Trying to figure out the best way to get ansible to do its magic within the containers. Was thinking of using ssh in each container, but then that is server-dependent. or I have to come via the proxy which seems like more work than should be necessary.
Again, I am already creating containers, deleting etc… I am talking about running commands within the container with ansible not via lxc exec containername bash which I can do now.
Anyone figure out the best way to do it.
It’s pretty easy to do.
The simple way to achieve it is following:
Create a container image with your own public ssh keys and with ansible dependency installed. Like you will need to define python path.
Launch new containers from this image.
Use host as proxyjump, the account used on host should also have the same public key in authorized_keys. For example your machine running ansible script add “~/.ssh/config” file as:
Host 192.168.*.*
HostName %h
IdentityFile ~/.ssh/id_rsa
ProxyJump 106.10.250.10
User ubuntu
Following is a simple ansible script to work with a dynamically created container. We have not used lxd module in ansible as it is not updated for quite sometime. So it does not work predictably but “awk” works predictable.
- hosts:
your_host_address_or_dns_name
remote_user: ubuntu
gather_facts: no
tasks:
- name: Check container list
command:
/snap/bin/lxc list
register: container_list
- name: Create and launch a container named test
command:
"/snap/bin/lxc launch test-image test"
when: ("test" not in container_list.stdout)
register: test_var
- name: Wait for 10 seconds before checking the address
wait_for:
timeout:
10
delegate_to:
localhost
- name: Get the test container ip
shell:
/snap/bin/lxc list test -c 4 | awk '!/IPV4/{ if ( $2 != "" ) print $2}'
register:
test_ipv4
when: test_var is defined
- name: Add this container information as dynamic host
add_host:
gather_facts: no
ansible_python_interpreter: /usr/bin/python3
name:
"{{ test_ipv4.stdout }}"
groups:
- testgroup
- hosts:
testgroup
remote_user: ubuntu
become: yes
become_method: sudo
tasks:
- name: Test information
debug:
msg:
"System working {{ ansible_host }}"
- name: Ping the server
ping:
register: testcontainer
- hosts:
your_host_ip_or_dns_name
remote_user: ubuntu
gather_facts: no
tasks:
command:
/snap/bin/lxc list
- name: Stop test container to create test base image
command:
/snap/bin/lxc stop test
when: ('test' in container_list.stdout)
register: test_image
- name: Check if the image exist
command:
/snap/bin/lxc image list
register: image_list
- name: Create image from test container when image do not exist
command:
/snap/bin/lxc publish test --alias test-1.0
when: ("test-1.0" not in image_list.stdout)
