mar
(Madeline Autumn-Rose)
1
After an update to 4.3 VMs no longer start, here’s the log.
Error: Failed to run: /snap/lxd/current/bin/lxd forklimits limit=memlock:unlimited:unlimited -- /snap/lxd/16044/bin/qemu-system-x86_64 -S -name pod-890-1000-00 -uuid <uuid> -daemonize -cpu host -nographic -serial chardev:console -nodefaults -no-reboot -no-user-config -sandbox on,obsolete=deny,elevateprivileges=allow,spawn=deny,resourcecontrol=deny -readconfig /var/snap/lxd/common/lxd/logs/<company>-staging2_pod-890-1000-00/qemu.conf -pidfile /var/snap/lxd/common/lxd/logs/<company>-staging2_pod-`Preformatted text`890-1000-00/qemu.pid -D /var/snap/lxd/common/lxd/logs/<company>-staging2_pod-890-1000-00/qemu.log -chroot /var/snap/lxd/common/lxd/virtual-machines/<company>-staging2_pod-890-1000-00 -smbios type=2,manufacturer=Canonical Ltd.,product=LXD -runas lxd: : exit status 1
Try `lxc info --show-log pod-890-1000-00` for more info
ubuntu@aa1-cptef101-n1:~$ lxc info --show-log --project <company>-staging2 pod-890-1000-00
Remote: unix://
Created: 2020/06/18 23:54 UTC
Status: Stopped
Type: virtual-machine
Profiles: stagingtwo-virtual-vault-890
Snapshots:
snap0 (taken at 2020/06/19 01:15 UTC) (stateless)
pre-common-yml (taken at 2020/06/30 18:42 UTC) (stateless)
phase3 (taken at 2020/06/30 23:34 UTC) (stateless)
Log:
qemu-system-x86_64:/var/snap/lxd/common/lxd/logs/<company>-staging2_pod-890-1000-00/qemu.conf:226: Parameter 'locking' is unexpected
stgraber
(Stéphane Graber)
2
Can you show the qemu.conf
for that VM?
stgraber
(Stéphane Graber)
3
And lxc config show --expanded NAME
for the VM.
I know what the problem is but need to track down exactly what code path needs to skip the file.locking
feature.
mar
4
QEMU Config:
# Machine
[machine]
graphics = “off”
type = “q35”
accel = “kvm”
usb = “off”
graphics = “off”
[global]
driver = "ICH9-LPC"
property = "disable_s3"
value = "1"
[global]
driver = "ICH9-LPC"
property = "disable_s4"
value = "1"
[boot-opts]
strict = "on"
# Console
[chardev "console"]
backend = "pty"
# Graphical console
[spice]
unix = "on"
addr = "/var/snap/lxd/common/lxd/logs/<company>-staging2_pod-890-1000-00/qemu.spice"
disable-ticketing = "on"
# Memory
[memory]
size = "15258M"
# CPU
[smp-opts]
cpus = "8"
sockets = "1"
cores = "8"
threads = "1"
# Firmware (read only)
[drive]
file = "/snap/lxd/current/share/qemu/OVMF_CODE.fd"
if = "pflash"
format = "raw"
unit = "0"
readonly = "on"
# Firmware settings (writable)
[drive]
file = "/var/snap/lxd/common/lxd/virtual-machines/<company>-staging2_pod-890-1000-00/qemu.nvram"
if = "pflash"
format = "raw"
unit = "1"
# Qemu control
[chardev "monitor"]
backend = "socket"
path = "/var/snap/lxd/common/lxd/logs/<company>-staging2_pod-890-1000-00/qemu.monitor"
server = "on"
wait = "off"
[mon]
chardev = "monitor"
mode = "control"
[device "qemu_pcie0"]
driver = "pcie-root-port"
bus = "pcie.0"
addr = "1.0"
chassis = "0"
multifunction = "on"
# Balloon driver
[device "qemu_balloon"]
driver = "virtio-balloon-pci"
bus = "qemu_pcie0"
addr = "00.0"
# Random number generator
[object "qemu_rng"]
qom-type = "rng-random"
filename = "/dev/urandom"
[device "dev-qemu_rng"]
driver = "virtio-rng-pci"
bus = "qemu_pcie0"
addr = "00.1"
rng = "qemu_rng"
# Input
[device "qemu_keyboard"]
driver = "virtio-keyboard-pci"
bus = "qemu_pcie0"
addr = "00.2"
# Input
[device "qemu_tablet"]
driver = "virtio-tablet-pci"
bus = "qemu_pcie0"
addr = "00.3"
# Vsock
[device "qemu_vsock"]
driver = "vhost-vsock-pci"
bus = "qemu_pcie0"
addr = "00.4"
guest-cid = "71"
# LXD serial identifier
[device "dev-qemu_serial"]
driver = "virtio-serial-pci"
bus = "qemu_pcie0"
addr = "00.5"
[chardev "qemu_serial-chardev"]
backend = "ringbuf"
size = "16B"
[device "qemu_serial"]
driver = "virtserialport"
name = "org.linuxcontainers.lxd"
chardev = "qemu_serial-chardev"
bus = "dev-qemu_serial.0"
[device "qemu_pcie1"]
bus = "pcie.0"
addr = "1.1"
chassis = "1"
# SCSI controller
[device "qemu_scsi"]
driver = "virtio-scsi-pci"
