:38+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210402-before-update pool=xpraclientTPool project=default
t=2021-04-05T16:38:38+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210402-before-update pool=xpraclientTPool project=default
t=2021-04-05T16:38:38+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210405-broken pool=xpraclientTPool project=default
t=2021-04-05T16:38:38+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210405-broken pool=xpraclientTPool project=default
t=2021-04-05T16:38:38+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch/logs/lxc.log username=colt
t=2021-04-05T16:41:19+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0 username=colt
t=2021-04-05T16:41:19+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/events username=colt
t=2021-04-05T16:41:19+0300 lvl=dbug msg="New event listener: 66caf421-2345-4aab-b028-fe0c3682ba5f"
t=2021-04-05T16:41:19+0300 lvl=dbug msg=Handling ip=@ method=PUT protocol=unix url=/1.0/instances/xpraclient-arch/state username=colt
t=2021-04-05T16:41:19+0300 lvl=dbug msg="\n\t{\n\t\t\"action\": \"restart\",\n\t\t\"timeout\": -1,\n\t\t\"force\": false,\n\t\t\"stateful\": false\n\t}"
t=2021-04-05T16:41:19+0300 lvl=dbug msg="New task Operation: 3a98bd1b-dbe5-4b8d-936c-e7aacd8cdac0"
t=2021-04-05T16:41:19+0300 lvl=dbug msg="Started task operation: 3a98bd1b-dbe5-4b8d-936c-e7aacd8cdac0"
t=2021-04-05T16:41:19+0300 lvl=info msg="Restarting container" action=shutdown created=2021-03-16T16:26:40+0200 ephemeral=false instance=xpraclient-arch instanceType=container project=default timeout=-1ns used=2021-04-05T16:35:51+0300
t=2021-04-05T16:41:19+0300 lvl=dbug msg="\n\t{\n\t\t\"type\": \"async\",\n\t\t\"status\": \"Operation created\",\n\t\t\"status_code\": 100,\n\t\t\"operation\": \"/1.0/operations/3a98bd1b-dbe5-4b8d-936c-e7aacd8cdac0\",\n\t\t\"error_code\": 0,\n\t\t\"error\": \"\",\n\t\t\"metadata\": {\n\t\t\t\"id\": \"3a98bd1b-dbe5-4b8d-936c-e7aacd8cdac0\",\n\t\t\t\"class\": \"task\",\n\t\t\t\"description\": \"Restarting instance\",\n\t\t\t\"created_at\": \"2021-04-05T16:41:19.156326097+03:00\",\n\t\t\t\"updated_at\": \"2021-04-05T16:41:19.156326097+03:00\",\n\t\t\t\"status\": \"Running\",\n\t\t\t\"status_code\": 103,\n\t\t\t\"resources\": {\n\t\t\t\t\"instances\": [\n\t\t\t\t\t\"/1.0/instances/xpraclient-arch\"\n\t\t\t\t]\n\t\t\t},\n\t\t\t\"metadata\": null,\n\t\t\t\"may_cancel\": false,\n\t\t\t\"err\": \"\",\n\t\t\t\"location\": \"none\"\n\t\t}\n\t}"
t=2021-04-05T16:41:19+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/operations/3a98bd1b-dbe5-4b8d-936c-e7aacd8cdac0 username=colt
t=2021-04-05T16:42:02+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0 username=colt
t=2021-04-05T16:42:02+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url="/1.0/instances?recursion=2" username=colt
t=2021-04-05T16:42:02+0300 lvl=dbug msg="GetInstanceUsage started" driver=btrfs instance=m-tmp pool=messangers2 project=default
t=2021-04-05T16:42:02+0300 lvl=dbug msg="GetInstanceUsage started" driver=btrfs instance=messangers-tmp pool=messangers2 project=default
t=2021-04-05T16:42:02+0300 lvl=dbug msg="GetInstanceUsage finished" driver=btrfs instance=m-tmp pool=messangers2 project=default
t=2021-04-05T16:42:02+0300 lvl=dbug msg="GetInstanceUsage finished" driver=btrfs instance=messangers-tmp pool=messangers2 project=default
t=2021-04-05T16:42:02+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=messangers pool=messangersTPool project=default
t=2021-04-05T16:42:02+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:42:02+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:42:02+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=messangers pool=messangersTPool project=default
t=2021-04-05T16:42:38+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0 username=colt
t=2021-04-05T16:42:38+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url="/1.0/instances?recursion=2" username=colt
t=2021-04-05T16:42:38+0300 lvl=dbug msg="GetInstanceUsage started" driver=btrfs instance=messangers-tmp pool=messangers2 project=default
t=2021-04-05T16:42:38+0300 lvl=dbug msg="GetInstanceUsage started" driver=btrfs instance=m-tmp pool=messangers2 project=default
t=2021-04-05T16:42:38+0300 lvl=dbug msg="GetInstanceUsage finished" driver=btrfs instance=m-tmp pool=messangers2 project=default
t=2021-04-05T16:42:38+0300 lvl=dbug msg="GetInstanceUsage finished" driver=btrfs instance=messangers-tmp pool=messangers2 project=default
t=2021-04-05T16:42:38+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=messangers pool=messangersTPool project=default
t=2021-04-05T16:42:38+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=messangers pool=messangersTPool project=default
t=2021-04-05T16:42:38+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:42:38+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:42:41+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0 username=colt
t=2021-04-05T16:42:41+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch username=colt
t=2021-04-05T16:42:41+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch/state username=colt
t=2021-04-05T16:42:41+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:42:41+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:42:41+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url="/1.0/instances/xpraclient-arch/snapshots?recursion=1" username=colt
t=2021-04-05T16:42:41+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210318-xpra-4.0.9-ready pool=xpraclientTPool project=default
t=2021-04-05T16:42:41+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210318-xpra-4.0.9-ready pool=xpraclientTPool project=default
t=2021-04-05T16:42:41+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210318-xpra-4.1.1-good pool=xpraclientTPool project=default
t=2021-04-05T16:42:41+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210318-xpra-4.1.1-good pool=xpraclientTPool project=default
t=2021-04-05T16:42:41+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210319-xpra-4.1.1-better pool=xpraclientTPool project=default
t=2021-04-05T16:42:41+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210319-xpra-4.1.1-better pool=xpraclientTPool project=default
t=2021-04-05T16:42:41+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210320-export pool=xpraclientTPool project=default
t=2021-04-05T16:42:41+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210320-export pool=xpraclientTPool project=default
t=2021-04-05T16:42:41+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210402-before-update pool=xpraclientTPool project=default
t=2021-04-05T16:42:41+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210402-before-update pool=xpraclientTPool project=default
t=2021-04-05T16:42:41+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210405-broken pool=xpraclientTPool project=default
t=2021-04-05T16:42:41+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210405-broken pool=xpraclientTPool project=default
t=2021-04-05T16:42:41+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch/logs/lxc.log username=colt
t=2021-04-05T16:42:54+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0 username=colt
t=2021-04-05T16:42:54+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url="/1.0/instances?recursion=2" username=colt
t=2021-04-05T16:42:54+0300 lvl=dbug msg="GetInstanceUsage started" driver=btrfs instance=messangers-tmp pool=messangers2 project=default
t=2021-04-05T16:42:54+0300 lvl=dbug msg="GetInstanceUsage started" driver=btrfs instance=m-tmp pool=messangers2 project=default
t=2021-04-05T16:42:54+0300 lvl=dbug msg="GetInstanceUsage finished" driver=btrfs instance=messangers-tmp pool=messangers2 project=default
t=2021-04-05T16:42:54+0300 lvl=dbug msg="GetInstanceUsage finished" driver=btrfs instance=m-tmp pool=messangers2 project=default
t=2021-04-05T16:42:54+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:42:54+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:42:54+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=messangers pool=messangersTPool project=default
t=2021-04-05T16:42:54+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=messangers pool=messangersTPool project=default
t=2021-04-05T16:42:56+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0 username=colt
t=2021-04-05T16:42:56+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch username=colt
t=2021-04-05T16:42:56+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch/state username=colt
t=2021-04-05T16:42:56+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:42:56+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:42:56+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url="/1.0/instances/xpraclient-arch/snapshots?recursion=1" username=colt
t=2021-04-05T16:42:56+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210318-xpra-4.0.9-ready pool=xpraclientTPool project=default
t=2021-04-05T16:42:56+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210318-xpra-4.0.9-ready pool=xpraclientTPool project=default
t=2021-04-05T16:42:56+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210318-xpra-4.1.1-good pool=xpraclientTPool project=default
t=2021-04-05T16:42:56+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210318-xpra-4.1.1-good pool=xpraclientTPool project=default
t=2021-04-05T16:42:56+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210319-xpra-4.1.1-better pool=xpraclientTPool project=default
t=2021-04-05T16:42:56+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210319-xpra-4.1.1-better pool=xpraclientTPool project=default
t=2021-04-05T16:42:56+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210320-export pool=xpraclientTPool project=default
t=2021-04-05T16:42:56+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210320-export pool=xpraclientTPool project=default
t=2021-04-05T16:42:56+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210402-before-update pool=xpraclientTPool project=default
t=2021-04-05T16:42:56+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210402-before-update pool=xpraclientTPool project=default
t=2021-04-05T16:42:56+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210405-broken pool=xpraclientTPool project=default
t=2021-04-05T16:42:56+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210405-broken pool=xpraclientTPool project=default
t=2021-04-05T16:42:56+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch/logs/lxc.log username=colt
t=2021-04-05T16:43:57+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0 username=colt
t=2021-04-05T16:43:57+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch username=colt
t=2021-04-05T16:43:57+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch/state username=colt
t=2021-04-05T16:43:57+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:43:57+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:43:57+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url="/1.0/instances/xpraclient-arch/snapshots?recursion=1" username=colt
t=2021-04-05T16:43:57+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210318-xpra-4.0.9-ready pool=xpraclientTPool project=default
