Hi guys!
On one of my servers I’ve observed an issue with LXD service twice. The processes get hung up for some reason inside the container and then if I try reboot from within the container or stop/start from server, the container just hangs.
LXC stop command is hung up for a while with no response on the terminal… I ended up rebooting the server to resolve this but I need a solution to resolve this permanently. Kindly help.
Server configuration:
OS: Ubuntu 18.04
LXD version: 4.21 (installed with snap)
Update:
I ran the following command to see the logs:
sudo cat /var/snap/lxd/common/lxd/logs/lxd.log
Observed this error log:
t=2022-01-05T17:21:21+0000 lvl=eror msg=“Error calling 'lxd forknet” err=“Failed to run: /snap/lxd/current/bin/lxd forknet info – 3865 -1: Failed setns to container network namespace: No such file or directory” instance=q457c0cc5109a instanceType=container pid=3865 project=default
Any suggestions on what this error message indicates?
Lxc container show log info gave the following information:
lxc info --show-log 457c0cc5109a
Status: RUNNING
Type: container
PID: 3865
Created: 2021/12/14 07:23 UTC
Last Used: 2022/01/05 05:44 UTCResources:
Processes: 20
CPU usage:
CPU usage (in seconds): 131261
Memory usage:
Memory (current): 35.57GiB
Memory (peak): 63.33GiBLog:
lxc q457c0cc5109a 20220105054408.345 ERROR utils - utils.c:lxc_can_use_pidfd:1774 - Kernel does not support pidfds
lxc q457c0cc5109a 20220105054408.409 ERROR conf - conf.c:turn_into_dependent_mounts:3906 - No such file or directory - Failed to recursively turn old root mount tree into dependent mount. Continuing…