bus = "qemu_pcie1"
addr = "00.0"
[device "qemu_pcie2"]
bus = "pcie.0"
addr = "1.2"
chassis = "2"
# Config drive
[fsdev "qemu_config"]
fsdriver = "local"
security_model = "none"
readonly = "on"
path = "/var/snap/lxd/common/lxd/virtual-machines/<company>-staging2_pod-890-1000-00/config"
[device "dev-qemu_config"]
driver = "virtio-9p-pci"
bus = "qemu_pcie2"
addr = "00.0"
mount_tag = "config"
fsdev = "qemu_config"
[device "qemu_pcie3"]
bus = "pcie.0"
addr = "1.3"
chassis = "3"
# GPU
[device "qemu_gpu"]
driver = "virtio-vga"
bus = "qemu_pcie3"
addr = "00.0"
[device "qemu_pcie4"]
bus = "pcie.0"
addr = "1.4"
chassis = "4"
# Network card ("eth0" device)
[netdev "lxd_eth0"]
type = "tap"
vhost = "on"
ifname = "tap6a5eb9bd"
script = "no"
downscript = "no"
[device "dev-lxd_eth0"]
driver = "virtio-net-pci"
bus = "qemu_pcie4"
addr = "00.0"
netdev = "lxd_eth0"
mac = "00:16:3e:4d:81:a2"
bootindex = "1"
# audit drive
[drive "lxd_audit"]
file = "rbd:lxd-virtualvaultfs-01/disk_pod-890-1000-00_audit:id=lxd:conf=/etc/ceph/ceph.conf"
format = "raw"
if = "none"
cache = "none"
aio = "native"
discard = "on"
file.locking = "off"
[device "dev-lxd_audit"]
driver = "scsi-hd"
bus = "qemu_scsi.0"
channel = "0"
scsi-id = "4"
lun = "1"
drive = "lxd_audit"
bootindex = "4"
# disk_a drive
[drive "lxd_disk_a"]
file = "rbd:lxd-virtualvaultfs-01/disk_pod-890-1000-00_a:id=lxd:conf=/etc/ceph/ceph.conf"
format = "raw"
if = "none"
cache = "none"
aio = "native"
discard = "on"
[device "dev-lxd_disk_a"]
driver = "scsi-hd"
bus = "qemu_scsi.0"
channel = "0"
scsi-id = "5"
lun = "1"
drive = "lxd_disk_a"
bootindex = "5"
# disk_b drive
[drive "lxd_disk_b"]
file = "rbd:lxd-virtualvaultfs-01/disk_pod-890-1000-00_b:id=lxd:conf=/etc/ceph/ceph.conf"
format = "raw"
if = "none"
cache = "none"
aio = "native"
discard = "on"
[device "dev-lxd_disk_b"]
driver = "scsi-hd"
bus = "qemu_scsi.0"
channel = "0"
scsi-id = "6"
lun = "1"
drive = "lxd_disk_b"
bootindex = "6"
# disk_c drive
[drive "lxd_disk_c"]
file = "rbd:lxd-virtualvaultfs-01/disk_pod-890-1000-00_c:id=lxd:conf=/etc/ceph/ceph.conf"
format = "raw"
if = "none"
cache = "none"
aio = "native"
discard = "on"
[device "dev-lxd_disk_c"]
driver = "scsi-hd"
bus = "qemu_scsi.0"
channel = "0"
scsi-id = "2"
lun = "1"
drive = "lxd_disk_c"
bootindex = "2"
# disk_d drive
[drive "lxd_disk_d"]
file = "rbd:lxd-virtualvaultfs-01/disk_pod-890-1000-00_d:id=lxd:conf=/etc/ceph/ceph.conf"
format = "raw"
if = "none"
cache = "none"
aio = "native"
discard = "on"
[device "dev-lxd_disk_d"]
driver = "scsi-hd"
bus = "qemu_scsi.0"
channel = "0"
scsi-id = "3"
lun = "1"
drive = "lxd_disk_d"
bootindex = "3"
# root drive
[drive "lxd_root"]
file = "/dev/rbd8"
format = "raw"
if = "none"
cache = "none"
aio = "native"
discard = "on"
[device "dev-lxd_root"]
driver = "scsi-hd"
bus = "qemu_scsi.0"
channel = "0"
scsi-id = "0"
lun = "1"
drive = "lxd_root"
bootindex = "0"
Config:
image.architecture: amd64
image.description: Debian stretch amd64 (20200618_16:58)
image.os: Debian
image.release: stretch
image.serial: “20200618_16:58”
image.type: disk-kvm.img
limits.cpu: “8”
limits.memory: 16GB
security.secureboot: “false”
volatile.base_image: 214c4284fea0055f1563e75a54dc349259428d43ea5e8502a78092b63d3852ec
volatile.eth0.hwaddr: 00:16:3e:4d:81:a2
volatile.vm.uuid:
audit:
ceph.cluster_name: ceph
ceph.user_name: lxd
source: ceph:lxd-virtualvaultfs-01/disk_pod-890-1000-00_audit
disk_a:
ceph.user_name: lxd
disk_b:
ceph.user_name: lxd
source: ceph:lxd-virtualvaultfs-01/disk_pod-890-1000-00_b
disk_c:
ceph.user_name: lxd
source: ceph:lxd-virtualvaultfs-01/disk_pod-890-1000-00_c
disk_d:
ceph.user_name: lxd
source: ceph:lxd-virtualvaultfs-01/disk_pod-890-1000-00_d
nictype: bridged
parent: br4
pool: ceph
- stagingtwo-virtual-vault-890
description: “”
stgraber
(Stéphane Graber)
5
mar
7
How long until this hits stable in snap?
stgraber
(Stéphane Graber)
8
I just pushed the cherry-pick now, will hit candidate in the next hour and should be in stable in the next 2-3 hours.