t=2021-04-05T16:43:57+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210318-xpra-4.0.9-ready pool=xpraclientTPool project=default
t=2021-04-05T16:43:57+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210318-xpra-4.1.1-good pool=xpraclientTPool project=default
t=2021-04-05T16:43:57+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210318-xpra-4.1.1-good pool=xpraclientTPool project=default
t=2021-04-05T16:43:57+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210319-xpra-4.1.1-better pool=xpraclientTPool project=default
t=2021-04-05T16:43:57+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210319-xpra-4.1.1-better pool=xpraclientTPool project=default
t=2021-04-05T16:43:57+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210320-export pool=xpraclientTPool project=default
t=2021-04-05T16:43:57+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210320-export pool=xpraclientTPool project=default
t=2021-04-05T16:43:57+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210402-before-update pool=xpraclientTPool project=default
t=2021-04-05T16:43:57+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210402-before-update pool=xpraclientTPool project=default
t=2021-04-05T16:43:57+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210405-broken pool=xpraclientTPool project=default
t=2021-04-05T16:43:57+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210405-broken pool=xpraclientTPool project=default
t=2021-04-05T16:43:57+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch/logs/lxc.log username=colt
t=2021-04-05T16:44:39+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0 username=colt
t=2021-04-05T16:44:39+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch username=colt
t=2021-04-05T16:44:39+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch/state username=colt
t=2021-04-05T16:44:39+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:44:39+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:44:39+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url="/1.0/instances/xpraclient-arch/snapshots?recursion=1" username=colt
t=2021-04-05T16:44:39+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210318-xpra-4.0.9-ready pool=xpraclientTPool project=default
t=2021-04-05T16:44:39+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210318-xpra-4.0.9-ready pool=xpraclientTPool project=default
t=2021-04-05T16:44:39+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210318-xpra-4.1.1-good pool=xpraclientTPool project=default
t=2021-04-05T16:44:39+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210318-xpra-4.1.1-good pool=xpraclientTPool project=default
t=2021-04-05T16:44:39+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210319-xpra-4.1.1-better pool=xpraclientTPool project=default
t=2021-04-05T16:44:39+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210319-xpra-4.1.1-better pool=xpraclientTPool project=default
t=2021-04-05T16:44:39+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210320-export pool=xpraclientTPool project=default
t=2021-04-05T16:44:39+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210320-export pool=xpraclientTPool project=default
t=2021-04-05T16:44:39+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210402-before-update pool=xpraclientTPool project=default
t=2021-04-05T16:44:39+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210402-before-update pool=xpraclientTPool project=default
t=2021-04-05T16:44:39+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210405-broken pool=xpraclientTPool project=default
t=2021-04-05T16:44:39+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210405-broken pool=xpraclientTPool project=default
t=2021-04-05T16:44:39+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch/logs/lxc.log username=colt
t=2021-04-05T16:44:40+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0 username=colt
t=2021-04-05T16:44:40+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch username=colt
t=2021-04-05T16:44:40+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch/state username=colt
t=2021-04-05T16:44:40+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:44:40+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:44:40+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url="/1.0/instances/xpraclient-arch/snapshots?recursion=1" username=colt
t=2021-04-05T16:44:40+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210318-xpra-4.0.9-ready pool=xpraclientTPool project=default
t=2021-04-05T16:44:40+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210318-xpra-4.0.9-ready pool=xpraclientTPool project=default
t=2021-04-05T16:44:40+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210318-xpra-4.1.1-good pool=xpraclientTPool project=default
t=2021-04-05T16:44:40+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210318-xpra-4.1.1-good pool=xpraclientTPool project=default
t=2021-04-05T16:44:40+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210319-xpra-4.1.1-better pool=xpraclientTPool project=default
t=2021-04-05T16:44:40+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210319-xpra-4.1.1-better pool=xpraclientTPool project=default
t=2021-04-05T16:44:40+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210320-export pool=xpraclientTPool project=default
t=2021-04-05T16:44:40+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210320-export pool=xpraclientTPool project=default
t=2021-04-05T16:44:40+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210402-before-update pool=xpraclientTPool project=default
t=2021-04-05T16:44:40+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210402-before-update pool=xpraclientTPool project=default
t=2021-04-05T16:44:40+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210405-broken pool=xpraclientTPool project=default
t=2021-04-05T16:44:40+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210405-broken pool=xpraclientTPool project=default
t=2021-04-05T16:44:40+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch/logs/lxc.log username=colt
t=2021-04-05T16:44:41+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0 username=colt
t=2021-04-05T16:44:41+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch username=colt
t=2021-04-05T16:44:42+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch/state username=colt
t=2021-04-05T16:44:42+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:44:42+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:44:42+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url="/1.0/instances/xpraclient-arch/snapshots?recursion=1" username=colt
t=2021-04-05T16:44:42+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210318-xpra-4.0.9-ready pool=xpraclientTPool project=default
t=2021-04-05T16:44:42+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210318-xpra-4.0.9-ready pool=xpraclientTPool project=default
t=2021-04-05T16:44:42+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210318-xpra-4.1.1-good pool=xpraclientTPool project=default
t=2021-04-05T16:44:42+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210318-xpra-4.1.1-good pool=xpraclientTPool project=default
t=2021-04-05T16:44:42+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210319-xpra-4.1.1-better pool=xpraclientTPool project=default
t=2021-04-05T16:44:42+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210319-xpra-4.1.1-better pool=xpraclientTPool project=default
t=2021-04-05T16:44:42+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210320-export pool=xpraclientTPool project=default
t=2021-04-05T16:44:42+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210320-export pool=xpraclientTPool project=default
t=2021-04-05T16:44:42+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210402-before-update pool=xpraclientTPool project=default
t=2021-04-05T16:44:42+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210402-before-update pool=xpraclientTPool project=default
t=2021-04-05T16:44:42+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210405-broken pool=xpraclientTPool project=default
t=2021-04-05T16:44:42+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210405-broken pool=xpraclientTPool project=default
t=2021-04-05T16:44:42+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch/logs/lxc.log username=colt
t=2021-04-05T16:44:50+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0 username=colt
t=2021-04-05T16:44:50+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url="/1.0/instances?recursion=2" username=colt
t=2021-04-05T16:44:50+0300 lvl=dbug msg="GetInstanceUsage started" driver=btrfs instance=m-tmp pool=messangers2 project=default
t=2021-04-05T16:44:50+0300 lvl=dbug msg="GetInstanceUsage started" driver=btrfs instance=messangers-tmp pool=messangers2 project=default
t=2021-04-05T16:44:50+0300 lvl=dbug msg="GetInstanceUsage finished" driver=btrfs instance=messangers-tmp pool=messangers2 project=default
t=2021-04-05T16:44:50+0300 lvl=dbug msg="GetInstanceUsage finished" driver=btrfs instance=m-tmp pool=messangers2 project=default
t=2021-04-05T16:44:50+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=messangers pool=messangersTPool project=default
t=2021-04-05T16:44:50+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=messangers pool=messangersTPool project=default
t=2021-04-05T16:44:50+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:44:50+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:45:56+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0 username=colt
t=2021-04-05T16:45:56+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url="/1.0/instances?recursion=2" username=colt
t=2021-04-05T16:45:56+0300 lvl=dbug msg="GetInstanceUsage started" driver=btrfs instance=messangers-tmp pool=messangers2 project=default
t=2021-04-05T16:45:56+0300 lvl=dbug msg="GetInstanceUsage started" driver=btrfs instance=m-tmp pool=messangers2 project=default
t=2021-04-05T16:45:56+0300 lvl=dbug msg="GetInstanceUsage finished" driver=btrfs instance=messangers-tmp pool=messangers2 project=default
t=2021-04-05T16:45:56+0300 lvl=dbug msg="GetInstanceUsage finished" driver=btrfs instance=m-tmp pool=messangers2 project=default
t=2021-04-05T16:45:56+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=messangers pool=messangersTPool project=default
t=2021-04-05T16:45:56+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=messangers pool=messangersTPool project=default
t=2021-04-05T16:45:56+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:45:56+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:46:34+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0 username=colt
t=2021-04-05T16:46:34+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch username=colt
t=2021-04-05T16:46:34+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch/state username=colt
t=2021-04-05T16:46:34+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:46:34+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:46:34+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url="/1.0/instances/xpraclient-arch/snapshots?recursion=1" username=colt
t=2021-04-05T16:46:34+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210318-xpra-4.0.9-ready pool=xpraclientTPool project=default
t=2021-04-05T16:46:34+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210318-xpra-4.0.9-ready pool=xpraclientTPool project=default
t=2021-04-05T16:46:34+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210318-xpra-4.1.1-good pool=xpraclientTPool project=default
t=2021-04-05T16:46:34+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210318-xpra-4.1.1-good pool=xpraclientTPool project=default
t=2021-04-05T16:46:34+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210319-xpra-4.1.1-better pool=xpraclientTPool project=default
t=2021-04-05T16:46:34+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210319-xpra-4.1.1-better pool=xpraclientTPool project=default
t=2021-04-05T16:46:34+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210320-export pool=xpraclientTPool project=default
t=2021-04-05T16:46:34+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210320-export pool=xpraclientTPool project=default
t=2021-04-05T16:46:34+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210402-before-update pool=xpraclientTPool project=default
t=2021-04-05T16:46:34+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210402-before-update pool=xpraclientTPool project=default
t=2021-04-05T16:46:34+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210405-broken pool=xpraclientTPool project=default
t=2021-04-05T16:46:34+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210405-broken pool=xpraclientTPool project=default
t=2021-04-05T16:46:34+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch/logs/lxc.log username=colt
t=2021-04-05T16:47:22+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0 username=colt
t=2021-04-05T16:47:22+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/events username=colt
t=2021-04-05T16:47:22+0300 lvl=dbug msg="New event listener: 4b378ce2-8686-4931-ae0d-3dede97b07a3"
t=2021-04-05T16:47:22+0300 lvl=dbug msg=Handling ip=@ method=PUT protocol=unix url=/1.0/instances/xpraclient-arch/state username=colt
t=2021-04-05T16:47:22+0300 lvl=dbug msg="\n\t{\n\t\t\"action\": \"stop\",\n\t\t\"timeout\": -1,\n\t\t\"force\": false,\n\t\t\"stateful\": false\n\t}"
t=2021-04-05T16:47:22+0300 lvl=dbug msg="New task Operation: dbaf1f5c-269d-4148-9725-05c0416a96d7"
t=2021-04-05T16:47:22+0300 lvl=dbug msg="Started task operation: dbaf1f5c-269d-4148-9725-05c0416a96d7"
t=2021-04-05T16:47:22+0300 lvl=info msg="Shutting down container" action=shutdown created=2021-03-16T16:26:40+0200 ephemeral=false instance=xpraclient-arch instanceType=container project=default timeout=-1s used=2021-04-05T16:35:51+0300
t=2021-04-05T16:47:22+0300 lvl=dbug msg="\n\t{\n\t\t\"type\": \"async\",\n\t\t\"status\": \"Operation created\",\n\t\t\"status_code\": 100,\n\t\t\"operation\": \"/1.0/operations/dbaf1f5c-269d-4148-9725-05c0416a96d7\",\n\t\t\"error_code\": 0,\n\t\t\"error\": \"\",\n\t\t\"metadata\": {\n\t\t\t\"id\": \"dbaf1f5c-269d-4148-9725-05c0416a96d7\",\n\t\t\t\"class\": \"task\",\n\t\t\t\"description\": \"Stopping instance\",\n\t\t\t\"created_at\": \"2021-04-05T16:47:22.271011947+03:00\",\n\t\t\t\"updated_at\": \"2021-04-05T16:47:22.271011947+03:00\",\n\t\t\t\"status\": \"Running\",\n\t\t\t\"status_code\": 103,\n\t\t\t\"resources\": {\n\t\t\t\t\"instances\": [\n\t\t\t\t\t\"/1.0/instances/xpraclient-arch\"\n\t\t\t\t]\n\t\t\t},\n\t\t\t\"metadata\": null,\n\t\t\t\"may_cancel\": false,\n\t\t\t\"err\": \"\",\n\t\t\t\"location\": \"none\"\n\t\t}\n\t}"
t=2021-04-05T16:47:22+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/operations/dbaf1f5c-269d-4148-9725-05c0416a96d7 username=colt
t=2021-04-05T16:47:29+0300 lvl=dbug msg=Handling ip=@ method=DELETE protocol=unix url=/1.0/operations/dbaf1f5c-269d-4148-9725-05c0416a96d7 username=colt
t=2021-04-05T16:47:32+0300 lvl=dbug msg=Handling ip=@ method=DELETE protocol=unix url=/1.0/operations/dbaf1f5c-269d-4148-9725-05c0416a96d7 username=colt
t=2021-04-05T16:47:32+0300 lvl=dbug msg="Event listener finished: 4b378ce2-8686-4931-ae0d-3dede97b07a3"
t=2021-04-05T16:47:32+0300 lvl=dbug msg="Disconnected event listener: 4b378ce2-8686-4931-ae0d-3dede97b07a3"
t=2021-04-05T16:47:36+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0 username=colt
t=2021-04-05T16:47:36+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch username=colt
t=2021-04-05T16:47:36+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch/state username=colt
t=2021-04-05T16:47:36+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:47:36+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:47:36+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url="/1.0/instances/xpraclient-arch/snapshots?recursion=1" username=colt
t=2021-04-05T16:47:36+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210318-xpra-4.0.9-ready pool=xpraclientTPool project=default
t=2021-04-05T16:47:36+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210318-xpra-4.0.9-ready pool=xpraclientTPool project=default
t=2021-04-05T16:47:36+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210318-xpra-4.1.1-good pool=xpraclientTPool project=default
t=2021-04-05T16:47:36+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210318-xpra-4.1.1-good pool=xpraclientTPool project=default
t=2021-04-05T16:47:36+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210319-xpra-4.1.1-better pool=xpraclientTPool project=default
t=2021-04-05T16:47:36+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210319-xpra-4.1.1-better pool=xpraclientTPool project=default
t=2021-04-05T16:47:36+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210320-export pool=xpraclientTPool project=default
t=2021-04-05T16:47:36+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210320-export pool=xpraclientTPool project=default
t=2021-04-05T16:47:36+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210402-before-update pool=xpraclientTPool project=default
t=2021-04-05T16:47:36+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210402-before-update pool=xpraclientTPool project=default
t=2021-04-05T16:47:36+0300 lvl=dbug msg="GetInstanceUsage started" driver=lvm instance=xpraclient-arch/210405-broken pool=xpraclientTPool project=default
t=2021-04-05T16:47:36+0300 lvl=dbug msg="GetInstanceUsage finished" driver=lvm instance=xpraclient-arch/210405-broken pool=xpraclientTPool project=default
t=2021-04-05T16:47:36+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch/logs/lxc.log username=colt
t=2021-04-05T16:47:53+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0 username=colt
t=2021-04-05T16:47:53+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/events username=colt
t=2021-04-05T16:47:53+0300 lvl=dbug msg="New event listener: 5efb2922-68db-44a6-a429-cfdf7825f249"
t=2021-04-05T16:47:53+0300 lvl=dbug msg=Handling ip=@ method=POST protocol=unix url=/1.0/instances/xpraclient-arch/exec username=colt
t=2021-04-05T16:47:53+0300 lvl=dbug msg="\n\t{\n\t\t\"command\": [\n\t\t\t\"bash\"\n\t\t],\n\t\t\"wait-for-websocket\": true,\n\t\t\"interactive\": true,\n\t\t\"environment\": {\n\t\t\t\"TERM\": \"xterm-256color\"\n\t\t},\n\t\t\"width\": 118,\n\t\t\"height\": 31,\n\t\t\"record-output\": false,\n\t\t\"user\": 0,\n\t\t\"group\": 0,\n\t\t\"cwd\": \"\"\n\t}"
t=2021-04-05T16:47:53+0300 lvl=dbug msg="MountInstance started" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:47:53+0300 lvl=dbug msg="MountInstance finished" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:47:53+0300 lvl=dbug msg=forkcheckfile instance=xpraclient-arch instanceType=container line="Path doesn't exist: No such file or directory" project=default
t=2021-04-05T16:47:53+0300 lvl=dbug msg="UnmountInstance started" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:47:53+0300 lvl=dbug msg="Skipping unmount as in use" driver=lvm pool=xpraclientTPool refCount=1
t=2021-04-05T16:47:53+0300 lvl=dbug msg="UnmountInstance finished" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:47:53+0300 lvl=dbug msg="New websocket Operation: 101a3452-332d-4983-a34a-76d89bbe9692"
t=2021-04-05T16:47:53+0300 lvl=dbug msg="Started websocket operation: 101a3452-332d-4983-a34a-76d89bbe9692"
t=2021-04-05T16:47:53+0300 lvl=dbug msg="\n\t{\n\t\t\"type\": \"async\",\n\t\t\"status\": \"Operation created\",\n\t\t\"status_code\": 100,\n\t\t\"operation\": \"/1.0/operations/101a3452-332d-4983-a34a-76d89bbe9692\",\n\t\t\"error_code\": 0,\n\t\t\"error\": \"\",\n\t\t\"metadata\": {\n\t\t\t\"id\": \"101a3452-332d-4983-a34a-76d89bbe9692\",\n\t\t\t\"class\": \"websocket\",\n\t\t\t\"description\": \"Executing command\",\n\t\t\t\"created_at\": \"2021-04-05T16:47:53.34610374+03:00\",\n\t\t\t\"updated_at\": \"2021-04-05T16:47:53.34610374+03:00\",\n\t\t\t\"status\": \"Running\",\n\t\t\t\"status_code\": 103,\n\t\t\t\"resources\": {\n\t\t\t\t\"containers\": [\n\t\t\t\t\t\"/1.0/containers/xpraclient-arch\"\n\t\t\t\t],\n\t\t\t\t\"instances\": [\n\t\t\t\t\t\"/1.0/instances/xpraclient-arch\"\n\t\t\t\t]\n\t\t\t},\n\t\t\t\"metadata\": {\n\t\t\t\t\"command\": [\n\t\t\t\t\t\"bash\"\n\t\t\t\t],\n\t\t\t\t\"environment\": {\n\t\t\t\t\t\"DISPLAY\": \":0\",\n\t\t\t\t\t\"HOME\": \"/root\",\n\t\t\t\t\t\"LANG\": \"C.UTF-8\",\n\t\t\t\t\t\"PATH\": \"/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin\",\n\t\t\t\t\t\"TERM\": \"xterm-256color\",\n\t\t\t\t\t\"USER\": \"root\"\n\t\t\t\t},\n\t\t\t\t\"fds\": {\n\t\t\t\t\t\"0\": \"7b25c9029638648215e0334bca6f1efe5de9d2040827aa93417d5240f3b96ec1\",\n\t\t\t\t\t\"control\": \"dcc4c8946db7d61a6620dfd0146ce58937abc6d2644fa3926347c80c711e7a8c\"\n\t\t\t\t},\n\t\t\t\t\"interactive\": true\n\t\t\t},\n\t\t\t\"may_cancel\": false,\n\t\t\t\"err\": \"\",\n\t\t\t\"location\": \"none\"\n\t\t}\n\t}"
t=2021-04-05T16:47:53+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url="/1.0/operations/101a3452-332d-4983-a34a-76d89bbe9692/websocket?secret=dcc4c8946db7d61a6620dfd0146ce58937abc6d2644fa3926347c80c711e7a8c" username=colt
t=2021-04-05T16:47:53+0300 lvl=dbug msg="Connected websocket Operation: 101a3452-332d-4983-a34a-76d89bbe9692"
t=2021-04-05T16:47:53+0300 lvl=dbug msg="Handled websocket Operation: 101a3452-332d-4983-a34a-76d89bbe9692"
t=2021-04-05T16:47:53+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url="/1.0/operations/101a3452-332d-4983-a34a-76d89bbe9692/websocket?secret=7b25c9029638648215e0334bca6f1efe5de9d2040827aa93417d5240f3b96ec1" username=colt
t=2021-04-05T16:47:53+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/operations/101a3452-332d-4983-a34a-76d89bbe9692 username=colt
t=2021-04-05T16:47:53+0300 lvl=dbug msg="Retrieved PID of executing child process" attachedPid=147909 instance=xpraclient-arch instanceType=container project=default
t=2021-04-05T16:47:53+0300 lvl=dbug msg="Instance process started" PID=147909 instance=xpraclient-arch
t=2021-04-05T16:47:53+0300 lvl=dbug msg="Interactive child process handler started" PID=147909 instance=xpraclient-arch
t=2021-04-05T16:47:53+0300 lvl=dbug msg="Started mirroring websocket" PID=147909 instance=xpraclient-arch
t=2021-04-05T16:47:58+0300 lvl=dbug msg="Instance process stopped" PID=147909 instance=xpraclient-arch
t=2021-04-05T16:47:58+0300 lvl=dbug msg="Detected poll(POLLHUP) event: exiting."
