Hello.
I’m not enthousiast using snap packaging for LXD on my fedora 32. How to build a dedicated rpm package from sources?
Thanks in advance for your help
Hello.
@ganto has a few COPR repos with various versions of LXC/LXD in them.
I’m not sure about the state of LXD 4.x in those but you may be able to re-use the packaging for your own builds.
Yes I had seen that but the latest builded version is 3.x. I looking to build a 4.x version
I going to ask him about how to build this from fedora. Thanks for the link
