No-no, that’s a problem on btrfs level. Something is wrong with your loop device. Let me think about possible ways to recover from that.
Sure, thanks
But inside the container it still shows that 45GB of disk space is left.
where have you seen that? df -h
/ lsblk
? Couldn’t you show output from that thing?
Inside the container:
df -h:
/dev/loop27 1.1T 1.1T 45G 96% /
none 492K 4.0K 488K 1% /dev
udev 63G 0 63G 0% /dev/fuse
tmpfs 100K 0 100K 0% /dev/lxd
/dev/nvme0n1p2 1.9T 1.5T 272G 85% /dev/nvidia2
tmpfs 100K 0 100K 0% /dev/.lxd-mounts
tmpfs 63G 0 63G 0% /dev/shm
tmpfs 13G 132K 13G 1% /run
tmpfs 63G 0 63G 0% /sys/fs/cgroup
lsblk:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
loop0 7:0 0 2.5M 1 loop
loop1 7:1 0 49.7M 1 loop
loop2 7:2 0 70.4M 1 loop
loop3 7:3 0 4K 1 loop
loop4 7:4 0 414.4M 1 loop
loop5 7:5 0 704K 1 loop
loop6 7:6 0 55.6M 1 loop
loop7 7:7 0 476K 1 loop
loop8 7:8 0 696K 1 loop
loop9 7:9 0 72.8M 1 loop
loop10 7:10 0 346.3M 1 loop
loop11 7:11 0 2.6M 1 loop
loop12 7:12 0 219M 1 loop
loop13 7:13 0 81.3M 1 loop
loop14 7:14 0 55.6M 1 loop
loop15 7:15 0 446.3M 1 loop
loop16 7:16 0 63.2M 1 loop
loop17 7:17 0 219M 1 loop
loop18 7:18 0 63.2M 1 loop
loop19 7:19 0 2.6M 1 loop
loop20 7:20 0 48M 1 loop
loop21 7:21 0 136.7M 1 loop
loop22 7:22 0 346.3M 1 loop
loop23 7:23 0 1.5M 1 loop
loop24 7:24 0 136.5M 1 loop
loop25 7:25 0 91.7M 1 loop
loop26 7:26 0 556K 1 loop
loop27 7:27 0 1.1T 0 loop /snap
loop28 7:28 0 139.7G 0 loop
sda 8:0 0 931.5G 0 disk
├─sda1 8:1 0 512M 0 part
└─sda2 8:2 0 931G 0 part
nvme0n1 259:0 0 1.9T 0 disk
├─nvme0n1p1 259:1 0 512M 0 part
└─nvme0n1p2 259:2 0 1.9T 0 part /dev/nvidia3
Thats about right 1.05TiB-1.00TiB is approx 45GB.
Perhaps its not full and its nothing to do with it, but its certainly very close, and may not be a coincidence.
I also thought if that could be an issue and tried increasing the volume size further but couldn’t do as it said it is a read only filesystem… Although I feel 45GB is a decent space.
Well now its corrupted you won’t be able to do anything with it unless BTRFS tooling allows it to be fixed. Otherwise it will need to be wiped and then the instances re-imported from backup.
As its read only, you could try stopping the instances and doing lxc export <instance> <file>
and then try reimporting them into a new pool.
I would suggest doing this anyway, in case any repair step you take make things worse.
A search for btrfs_free_extent show people in similar situations,
For future: IMHO, loop device is not a best way to store 1TB volumes. It’s better to use the btrfs shared with the host or on a separate device. It’s really hard to manage so big raw images.
You need to stop all containers which are using this loop device. Then perform (on host):
# IMPORTANT!!!
# stop all containers which are using loop device
# make BACKUP of your image or valuable data. Because recovery attempt may end up with data loss.
#create loop device on the host
losetup -L -f --show /var/snap/lxd/common/lxd/disks/vol-ce9e2a76-8b0c-437b-81d4-4c4f47f147e7.img
# then try /dev/loopN from output of previous command
# this will only check filesystem without modification
btrfs check /dev/loopN
# this will try repair. REALLY dangerous! Data loss is possible!
btrfs check --repair -p /dev/loopN
# detach device and then try to start the container
losetup -d /dev/loopN
Ohk. Is there any other way to recover from current state? As I would not be able to export as there isn’t enough storage on the system to keep both container data and exported file.
Also, is there any way to avoid this in future? This is not the first time I am facing this… Does ZFS offer a superior solution compared to BTRFS for LXD containers?
And again. Just to be on the safe side. @genesis96839, make backup of all valuable data before trying recovering btrfs. And… good luck (-:
Thanks. Let me try this.
Yes, I’ve transferred most of the data on a secondary disk for now. Will try these commands now.
BTRFS isn’t well known for its reliability sadly.
I tried the commands after stopping the container but received errors:
Response:
losetup: /var/snap/lxd/common/lxd/disks/vol-ce9e2a76-8b0c-437b-81d4-4c4f47f147e7.img: failed to re-use loop device
sudo btrfs check /dev/loop27
Response:
ERROR: cannot open device '/dev/loop27': Device or resource busy
ERROR: cannot open file system
sudo btrfs check --repair -p /dev/loop27
Response:
So would you recommend zfs next time in container deployment?
As an update:
This worked!! Wow I was not expecting this to get resolved. Thank you so much
I had stopped the container but the loop device was still in use. So to make it work, I stopped snap lxd deamon. Then it got detached and I was able to run these commands.
It did delete 2GB of data and I am not sure it went from which folder. But anyways it recovered 99% of the container.
Thanks again!
@stgraber has made a whole series of videos covering the pros and cons of each of the storage drivers that LXD supports:
