I installed lxd --channel 4.0/stable, and i have 2 containers:
ng-tst (with nginx and php-fpm)
db (with mariadb)
From windows i can ssh into both.
With dbeaver i can connect to db and create databases and look at global variables:
bind-address = 0.0.0.0
port = 3306
The 2 containers can ping each other.
But when a php script in ng-tst wants to make a pdo connection with db, i get:
SQLSTATE[HY000] [2006] MySQL server has gone away
I tried with host=ip and host=db.lxd, but same result.
I don’t know where to look, any pointers would be very welcome.
stgraber
(Stéphane Graber)
August 14, 2020, 7:01pm
2
Maybe confirm that you can ping db from ng-tst and if you can, try connecting to mariadb using the command line client from ng-tst to isolate things a bit.
Ping: works
mysql -u main3 -h 10.33.183.47 -p
ERROR 1045 (28000): Access denied for user ‘main3’@‘ng-tst.lxd’ (using password: YES):
The user is defined as ‘main3’@’%’
Sorry, connection was ok, i used a wrong password.
So i suppose it is rather a php problem, and not a lxc problem.
Everything is ok now.
The problem was me, a mix-up of passwords.
Sorry to have bothered you.
stgraber
(Stéphane Graber)
August 14, 2020, 8:37pm
6
Ah, good that it was a simple problem