t=2021-04-05T16:47:58+0300 lvl=dbug msg="Sending write barrier"
t=2021-04-05T16:47:58+0300 lvl=dbug msg="Got error getting next reader" PID=147909 err="read unix /var/snap/lxd/common/lxd/unix.socket->@: use of closed network connection" instance=xpraclient-arch
t=2021-04-05T16:47:58+0300 lvl=dbug msg="Interactive child process handler finished" PID=147909 instance=xpraclient-arch
t=2021-04-05T16:47:58+0300 lvl=dbug msg="Got error getting next reader websocket: close 1006 (abnormal closure): unexpected EOF"
t=2021-04-05T16:47:58+0300 lvl=dbug msg="Finished mirroring websocket" PID=147909 instance=xpraclient-arch
t=2021-04-05T16:47:58+0300 lvl=dbug msg="Updated metadata for websocket Operation: 101a3452-332d-4983-a34a-76d89bbe9692"
t=2021-04-05T16:47:58+0300 lvl=dbug msg="Success for websocket operation: 101a3452-332d-4983-a34a-76d89bbe9692"
t=2021-04-05T16:47:58+0300 lvl=dbug msg="Event listener finished: 5efb2922-68db-44a6-a429-cfdf7825f249"
t=2021-04-05T16:47:58+0300 lvl=dbug msg="Disconnected event listener: 5efb2922-68db-44a6-a429-cfdf7825f249"
t=2021-04-05T16:47:58+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url="/internal/containers/xpraclient-arch/onstopns?netns=%2Fproc%2F143753%2Ffd%2F4&project=default&target=stop" username=root
t=2021-04-05T16:47:58+0300 lvl=dbug msg="Stopping device" device=eth0 instance=xpraclient-arch instanceType=container project=default type=nic
t=2021-04-05T16:47:58+0300 lvl=dbug msg="Clearing instance firewall static filters" dev=eth0 host_name=veth11c102f0 hwaddr=00:16:3e:7c:12:de instance=xpraclient-arch ipv4=0.0.0.0 ipv6=:: parent=lxdbr0 project=default
t=2021-04-05T16:47:58+0300 lvl=dbug msg="Clearing instance firewall dynamic filters" dev=eth0 host_name=veth11c102f0 hwaddr=00:16:3e:7c:12:de instance=xpraclient-arch ipv4=<nil> ipv6=<nil> parent=lxdbr0 project=default
t=2021-04-05T16:47:58+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url="/internal/containers/xpraclient-arch/onstop?project=default&target=stop" username=root
t=2021-04-05T16:47:58+0300 lvl=dbug msg="Container initiated" action=stop created=2021-03-16T16:26:40+0200 ephemeral=false instance=xpraclient-arch instanceType=container project=default stateful=false used=2021-04-05T16:35:51+0300
t=2021-04-05T16:47:58+0300 lvl=dbug msg="Container stopped, cleaning up" instance=xpraclient-arch instanceType=container project=default
t=2021-04-05T16:47:58+0300 lvl=dbug msg="Stopping device" device=mygpu instance=xpraclient-arch instanceType=container project=default type=gpu
t=2021-04-05T16:47:58+0300 lvl=dbug msg="Stopping device" device=X0 instance=xpraclient-arch instanceType=container project=default type=proxy
t=2021-04-05T16:47:58+0300 lvl=info msg="Shut down container" action=shutdown created=2021-03-16T16:26:40+0200 ephemeral=false instance=xpraclient-arch instanceType=container project=default timeout=-1s used=2021-04-05T16:35:51+0300
t=2021-04-05T16:47:58+0300 lvl=dbug msg="Stopping device" device=Xauthority instance=xpraclient-arch instanceType=container project=default type=disk
t=2021-04-05T16:47:58+0300 lvl=dbug msg="Success for task operation: dbaf1f5c-269d-4148-9725-05c0416a96d7"
t=2021-04-05T16:47:58+0300 lvl=dbug msg="Stopping device" device=Xauthority2 instance=xpraclient-arch instanceType=container project=default type=disk
t=2021-04-05T16:47:58+0300 lvl=dbug msg="Stopping device" device=shared_storage instance=xpraclient-arch instanceType=container project=default type=disk
t=2021-04-05T16:47:58+0300 lvl=dbug msg="Stopping device" device=root instance=xpraclient-arch instanceType=container project=default type=disk
t=2021-04-05T16:47:58+0300 lvl=dbug msg="MountInstance started" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:47:58+0300 lvl=dbug msg="UnmountInstance started" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:47:58+0300 lvl=dbug msg="MountInstance finished" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:47:58+0300 lvl=dbug msg="Container idmap changed, remapping" instance=xpraclient-arch instanceType=container project=default
t=2021-04-05T16:47:58+0300 lvl=dbug msg="Updated metadata for task Operation: 3a98bd1b-dbe5-4b8d-936c-e7aacd8cdac0"
t=2021-04-05T16:47:58+0300 lvl=dbug msg="Skipping unmount as in use" driver=lvm pool=xpraclientTPool refCount=1
t=2021-04-05T16:47:58+0300 lvl=dbug msg="UnmountInstance finished" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:48:22+0300 lvl=dbug msg="UnmountInstance started" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:48:27+0300 lvl=dbug msg="Unmounted logical volume" driver=lvm keepBlockDev=false path=/var/snap/lxd/common/lxd/storage-pools/xpraclientTPool/containers/xpraclient-arch pool=xpraclientTPool
t=2021-04-05T16:48:27+0300 lvl=dbug msg="Deactivated logical volume" dev=/dev/xpraclientTPoolVG/containers_xpraclient--arch driver=lvm pool=xpraclientTPool
t=2021-04-05T16:48:27+0300 lvl=dbug msg="UnmountInstance finished" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:48:27+0300 lvl=dbug msg="Failure for task operation: 3a98bd1b-dbe5-4b8d-936c-e7aacd8cdac0: Failed preparing container for start: invalid argument - Failed to change ACLs on /var/snap/lxd/common/lxd/storage-pools/xpraclientTPool/containers/xpraclient-arch/rootfs/var/log/journal"
t=2021-04-05T16:48:27+0300 lvl=dbug msg="Event listener finished: 66caf421-2345-4aab-b028-fe0c3682ba5f"
t=2021-04-05T16:48:27+0300 lvl=dbug msg="Disconnected event listener: 66caf421-2345-4aab-b028-fe0c3682ba5f"
Restart result:
$ lxc restart xpraclient-arch
Error: Failed preparing container for start: invalid argument - Failed to change ACLs on /var/snap/lxd/common/lxd/storage-pools/xpraclientTPool/containers/xpraclient-arch/rootfs/var/log/journal
Try `lxc info --show-log xpraclient-arch` for more info
$ sudo nsenter -t $(cat /var/snap/lxd/common/lxd.pid) -m -u -i -n -- /bin/bash -c "/bin/ls -la /var/snap/lxd/common/lxd/storage-pools/xpraclientTPool/containers/xpraclient-arch/rootfs/var/log/journal"
/bin/ls: cannot access '/var/snap/lxd/common/lxd/storage-pools/xpraclientTPool/containers/xpraclient-arch/rootfs/var/log/journal': No such file or directory
Container log:
$ lxc info --show-log xpraclient-arch
Remote: unix://
Created: 2021/03/16 14:26 UTC
Status: Stopped
Type: container
Profiles: xpraclient-arch, shared_storage, x11
Snapshots:
210402-before-update (taken at 2021/04/02 08:18 UTC) (stateless)
210405-broken (taken at 2021/04/05 10:27 UTC) (stateless)
Log:
lxc 20210405135304.545 TRACE commands - commands.c:lxc_cmd:302 - Connection refused - Command "get_state" failed to connect command socket
lxc 20210405135304.550 TRACE commands - commands.c:lxc_cmd:302 - Connection refused - Command "get_state" failed to connect command socket
And i have managed to start it if i restore it from snapshot with uid/gid mapping profile enabled.
