I am trying to configure an LXD cluster with multiples isolated fan networks.
I didn’t understand how I should do to get it done.
This is my set up :
$ lxc cluster list
| NAME | URL | DATABASE | STATE | MESSAGE |
| lxd1 | https://192.168.56.11:8443 | YES | ONLINE | fully operational |
| lxd2 | https://192.168.56.12:8443 | YES | ONLINE | fully operational |
| lxd3 | https://192.168.56.13:8443 | YES | ONLINE | fully operational |
$ lxc network list
| NAME | TYPE | MANAGED | DESCRIPTION | USED BY | STATE |
| enp0s3 | physical | NO | | 0 | |
| enp0s8 | physical | NO | | 0 | |
| lxdfan0 | bridge | YES | | 3 | CREATED |
| lxdfan1 | bridge | YES | | 2 | PENDING |
$ lxc network show lxdfan0
bridge.mode: fan
fan.overlay_subnet: 240.1.0.0/16
fan.underlay_subnet: 192.168.56.0/24
type: bridge
- /1.0/containers/c1
- /1.0/containers/c2
- /1.0/containers/c3
managed: true
status: Created
locations:
- lxd1
- lxd2
- lxd3
$ lxc network show lxdfan1
bridge.mode: fan
fan.overlay_subnet: 240.2.0.0/16
type: bridge
- /1.0/containers/d1
- /1.0/containers/d2
managed: true
status: Pending
locations:
- lxd2
$ lxc list
| c1 | RUNNING | 240.1.11.155 (eth0) | | PERSISTENT | | lxd1 |
| c2 | RUNNING | 240.1.12.88 (eth0) | | PERSISTENT | | lxd2 |
| c3 | RUNNING | 240.1.13.187 (eth0) | | PERSISTENT | | lxd3 |
| d1 | RUNNING | 240.2.11.165 (eth0) | | PERSISTENT | | lxd1 |
| d2 | RUNNING | 240.2.12.160 (eth0) | | PERSISTENT | | lxd2 |
- c1 can ping cX and dX (dX should be forbidden)
- d1 can ping dX and cX (cX should be forbidden)
So I checked iptables rules, traffic is authorized between lxdfan networks:
Chain INPUT (policy ACCEPT 102K packets, 13M bytes)
pkts bytes target prot opt in out source destination
0 0 ACCEPT tcp -- lxdfan1 * 0.0.0.0/0 0.0.0.0/0 tcp dpt:53 /* generated for LXD network lxdfan1 */
4 277 ACCEPT udp -- lxdfan1 * 0.0.0.0/0 0.0.0.0/0 udp dpt:53 /* generated for LXD network lxdfan1 */
1 312 ACCEPT udp -- lxdfan1 * 0.0.0.0/0 0.0.0.0/0 udp dpt:67 /* generated for LXD network lxdfan1 */
0 0 ACCEPT tcp -- lxdfan0 * 0.0.0.0/0 0.0.0.0/0 tcp dpt:53 /* generated for LXD network lxdfan0 */
3 205 ACCEPT udp -- lxdfan0 * 0.0.0.0/0 0.0.0.0/0 udp dpt:53 /* generated for LXD network lxdfan0 */
2 624 ACCEPT udp -- lxdfan0 * 0.0.0.0/0 0.0.0.0/0 udp dpt:67 /* generated for LXD network lxdfan0 */
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
242 23364 ACCEPT all -- * lxdfan1 0.0.0.0/0 0.0.0.0/0 /* generated for LXD network lxdfan1 */
242 20731 ACCEPT all -- lxdfan1 * 0.0.0.0/0 0.0.0.0/0 /* generated for LXD network lxdfan1 */
12 4044 ACCEPT all -- * lxdfan0 0.0.0.0/0 0.0.0.0/0 /* generated for LXD network lxdfan0 */
12 1411 ACCEPT all -- lxdfan0 * 0.0.0.0/0 0.0.0.0/0 /* generated for LXD network lxdfan0 */
Chain OUTPUT (policy ACCEPT 93036 packets, 13M bytes)
0 0 ACCEPT tcp -- * lxdfan1 0.0.0.0/0 0.0.0.0/0 tcp spt:53 /* generated for LXD network lxdfan1 */
3 237 ACCEPT udp -- * lxdfan1 0.0.0.0/0 0.0.0.0/0 udp spt:53 /* generated for LXD network lxdfan1 */
1 329 ACCEPT udp -- * lxdfan1 0.0.0.0/0 0.0.0.0/0 udp spt:67 /* generated for LXD network lxdfan1 */
0 0 ACCEPT tcp -- * lxdfan0 0.0.0.0/0 0.0.0.0/0 tcp spt:53 /* generated for LXD network lxdfan0 */
3 237 ACCEPT udp -- * lxdfan0 0.0.0.0/0 0.0.0.0/0 udp spt:53 /* generated for LXD network lxdfan0 */
2 658 ACCEPT udp -- * lxdfan0 0.0.0.0/0 0.0.0.0/0 udp spt:67 /* generated for LXD network lxdfan0 */
So, I am a bit confused because I really don’t know what’s the best way do to that.
If you have any ideas…
Cheers
