Hello All,
I’ve just tried upgrading my LXD (running as a snap on Ubuntu 24.04.3LTS) from 4.0/stable to 6/stable. Unfortunately, LXD is now failing to start. journalctl -u snap.lxd.daemon -f shows that LXD is repeatedly trying and failing to start, with errors of the following nature:
Oct 04 10:08:58 ruby lxd.daemon[166672]: => Starting LXD
Oct 04 10:08:58 ruby lxd.daemon[167568]: time="2025-10-04T10:08:58Z" level=warning msg=" - Couldn't find the CGroup network priority controller, per-instance network priority will be ignored. Please use per-device limits.priority instead"
Oct 04 10:09:00 ruby lxd.daemon[167568]: time="2025-10-04T10:09:00Z" level=error msg="Failed starting daemon" err="Failed applying patch \"storage_missing_snapshot_records\": Failed applying patch to pool \"default\": Error inserting volume \"btrbk/btrbk_2021-08-01\" for project \"default\" in pool \"default\" of type \"containers\" into database \"Failed creating volume snapshot record: UNIQUE constraint failed: storage_volumes_snapshots.storage_volume_id, storage_volumes_snapshots.name\""
Oct 04 10:09:01 ruby lxd.daemon[167568]: time="2025-10-04T10:09:01Z" level=warning msg="Dqlite last entry" index=0 term=0
Oct 04 10:09:01 ruby lxd.daemon[167568]: Error: Failed applying patch "storage_missing_snapshot_records": Failed applying patch to pool "default": Error inserting volume "btrbk/btrbk_2021-08-01" for project "default" in pool "default" of type "containers" into database "Failed creating volume snapshot record: UNIQUE constraint failed: storage_volumes_snapshots.storage_volume_id, storage_volumes_snapshots.name"
Oct 04 10:09:01 ruby lxd.daemon[166672]: Killed
Oct 04 10:09:01 ruby lxd.daemon[166672]: => LXD failed to start
So it looks like there’s an issue with some of the container snapshots I have running. Downgrading to 4.0/stable also no longer works. Can anyone suggest how I can fix the situation?
Regards,
Chris