$ lxc info
core.https_address: '[::]:8443'
images.auto_update_interval: "0"
api_extensions:
- container_stop_priority
- container_syscall_filtering
- auth_pki
- container_last_used_at
- etag
- patch
- usb_devices
- https_allowed_credentials
- image_compression_algorithm
- directory_manipulation
- container_cpu_time
- storage_zfs_use_refquota
- storage_lvm_mount_options
- network
- profile_usedby
- container_push
- container_exec_recording
- certificate_update
- gpu_devices
- container_image_properties
- migration_progress
- id_map
- network_firewall_filtering
- network_routes
- storage
- file_delete
- file_append
- network_dhcp_expiry
- storage_lvm_vg_rename
- storage_lvm_thinpool_rename
- network_vlan
- image_create_aliases
- container_stateless_copy
- container_only_migration
- storage_zfs_clone_copy
- unix_device_rename
- storage_lvm_use_thinpool
- storage_rsync_bwlimit
- network_vxlan_interface
- storage_btrfs_mount_options
- entity_description
- image_force_refresh
- storage_lvm_lv_resizing
- id_map_base
- file_symlinks
- container_push_target
- network_vlan_physical
- storage_images_delete
- container_edit_metadata
- storage_driver_ceph
- storage_ceph_user_name
- resource_limits
- resources
- kernel_limits
- storage_api_volume_rename
- macaroon_authentication
- network_sriov
- console
- restrict_devlxd
- migration_pre_copy
- infiniband
- maas_network
- devlxd_events
- proxy
- network_dhcp_gateway
- file_get_symlink
- network_leases
- unix_device_hotplug
- operation_description
- clustering
- event_lifecycle
- nvidia_runtime
- container_mount_propagation
- container_backup
- devlxd_images
- proxy_unix
- proxy_udp
- clustering_join
- network_state
- proxy_unix_dac_properties
- container_protection_delete
- unix_priv_drop
- pprof_http
- proxy_haproxy_protocol
- network_hwaddr
- proxy_nat
- network_nat_order
- container_full
- candid_authentication
- backup_compression
- candid_config
- nvidia_runtime_config
- storage_unmapped
- projects
- candid_config_key
- network_vxlan_ttl
- container_incremental_copy
- usb_optional_vendorid
- snapshot_scheduling
- container_copy_project
- clustering_server_address
- container_protection_shift
- snapshot_expiry
- snapshot_expiry_creation
- network_leases_location
- resources_cpu_socket
- resources_gpu
- resources_numa
- kernel_features
- id_map_current
- event_location
- network_nat_address
- container_nic_routes
- rbac
- cluster_internal_copy
- seccomp_notify
- lxc_features
- container_nic_ipvlan
- network_vlan_sriov
- storage_cephfs
- container_nic_ipfilter
- resources_v2
- container_syscall_intercept
- container_disk_shift
- storage_shifted
- resources_infiniband
- daemon_storage
- instances
- image_types
- resources_disk_sata
- clustering_roles
- images_expiry
- resources_network_firmware
- ceph_data_pool_name
- compression_squashfs
- container_raw_mount
- container_nic_routed
- container_disk_ceph
- virtual-machines
- image_profiles
- clustering_architecture
- resources_disk_id
- storage_lvm_stripes
- vm_boot_priority
- unix_hotplug_devices
- api_filtering
- instance_nic_network
- clustering_sizing
- firewall_driver
- projects_limits
- limits_hugepages
- projects_restrictions
- volume_snapshot_scheduling
- trust_ca_certificates
- snapshot_disk_usage
- clustering_edit_roles
- resources_usb_pci
- resources_cpu_threads_numa
- resources_cpu_core_die
- api_os
- container_nic_ipvlan_mode
- resources_system
- images_push_relay
- network_dns_search
- container_nic_routed_limits
- instance_nic_bridged_vlan
- network_state_bond_bridge
- usedby_consistency
- custom_block_volumes
- clustering_failure_domains
- resources_gpu_mdev
- console_vga_type
- projects_limits_disk
- network_type_macvlan
- network_type_sriov
- network_type_ovn
- projects_networks
- custom_volume_backup
- backup_override_name
- storage_rsync_compression
- network_type_physical
- network_ovn_nat
- tpm_device_type
- gpu_mdev
- resources_pci_iommu
- resources_network_usb
- resources_disk_address
- network_ovn_dhcp
- projects_limits_instances
- network_state_vlan
- instance_bulk_state_change
- network_gvrp
- instance_pool_move
- gpu_sriov
- pci_device_type
- storage_volume_state
- network_acl
- migration_stateful
- disk_state_quota
- storage_ceph_features
- projects_compression
- certificate_project
- network_ovn_acl
- projects_images_auto_update
api_status: stable
api_version: "1.0"
auth: trusted
public: false
auth_methods:
- tls
environment:
addresses:
- 192.168.1.200:8443
- 10.160.195.1:8443
architectures:
- x86_64
- i686
certificate: |
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
certificate_fingerprint: ccbd532659224204c192fa609b86cce2282e722b5d6a7dde67e8f988661b9803
driver: lxc | qemu
driver_version: 4.0.6 | 5.2.0
firewall: nftables
kernel: Linux
kernel_architecture: x86_64
kernel_features:
netnsid_getifaddrs: "true"
seccomp_listener: "true"
shiftfs: "false"
uevent_injection: "true"
unpriv_fscaps: "true"
kernel_version: 5.11.11-arch1-1
lxc_features:
cgroup2: "true"
devpts_fd: "true"
mount_injection_file: "true"
network_ipvlan: "true"
network_l2proxy: "true"
network_veth_router: "true"
pidfd: "true"
seccomp_notify: "true"
os_name: Arch Linux
os_version: ""
project: default
server: lxd
server_clustered: false
server_name: LIVE.ARCH.BOX
server_pid: 1118
server_version: "4.12"
storage: lvm | btrfs
storage_version: 2.03.11(2) (2021-01-08) / 1.02.175 (2021-01-08) / 4.43.0 | 4.15.1
Another attempt: restore with uid/gid mapping profile remove -> try start -> add uid/gid mapping profile -> try start (another error) -> set container privileged -> try start …
t=2021-04-05T16:58:26+0300 lvl=dbug msg="New task Operation: aa83c921-7528-47e0-9599-9a9aaf08d505"
t=2021-04-05T16:58:26+0300 lvl=dbug msg="Started task operation: aa83c921-7528-47e0-9599-9a9aaf08d505"
t=2021-04-05T16:58:26+0300 lvl=dbug msg="\n\t{\n\t\t\"type\": \"async\",\n\t\t\"status\": \"Operation created\",\n\t\t\"status_code\": 100,\n\t\t\"operation\": \"/1.0/operations/aa83c921-7528-47e0-9599-9a9aaf08d505\",\n\t\t\"error_code\": 0,\n\t\t\"error\": \"\",\n\t\t\"metadata\": {\n\t\t\t\"id\": \"aa83c921-7528-47e0-9599-9a9aaf08d505\",\n\t\t\t\"class\": \"task\",\n\t\t\t\"description\": \"Starting instance\",\n\t\t\t\"created_at\": \"2021-04-05T16:58:26.24754608+03:00\",\n\t\t\t\"updated_at\": \"2021-04-05T16:58:26.24754608+03:00\",\n\t\t\t\"status\": \"Running\",\n\t\t\t\"status_code\": 103,\n\t\t\t\"resources\": {\n\t\t\t\t\"instances\": [\n\t\t\t\t\t\"/1.0/instances/xpraclient-arch\"\n\t\t\t\t]\n\t\t\t},\n\t\t\t\"metadata\": null,\n\t\t\t\"may_cancel\": false,\n\t\t\t\"err\": \"\",\n\t\t\t\"location\": \"none\"\n\t\t}\n\t}"
t=2021-04-05T16:58:26+0300 lvl=dbug msg="MountInstance started" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:58:26+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/operations/aa83c921-7528-47e0-9599-9a9aaf08d505 username=colt
t=2021-04-05T16:58:26+0300 lvl=dbug msg="Activated logical volume" dev=/dev/xpraclientTPoolVG/containers_xpraclient--arch driver=lvm pool=xpraclientTPool
t=2021-04-05T16:58:26+0300 lvl=dbug msg="Mounted logical volume" dev=/dev/xpraclientTPoolVG/containers_xpraclient--arch driver=lvm options=discard path=/var/snap/lxd/common/lxd/storage-pools/xpraclientTPool/containers/xpraclient-arch pool=xpraclientTPool
t=2021-04-05T16:58:26+0300 lvl=dbug msg="MountInstance finished" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:58:26+0300 lvl=dbug msg="Container idmap changed, remapping" instance=xpraclient-arch instanceType=container project=default
t=2021-04-05T16:58:26+0300 lvl=dbug msg="Updated metadata for task Operation: aa83c921-7528-47e0-9599-9a9aaf08d505"
t=2021-04-05T16:58:49+0300 lvl=dbug msg="UnmountInstance started" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:58:53+0300 lvl=dbug msg="Unmounted logical volume" driver=lvm keepBlockDev=false path=/var/snap/lxd/common/lxd/storage-pools/xpraclientTPool/containers/xpraclient-arch pool=xpraclientTPool
t=2021-04-05T16:58:53+0300 lvl=dbug msg="Deactivated logical volume" dev=/dev/xpraclientTPoolVG/containers_xpraclient--arch driver=lvm pool=xpraclientTPool
t=2021-04-05T16:58:53+0300 lvl=dbug msg="UnmountInstance finished" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:58:53+0300 lvl=dbug msg="Failure for task operation: aa83c921-7528-47e0-9599-9a9aaf08d505: Failed preparing container for start: invalid argument - Failed to change ACLs on /var/snap/lxd/common/lxd/storage-pools/xpraclientTPool/containers/xpraclient-arch/rootfs/var/log/journal"
t=2021-04-05T16:58:53+0300 lvl=dbug msg="Event listener finished: e941f934-d3b3-4da5-8e76-f14fb9eacbbc"
t=2021-04-05T16:58:53+0300 lvl=dbug msg="Disconnected event listener: e941f934-d3b3-4da5-8e76-f14fb9eacbbc"
t=2021-04-05T16:59:28+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0 username=colt
t=2021-04-05T16:59:28+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch username=colt
t=2021-04-05T16:59:28+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/events username=colt
t=2021-04-05T16:59:28+0300 lvl=dbug msg="New event listener: e722e336-af45-42ba-abf7-8732e9ca4fd6"
t=2021-04-05T16:59:28+0300 lvl=dbug msg=Handling ip=@ method=PUT protocol=unix url=/1.0/instances/xpraclient-arch username=colt
t=2021-04-05T16:59:28+0300 lvl=dbug msg="\n\t{\n\t\t\"architecture\": \"x86_64\",\n\t\t\"config\": {\n\t\t\t\"image.architecture\": \"x86_64\",\n\t\t\t\"image.description\": \"Archlinux x86_64 (20201120_04:33)\",\n\t\t\t\"image.name\": \"archlinux--x86_64-default-20201120_04:33\",\n\t\t\t\"image.os\": \"archlinux\",\n\t\t\t\"image.serial\": \"20201120_04:33\",\n\t\t\t\"image.variant\": \"default\",\n\t\t\t\"volatile.base_image\": \"9423095458216311d4022896fff73bb390fc72c57ff49940e0b8e09c398ce896\",\n\t\t\t\"volatile.eth0.hwaddr\": \"00:16:3e:7c:12:de\",\n\t\t\t\"volatile.idmap.base\": \"0\",\n\t\t\t\"volatile.idmap.current\": \"[{\\\"Isuid\\\":true,\\\"Isgid\\\":false,\\\"Hostid\\\":1000000,\\\"Nsid\\\":0,\\\"Maprange\\\":1000},{\\\"Isuid\\\":true,\\\"Isgid\\\":false,\\\"Hostid\\\":1000,\\\"Nsid\\\":1000,\\\"Maprange\\\":1},{\\\"Isuid\\\":true,\\\"Isgid\\\":false,\\\"Hostid\\\":1001001,\\\"Nsid\\\":1001,\\\"Maprange\\\":999998999},{\\\"Isuid\\\":false,\\\"Isgid\\\":true,\\\"Hostid\\\":1000000,\\\"Nsid\\\":0,\\\"Maprange\\\":985},{\\\"Isuid\\\":false,\\\"Isgid\\\":true,\\\"Hostid\\\":985,\\\"Nsid\\\":985,\\\"Maprange\\\":1},{\\\"Isuid\\\":false,\\\"Isgid\\\":true,\\\"Hostid\\\":1000986,\\\"Nsid\\\":986,\\\"Maprange\\\":999999014}]\",\n\t\t\t\"volatile.idmap.next\": \"[{\\\"Isuid\\\":true,\\\"Isgid\\\":false,\\\"Hostid\\\":1000000,\\\"Nsid\\\":0,\\\"Maprange\\\":1000000000},{\\\"Isuid\\\":false,\\\"Isgid\\\":true,\\\"Hostid\\\":1000000,\\\"Nsid\\\":0,\\\"Maprange\\\":1000000000}]\",\n\t\t\t\"volatile.last_state.idmap\": \"[{\\\"Isuid\\\":true,\\\"Isgid\\\":false,\\\"Hostid\\\":1000000,\\\"Nsid\\\":0,\\\"Maprange\\\":1000},{\\\"Isuid\\\":true,\\\"Isgid\\\":false,\\\"Hostid\\\":1000,\\\"Nsid\\\":1000,\\\"Maprange\\\":1},{\\\"Isuid\\\":true,\\\"Isgid\\\":false,\\\"Hostid\\\":1001001,\\\"Nsid\\\":1001,\\\"Maprange\\\":999998999},{\\\"Isuid\\\":false,\\\"Isgid\\\":true,\\\"Hostid\\\":1000000,\\\"Nsid\\\":0,\\\"Maprange\\\":985},{\\\"Isuid\\\":false,\\\"Isgid\\\":true,\\\"Hostid\\\":985,\\\"Nsid\\\":985,\\\"Maprange\\\":1},{\\\"Isuid\\\":false,\\\"Isgid\\\":true,\\\"Hostid\\\":1000986,\\\"Nsid\\\":986,\\\"Maprange\\\":999999014}]\",\n\t\t\t\"volatile.last_state.power\": \"RUNNING\",\n\t\t\t\"volatile.uuid\": \"c72e2b3c-56b4-42e4-9081-6c098e3da3d5\"\n\t\t},\n\t\t\"devices\": {\n\t\t\t\"root\": {\n\t\t\t\t\"path\": \"/\",\n\t\t\t\t\"pool\": \"xpraclientTPool\",\n\t\t\t\t\"type\": \"disk\"\n\t\t\t}\n\t\t},\n\t\t\"ephemeral\": false,\n\t\t\"profiles\": [\n\t\t\t\"xpraclient-arch\",\n\t\t\t\"shared_storage\",\n\t\t\t\"x11\"\n\t\t],\n\t\t\"stateful\": false,\n\t\t\"description\": \"\"\n\t}"
t=2021-04-05T16:59:28+0300 lvl=dbug msg="New task Operation: b729fa62-dca0-4fbd-bf65-074cc13e2314"
t=2021-04-05T16:59:28+0300 lvl=dbug msg="Started task operation: b729fa62-dca0-4fbd-bf65-074cc13e2314"
t=2021-04-05T16:59:28+0300 lvl=dbug msg="\n\t{\n\t\t\"type\": \"async\",\n\t\t\"status\": \"Operation created\",\n\t\t\"status_code\": 100,\n\t\t\"operation\": \"/1.0/operations/b729fa62-dca0-4fbd-bf65-074cc13e2314\",\n\t\t\"error_code\": 0,\n\t\t\"error\": \"\",\n\t\t\"metadata\": {\n\t\t\t\"id\": \"b729fa62-dca0-4fbd-bf65-074cc13e2314\",\n\t\t\t\"class\": \"task\",\n\t\t\t\"description\": \"Updating instance\",\n\t\t\t\"created_at\": \"2021-04-05T16:59:28.218831861+03:00\",\n\t\t\t\"updated_at\": \"2021-04-05T16:59:28.218831861+03:00\",\n\t\t\t\"status\": \"Running\",\n\t\t\t\"status_code\": 103,\n\t\t\t\"resources\": {\n\t\t\t\t\"containers\": [\n\t\t\t\t\t\"/1.0/containers/xpraclient-arch\"\n\t\t\t\t],\n\t\t\t\t\"instances\": [\n\t\t\t\t\t\"/1.0/instances/xpraclient-arch\"\n\t\t\t\t]\n\t\t\t},\n\t\t\t\"metadata\": null,\n\t\t\t\"may_cancel\": false,\n\t\t\t\"err\": \"\",\n\t\t\t\"location\": \"none\"\n\t\t}\n\t}"
t=2021-04-05T16:59:28+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/operations/b729fa62-dca0-4fbd-bf65-074cc13e2314 username=colt
t=2021-04-05T16:59:28+0300 lvl=dbug msg="UpdateInstanceBackupFile started" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:59:28+0300 lvl=dbug msg="Activated logical volume" dev=/dev/xpraclientTPoolVG/containers_xpraclient--arch driver=lvm pool=xpraclientTPool
t=2021-04-05T16:59:28+0300 lvl=dbug msg="Mounted logical volume" dev=/dev/xpraclientTPoolVG/containers_xpraclient--arch driver=lvm options=discard path=/var/snap/lxd/common/lxd/storage-pools/xpraclientTPool/containers/xpraclient-arch pool=xpraclientTPool
t=2021-04-05T16:59:28+0300 lvl=dbug msg="Unmounted logical volume" driver=lvm keepBlockDev=false path=/var/snap/lxd/common/lxd/storage-pools/xpraclientTPool/containers/xpraclient-arch pool=xpraclientTPool
t=2021-04-05T16:59:28+0300 lvl=dbug msg="Deactivated logical volume" dev=/dev/xpraclientTPoolVG/containers_xpraclient--arch driver=lvm pool=xpraclientTPool
t=2021-04-05T16:59:28+0300 lvl=dbug msg="UpdateInstanceBackupFile finished" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:59:28+0300 lvl=dbug msg="Success for task operation: b729fa62-dca0-4fbd-bf65-074cc13e2314"
t=2021-04-05T16:59:28+0300 lvl=dbug msg="Event listener finished: e722e336-af45-42ba-abf7-8732e9ca4fd6"
t=2021-04-05T16:59:28+0300 lvl=dbug msg="Disconnected event listener: e722e336-af45-42ba-abf7-8732e9ca4fd6"
t=2021-04-05T16:59:56+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0 username=colt
t=2021-04-05T16:59:56+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch username=colt
t=2021-04-05T16:59:56+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/events username=colt
t=2021-04-05T16:59:56+0300 lvl=dbug msg="New event listener: da94e425-da00-4c21-943e-8866b838721b"
t=2021-04-05T16:59:56+0300 lvl=dbug msg=Handling ip=@ method=PUT protocol=unix url=/1.0/instances/xpraclient-arch/state username=colt
t=2021-04-05T16:59:56+0300 lvl=dbug msg="\n\t{\n\t\t\"action\": \"start\",\n\t\t\"timeout\": 0,\n\t\t\"force\": false,\n\t\t\"stateful\": false\n\t}"
t=2021-04-05T16:59:56+0300 lvl=dbug msg="New task Operation: 3d26051f-321c-4a6f-bfdb-0998349f8f52"
t=2021-04-05T16:59:56+0300 lvl=dbug msg="Started task operation: 3d26051f-321c-4a6f-bfdb-0998349f8f52"
t=2021-04-05T16:59:56+0300 lvl=dbug msg="\n\t{\n\t\t\"type\": \"async\",\n\t\t\"status\": \"Operation created\",\n\t\t\"status_code\": 100,\n\t\t\"operation\": \"/1.0/operations/3d26051f-321c-4a6f-bfdb-0998349f8f52\",\n\t\t\"error_code\": 0,\n\t\t\"error\": \"\",\n\t\t\"metadata\": {\n\t\t\t\"id\": \"3d26051f-321c-4a6f-bfdb-0998349f8f52\",\n\t\t\t\"class\": \"task\",\n\t\t\t\"description\": \"Starting instance\",\n\t\t\t\"created_at\": \"2021-04-05T16:59:56.102566192+03:00\",\n\t\t\t\"updated_at\": \"2021-04-05T16:59:56.102566192+03:00\",\n\t\t\t\"status\": \"Running\",\n\t\t\t\"status_code\": 103,\n\t\t\t\"resources\": {\n\t\t\t\t\"instances\": [\n\t\t\t\t\t\"/1.0/instances/xpraclient-arch\"\n\t\t\t\t]\n\t\t\t},\n\t\t\t\"metadata\": null,\n\t\t\t\"may_cancel\": false,\n\t\t\t\"err\": \"\",\n\t\t\t\"location\": \"none\"\n\t\t}\n\t}"
t=2021-04-05T16:59:56+0300 lvl=dbug msg="MountInstance started" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:59:56+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/operations/3d26051f-321c-4a6f-bfdb-0998349f8f52 username=colt
t=2021-04-05T16:59:56+0300 lvl=dbug msg="Activated logical volume" dev=/dev/xpraclientTPoolVG/containers_xpraclient--arch driver=lvm pool=xpraclientTPool
