Good Morning, i have been having this issue for a little while now. cannot find the solution, i am running ubuntu 18.04 container on my main host and then installing snaplxd on the container but have no tab auto complete, i didint think much of it but when i went ahead and launched a container(ubuntu 18.04) i could not get the container to start any ideas?
You have two questions here,
How do I enable nested container in LXD?
The answer is that you need to enable nested container support in the specific container. See https://blog.ubuntu.com/2015/10/30/nested-containers-in-lxd on how to do that on a new container or how to reconfigure an existing container to accepted nested containers. -
How do I enable LXD Bash shell completion?
It is already enabled for the Bash shell in/usr/share/bash-completion/completions/lxc
and/usr/share/bash-completion/completions/lxd.lxc
. When you launch a new container with Ubuntu 18.04, you get by default the deb package of LXD, and it comes with Bash completion for thelxc
command.
But what happens if yousudo apt remove --purge lxd lxd-client
and install the snap package of LXD?
The snap package installs the required Bash completion for LXD.ubuntu@complete:~$ ls -l /usr/share/bash-completion/completions/lxd.lxc lrwxrwxrwx 1 root root 44 Nov 6 14:28 /usr/share/bash-completion/completions/lxd.lxc -> /snap/core/current/usr/lib/snapd/complete.sh ubuntu@complete:~$
You need to start a fresh Bash shell if you just installed LXD. Or, run
source /etc/bash_completion
so that the current shell works as well.
Thank you!! Very well explained !