t=2021-04-05T16:59:56+0300 lvl=dbug msg="Mounted logical volume" dev=/dev/xpraclientTPoolVG/containers_xpraclient--arch driver=lvm options=discard path=/var/snap/lxd/common/lxd/storage-pools/xpraclientTPool/containers/xpraclient-arch pool=xpraclientTPool
t=2021-04-05T16:59:56+0300 lvl=dbug msg="MountInstance finished" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:59:56+0300 lvl=dbug msg="Starting device" device=eth0 instance=xpraclient-arch instanceType=container project=default type=nic
t=2021-04-05T16:59:56+0300 lvl=dbug msg="Starting device" device=root instance=xpraclient-arch instanceType=container project=default type=disk
t=2021-04-05T16:59:56+0300 lvl=dbug msg="Starting device" device=shared_storage instance=xpraclient-arch instanceType=container project=default type=disk
t=2021-04-05T16:59:56+0300 lvl=dbug msg="Starting device" device=Xauthority2 instance=xpraclient-arch instanceType=container project=default type=disk
t=2021-04-05T16:59:56+0300 lvl=dbug msg="Starting device" device=Xauthority instance=xpraclient-arch instanceType=container project=default type=disk
t=2021-04-05T16:59:56+0300 lvl=dbug msg="Starting device" device=X0 instance=xpraclient-arch instanceType=container project=default type=proxy
t=2021-04-05T16:59:56+0300 lvl=dbug msg="Starting device" device=mygpu instance=xpraclient-arch instanceType=container project=default type=gpu
t=2021-04-05T16:59:56+0300 lvl=dbug msg="UpdateInstanceBackupFile started" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:59:56+0300 lvl=dbug msg="Skipping unmount as in use" driver=lvm pool=xpraclientTPool refCount=1
t=2021-04-05T16:59:56+0300 lvl=dbug msg="UpdateInstanceBackupFile finished" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:59:56+0300 lvl=info msg="Starting container" action=start created=2021-03-16T16:26:40+0200 ephemeral=false instance=xpraclient-arch instanceType=container project=default stateful=false used=2021-04-05T16:35:51+0300
t=2021-04-05T16:59:56+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url="/internal/containers/xpraclient-arch/onstart?project=default" username=root
t=2021-04-05T16:59:56+0300 lvl=dbug msg="Scheduler: container xpraclient-arch started: re-balancing"
t=2021-04-05T16:59:56+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url="/internal/containers/xpraclient-arch/onstopns?netns=%2Fproc%2F151778%2Ffd%2F4&project=default&target=stop" username=root
t=2021-04-05T16:59:56+0300 lvl=dbug msg="Stopping device" device=eth0 instance=xpraclient-arch instanceType=container project=default type=nic
t=2021-04-05T16:59:56+0300 lvl=dbug msg="Clearing instance firewall static filters" dev=eth0 host_name=veth9639ea57 hwaddr=00:16:3e:7c:12:de instance=xpraclient-arch ipv4=0.0.0.0 ipv6=:: parent=lxdbr0 project=default
t=2021-04-05T16:59:56+0300 lvl=dbug msg="Clearing instance firewall dynamic filters" dev=eth0 host_name=veth9639ea57 hwaddr=00:16:3e:7c:12:de instance=xpraclient-arch ipv4=<nil> ipv6=<nil> parent=lxdbr0 project=default
t=2021-04-05T16:59:56+0300 lvl=eror msg="Failed starting container" action=start created=2021-03-16T16:26:40+0200 ephemeral=false instance=xpraclient-arch instanceType=container project=default stateful=false used=2021-04-05T16:35:51+0300
t=2021-04-05T16:59:56+0300 lvl=dbug msg="Failure for task operation: 3d26051f-321c-4a6f-bfdb-0998349f8f52: Failed to run: /snap/lxd/current/bin/lxd forkstart xpraclient-arch /var/snap/lxd/common/lxd/containers /var/snap/lxd/common/lxd/logs/xpraclient-arch/lxc.conf: "
t=2021-04-05T16:59:56+0300 lvl=dbug msg="Event listener finished: da94e425-da00-4c21-943e-8866b838721b"
t=2021-04-05T16:59:56+0300 lvl=dbug msg="Disconnected event listener: da94e425-da00-4c21-943e-8866b838721b"
t=2021-04-05T16:59:57+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url="/internal/containers/xpraclient-arch/onstop?project=default&target=stop" username=root
t=2021-04-05T16:59:57+0300 lvl=dbug msg="Container initiated" action=stop created=2021-03-16T16:26:40+0200 ephemeral=false instance=xpraclient-arch instanceType=container project=default stateful=false used=2021-04-05T16:59:56+0300
t=2021-04-05T16:59:57+0300 lvl=dbug msg="Container stopped, cleaning up" instance=xpraclient-arch instanceType=container project=default
t=2021-04-05T16:59:57+0300 lvl=dbug msg="Stopping device" device=mygpu instance=xpraclient-arch instanceType=container project=default type=gpu
t=2021-04-05T16:59:57+0300 lvl=dbug msg="Stopping device" device=X0 instance=xpraclient-arch instanceType=container project=default type=proxy
t=2021-04-05T16:59:57+0300 lvl=dbug msg="Stopping device" device=Xauthority instance=xpraclient-arch instanceType=container project=default type=disk
t=2021-04-05T16:59:57+0300 lvl=dbug msg="Stopping device" device=Xauthority2 instance=xpraclient-arch instanceType=container project=default type=disk
t=2021-04-05T16:59:57+0300 lvl=dbug msg="Stopping device" device=shared_storage instance=xpraclient-arch instanceType=container project=default type=disk
t=2021-04-05T16:59:57+0300 lvl=dbug msg="Stopping device" device=root instance=xpraclient-arch instanceType=container project=default type=disk
t=2021-04-05T16:59:57+0300 lvl=dbug msg="UnmountInstance started" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:59:57+0300 lvl=dbug msg="Unmounted logical volume" driver=lvm keepBlockDev=false path=/var/snap/lxd/common/lxd/storage-pools/xpraclientTPool/containers/xpraclient-arch pool=xpraclientTPool
t=2021-04-05T16:59:57+0300 lvl=dbug msg="Deactivated logical volume" dev=/dev/xpraclientTPoolVG/containers_xpraclient--arch driver=lvm pool=xpraclientTPool
t=2021-04-05T16:59:57+0300 lvl=dbug msg="UnmountInstance finished" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T16:59:57+0300 lvl=info msg="Shut down container" action=stop created=2021-03-16T16:26:40+0200 ephemeral=false instance=xpraclient-arch instanceType=container project=default stateful=false used=2021-04-05T16:59:56+0300
t=2021-04-05T16:59:57+0300 lvl=dbug msg="Scheduler: container xpraclient-arch stopped: re-balancing"
t=2021-04-05T17:01:05+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0 username=colt
t=2021-04-05T17:01:05+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch username=colt
t=2021-04-05T17:01:13+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0 username=colt
t=2021-04-05T17:01:13+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch username=colt
t=2021-04-05T17:01:13+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/events username=colt
t=2021-04-05T17:01:13+0300 lvl=dbug msg="New event listener: 4bdd06a2-a455-4320-a990-6732171f4f41"
t=2021-04-05T17:01:13+0300 lvl=dbug msg=Handling ip=@ method=PUT protocol=unix url=/1.0/instances/xpraclient-arch username=colt
t=2021-04-05T17:01:13+0300 lvl=dbug msg="\n\t{\n\t\t\"architecture\": \"x86_64\",\n\t\t\"config\": {\n\t\t\t\"image.architecture\": \"x86_64\",\n\t\t\t\"image.description\": \"Archlinux x86_64 (20201120_04:33)\",\n\t\t\t\"image.name\": \"archlinux--x86_64-default-20201120_04:33\",\n\t\t\t\"image.os\": \"archlinux\",\n\t\t\t\"image.serial\": \"20201120_04:33\",\n\t\t\t\"image.variant\": \"default\",\n\t\t\t\"security.privileged\": \"true\",\n\t\t\t\"volatile.base_image\": \"9423095458216311d4022896fff73bb390fc72c57ff49940e0b8e09c398ce896\",\n\t\t\t\"volatile.eth0.hwaddr\": \"00:16:3e:7c:12:de\",\n\t\t\t\"volatile.idmap.base\": \"0\",\n\t\t\t\"volatile.idmap.current\": \"[{\\\"Isuid\\\":true,\\\"Isgid\\\":false,\\\"Hostid\\\":1000000,\\\"Nsid\\\":0,\\\"Maprange\\\":1000},{\\\"Isuid\\\":true,\\\"Isgid\\\":false,\\\"Hostid\\\":1000,\\\"Nsid\\\":1000,\\\"Maprange\\\":1},{\\\"Isuid\\\":true,\\\"Isgid\\\":false,\\\"Hostid\\\":1001001,\\\"Nsid\\\":1001,\\\"Maprange\\\":999998999},{\\\"Isuid\\\":false,\\\"Isgid\\\":true,\\\"Hostid\\\":1000000,\\\"Nsid\\\":0,\\\"Maprange\\\":985},{\\\"Isuid\\\":false,\\\"Isgid\\\":true,\\\"Hostid\\\":985,\\\"Nsid\\\":985,\\\"Maprange\\\":1},{\\\"Isuid\\\":false,\\\"Isgid\\\":true,\\\"Hostid\\\":1000986,\\\"Nsid\\\":986,\\\"Maprange\\\":999999014}]\",\n\t\t\t\"volatile.idmap.next\": \"[{\\\"Isuid\\\":true,\\\"Isgid\\\":false,\\\"Hostid\\\":1000000,\\\"Nsid\\\":0,\\\"Maprange\\\":1000},{\\\"Isuid\\\":true,\\\"Isgid\\\":false,\\\"Hostid\\\":1000,\\\"Nsid\\\":1000,\\\"Maprange\\\":1},{\\\"Isuid\\\":true,\\\"Isgid\\\":false,\\\"Hostid\\\":1001001,\\\"Nsid\\\":1001,\\\"Maprange\\\":999998999},{\\\"Isuid\\\":false,\\\"Isgid\\\":true,\\\"Hostid\\\":1000000,\\\"Nsid\\\":0,\\\"Maprange\\\":985},{\\\"Isuid\\\":false,\\\"Isgid\\\":true,\\\"Hostid\\\":985,\\\"Nsid\\\":985,\\\"Maprange\\\":1},{\\\"Isuid\\\":false,\\\"Isgid\\\":true,\\\"Hostid\\\":1000986,\\\"Nsid\\\":986,\\\"Maprange\\\":999999014}]\",\n\t\t\t\"volatile.last_state.idmap\": \"[{\\\"Isuid\\\":true,\\\"Isgid\\\":false,\\\"Hostid\\\":1000000,\\\"Nsid\\\":0,\\\"Maprange\\\":1000},{\\\"Isuid\\\":true,\\\"Isgid\\\":false,\\\"Hostid\\\":1000,\\\"Nsid\\\":1000,\\\"Maprange\\\":1},{\\\"Isuid\\\":true,\\\"Isgid\\\":false,\\\"Hostid\\\":1001001,\\\"Nsid\\\":1001,\\\"Maprange\\\":999998999},{\\\"Isuid\\\":false,\\\"Isgid\\\":true,\\\"Hostid\\\":1000000,\\\"Nsid\\\":0,\\\"Maprange\\\":985},{\\\"Isuid\\\":false,\\\"Isgid\\\":true,\\\"Hostid\\\":985,\\\"Nsid\\\":985,\\\"Maprange\\\":1},{\\\"Isuid\\\":false,\\\"Isgid\\\":true,\\\"Hostid\\\":1000986,\\\"Nsid\\\":986,\\\"Maprange\\\":999999014}]\",\n\t\t\t\"volatile.last_state.power\": \"STOPPED\",\n\t\t\t\"volatile.uuid\": \"c72e2b3c-56b4-42e4-9081-6c098e3da3d5\"\n\t\t},\n\t\t\"devices\": {\n\t\t\t\"root\": {\n\t\t\t\t\"path\": \"/\",\n\t\t\t\t\"pool\": \"xpraclientTPool\",\n\t\t\t\t\"type\": \"disk\"\n\t\t\t}\n\t\t},\n\t\t\"ephemeral\": false,\n\t\t\"profiles\": [\n\t\t\t\"xpraclient-arch\",\n\t\t\t\"shared_storage\",\n\t\t\t\"x11\"\n\t\t],\n\t\t\"stateful\": false,\n\t\t\"description\": \"\"\n\t}"
t=2021-04-05T17:01:13+0300 lvl=dbug msg="New task Operation: 41c16458-b0f2-4f55-b383-0ecdcc503962"
t=2021-04-05T17:01:13+0300 lvl=dbug msg="Started task operation: 41c16458-b0f2-4f55-b383-0ecdcc503962"
t=2021-04-05T17:01:13+0300 lvl=dbug msg="\n\t{\n\t\t\"type\": \"async\",\n\t\t\"status\": \"Operation created\",\n\t\t\"status_code\": 100,\n\t\t\"operation\": \"/1.0/operations/41c16458-b0f2-4f55-b383-0ecdcc503962\",\n\t\t\"error_code\": 0,\n\t\t\"error\": \"\",\n\t\t\"metadata\": {\n\t\t\t\"id\": \"41c16458-b0f2-4f55-b383-0ecdcc503962\",\n\t\t\t\"class\": \"task\",\n\t\t\t\"description\": \"Updating instance\",\n\t\t\t\"created_at\": \"2021-04-05T17:01:13.395574516+03:00\",\n\t\t\t\"updated_at\": \"2021-04-05T17:01:13.395574516+03:00\",\n\t\t\t\"status\": \"Running\",\n\t\t\t\"status_code\": 103,\n\t\t\t\"resources\": {\n\t\t\t\t\"containers\": [\n\t\t\t\t\t\"/1.0/containers/xpraclient-arch\"\n\t\t\t\t],\n\t\t\t\t\"instances\": [\n\t\t\t\t\t\"/1.0/instances/xpraclient-arch\"\n\t\t\t\t]\n\t\t\t},\n\t\t\t\"metadata\": null,\n\t\t\t\"may_cancel\": false,\n\t\t\t\"err\": \"\",\n\t\t\t\"location\": \"none\"\n\t\t}\n\t}"
t=2021-04-05T17:01:13+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/operations/41c16458-b0f2-4f55-b383-0ecdcc503962 username=colt
t=2021-04-05T17:01:13+0300 lvl=dbug msg="UpdateInstanceBackupFile started" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T17:01:13+0300 lvl=dbug msg="Activated logical volume" dev=/dev/xpraclientTPoolVG/containers_xpraclient--arch driver=lvm pool=xpraclientTPool
t=2021-04-05T17:01:13+0300 lvl=dbug msg="Mounted logical volume" dev=/dev/xpraclientTPoolVG/containers_xpraclient--arch driver=lvm options=discard path=/var/snap/lxd/common/lxd/storage-pools/xpraclientTPool/containers/xpraclient-arch pool=xpraclientTPool
t=2021-04-05T17:01:13+0300 lvl=dbug msg="Unmounted logical volume" driver=lvm keepBlockDev=false path=/var/snap/lxd/common/lxd/storage-pools/xpraclientTPool/containers/xpraclient-arch pool=xpraclientTPool
t=2021-04-05T17:01:14+0300 lvl=dbug msg="Deactivated logical volume" dev=/dev/xpraclientTPoolVG/containers_xpraclient--arch driver=lvm pool=xpraclientTPool
t=2021-04-05T17:01:14+0300 lvl=dbug msg="UpdateInstanceBackupFile finished" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T17:01:14+0300 lvl=dbug msg="Success for task operation: 41c16458-b0f2-4f55-b383-0ecdcc503962"
t=2021-04-05T17:01:14+0300 lvl=dbug msg="Event listener finished: 4bdd06a2-a455-4320-a990-6732171f4f41"
t=2021-04-05T17:01:14+0300 lvl=dbug msg="Disconnected event listener: 4bdd06a2-a455-4320-a990-6732171f4f41"
t=2021-04-05T17:01:21+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0 username=colt
t=2021-04-05T17:01:21+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/instances/xpraclient-arch username=colt
t=2021-04-05T17:01:21+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/events username=colt
t=2021-04-05T17:01:21+0300 lvl=dbug msg="New event listener: 4c631b84-e27c-444a-af1e-8a2a1677c077"
t=2021-04-05T17:01:21+0300 lvl=dbug msg=Handling ip=@ method=PUT protocol=unix url=/1.0/instances/xpraclient-arch/state username=colt
t=2021-04-05T17:01:21+0300 lvl=dbug msg="\n\t{\n\t\t\"action\": \"start\",\n\t\t\"timeout\": 0,\n\t\t\"force\": false,\n\t\t\"stateful\": false\n\t}"
t=2021-04-05T17:01:21+0300 lvl=dbug msg="New task Operation: 86d6716d-5341-4bc1-aa30-01b269da208e"
t=2021-04-05T17:01:21+0300 lvl=dbug msg="Started task operation: 86d6716d-5341-4bc1-aa30-01b269da208e"
t=2021-04-05T17:01:21+0300 lvl=dbug msg="\n\t{\n\t\t\"type\": \"async\",\n\t\t\"status\": \"Operation created\",\n\t\t\"status_code\": 100,\n\t\t\"operation\": \"/1.0/operations/86d6716d-5341-4bc1-aa30-01b269da208e\",\n\t\t\"error_code\": 0,\n\t\t\"error\": \"\",\n\t\t\"metadata\": {\n\t\t\t\"id\": \"86d6716d-5341-4bc1-aa30-01b269da208e\",\n\t\t\t\"class\": \"task\",\n\t\t\t\"description\": \"Starting instance\",\n\t\t\t\"created_at\": \"2021-04-05T17:01:21.082762196+03:00\",\n\t\t\t\"updated_at\": \"2021-04-05T17:01:21.082762196+03:00\",\n\t\t\t\"status\": \"Running\",\n\t\t\t\"status_code\": 103,\n\t\t\t\"resources\": {\n\t\t\t\t\"instances\": [\n\t\t\t\t\t\"/1.0/instances/xpraclient-arch\"\n\t\t\t\t]\n\t\t\t},\n\t\t\t\"metadata\": null,\n\t\t\t\"may_cancel\": false,\n\t\t\t\"err\": \"\",\n\t\t\t\"location\": \"none\"\n\t\t}\n\t}"
t=2021-04-05T17:01:21+0300 lvl=dbug msg=Handling ip=@ method=GET protocol=unix url=/1.0/operations/86d6716d-5341-4bc1-aa30-01b269da208e username=colt
t=2021-04-05T17:01:21+0300 lvl=dbug msg="MountInstance started" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T17:01:21+0300 lvl=dbug msg="Activated logical volume" dev=/dev/xpraclientTPoolVG/containers_xpraclient--arch driver=lvm pool=xpraclientTPool
t=2021-04-05T17:01:21+0300 lvl=dbug msg="Mounted logical volume" dev=/dev/xpraclientTPoolVG/containers_xpraclient--arch driver=lvm options=discard path=/var/snap/lxd/common/lxd/storage-pools/xpraclientTPool/containers/xpraclient-arch pool=xpraclientTPool
t=2021-04-05T17:01:21+0300 lvl=dbug msg="MountInstance finished" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T17:01:21+0300 lvl=dbug msg="Container idmap changed, remapping" instance=xpraclient-arch instanceType=container project=default
t=2021-04-05T17:01:21+0300 lvl=dbug msg="Updated metadata for task Operation: 86d6716d-5341-4bc1-aa30-01b269da208e"
t=2021-04-05T17:01:40+0300 lvl=dbug msg="UnmountInstance started" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T17:01:41+0300 lvl=dbug msg="Unmounted logical volume" driver=lvm keepBlockDev=false path=/var/snap/lxd/common/lxd/storage-pools/xpraclientTPool/containers/xpraclient-arch pool=xpraclientTPool
t=2021-04-05T17:01:42+0300 lvl=dbug msg="Deactivated logical volume" dev=/dev/xpraclientTPoolVG/containers_xpraclient--arch driver=lvm pool=xpraclientTPool
t=2021-04-05T17:01:42+0300 lvl=dbug msg="UnmountInstance finished" driver=lvm instance=xpraclient-arch pool=xpraclientTPool project=default
t=2021-04-05T17:01:42+0300 lvl=dbug msg="Failure for task operation: 86d6716d-5341-4bc1-aa30-01b269da208e: Failed preparing container for start: invalid argument - Failed to change ACLs on /var/snap/lxd/common/lxd/storage-pools/xpraclientTPool/containers/xpraclient-arch/rootfs/var/log/journal"
t=2021-04-05T17:01:42+0300 lvl=dbug msg="Event listener finished: 4c631b84-e27c-444a-af1e-8a2a1677c077"
t=2021-04-05T17:01:42+0300 lvl=dbug msg="Disconnected event listener: 4c631b84-e27c-444a-af1e-8a2a1677c077"
UPD luckily lxc copy worked with no errors, however to start container i had to enable privileged mode, otherwise there was an error:
msg="Failure for task operation: 6d2ea60c-6e38-4511-b798-d24733de9638: Failed to run: /snap/lxd/current/bin/lxd forkstart xprabro /var/snap/lxd/common/lxd/containers /var/snap/lxd/common/lxd/logs/xprabro/lxc.conf: "
