After reboot, LXD fails to start with following journal entries:
-- Reboot --
Okt 02 12:45:39 cirrus systemd[1]: Starting LXD - main daemon...
Okt 02 12:45:40 cirrus lxd[3852]: lvl=warn msg="CGroup memory swap accounting is disabled, swap limits will be ignored." t=2018-10-02T12:45:
Okt 02 12:45:40 cirrus lxd[3852]: panic: log not found
Okt 02 12:45:40 cirrus lxd[3852]: goroutine 1 [running]:
Okt 02 12:45:40 cirrus lxd[3852]: github.com/hashicorp/raft.NewRaft(0xc420032360, 0x11278e0, 0xc42030b060, 0x112fd20, 0xc42030ae60, 0x112c9e
Okt 02 12:45:40 cirrus lxd[3852]: /build/lxd-0FDBXp/lxd-3.0.1/obj-x86_64-linux-gnu/src/github.com/hashicorp/raft/api.go:491 +0x11ba
Okt 02 12:45:40 cirrus lxd[3852]: github.com/lxc/lxd/lxd/cluster.raftInstanceInit(0xc42030a220, 0xc42030ad00, 0xc4202f7ea0, 0x40080000000000
Okt 02 12:45:40 cirrus lxd[3852]: /build/lxd-0FDBXp/lxd-3.0.1/obj-x86_64-linux-gnu/src/github.com/lxc/lxd/lxd/cluster/raft.go:190 +0
Okt 02 12:45:40 cirrus lxd[3852]: github.com/lxc/lxd/lxd/cluster.newRaft(0xc42030a220, 0xc4202f7ea0, 0x4008000000000000, 0x0, 0x0, 0x40d606)
Okt 02 12:45:40 cirrus lxd[3852]: /build/lxd-0FDBXp/lxd-3.0.1/obj-x86_64-linux-gnu/src/github.com/lxc/lxd/lxd/cluster/raft.go:71 +0x
Okt 02 12:45:40 cirrus lxd[3852]: github.com/lxc/lxd/lxd/cluster.(*Gateway).init(0xc42033a3c0, 0xc42033a3c0, 0xc420038e40)
Okt 02 12:45:40 cirrus lxd[3852]: /build/lxd-0FDBXp/lxd-3.0.1/obj-x86_64-linux-gnu/src/github.com/lxc/lxd/lxd/cluster/gateway.go:403
Okt 02 12:45:40 cirrus lxd[3852]: github.com/lxc/lxd/lxd/cluster.NewGateway(0xc42030a220, 0xc4202f7ea0, 0xc4202b76c0, 0x2, 0x2, 0xc42003a500
Okt 02 12:45:40 cirrus lxd[3852]: /build/lxd-0FDBXp/lxd-3.0.1/obj-x86_64-linux-gnu/src/github.com/lxc/lxd/lxd/cluster/gateway.go:54
Okt 02 12:45:40 cirrus lxd[3852]: main.(*Daemon).init(0xc4202d8270, 0xc4202b78d8, 0x40d606)
Okt 02 12:45:40 cirrus lxd[3852]: /build/lxd-0FDBXp/lxd-3.0.1/obj-x86_64-linux-gnu/src/github.com/lxc/lxd/lxd/daemon.go:416 +0x4a8
Okt 02 12:45:40 cirrus lxd[3852]: main.(*Daemon).Init(0xc4202d8270, 0xc4202d8270, 0xc420038960)
Okt 02 12:45:40 cirrus lxd[3852]: /build/lxd-0FDBXp/lxd-3.0.1/obj-x86_64-linux-gnu/src/github.com/lxc/lxd/lxd/daemon.go:355 +0x2f
Okt 02 12:45:40 cirrus lxd[3852]: main.(*cmdDaemon).Run(0xc420031600, 0xc4202cc000, 0xc4202a6960, 0x0, 0x3, 0x0, 0x0)
Okt 02 12:45:40 cirrus lxd[3852]: /build/lxd-0FDBXp/lxd-3.0.1/obj-x86_64-linux-gnu/src/github.com/lxc/lxd/lxd/main_daemon.go:82 +0x3
Okt 02 12:45:40 cirrus lxd[3852]: main.(*cmdDaemon).Run-fm(0xc4202cc000, 0xc4202a6960, 0x0, 0x3, 0x0, 0x0)
Okt 02 12:45:40 cirrus lxd[3852]: /build/lxd-0FDBXp/lxd-3.0.1/obj-x86_64-linux-gnu/src/github.com/lxc/lxd/lxd/main_daemon.go:42 +0x5
Okt 02 12:45:40 cirrus lxd[3852]: github.com/spf13/cobra.(*Command).execute(0xc4202cc000, 0xc4200c0050, 0x3, 0x3, 0xc4202cc000, 0xc4200c0050
Okt 02 12:45:40 cirrus lxd[3852]: /build/lxd-0FDBXp/lxd-3.0.1/obj-x86_64-linux-gnu/src/github.com/spf13/cobra/command.go:762 +0x468
Okt 02 12:45:40 cirrus lxd[3852]: github.com/spf13/cobra.(*Command).ExecuteC(0xc4202cc000, 0x0, 0xc4202d6500, 0xc4202d6500)
Okt 02 12:45:40 cirrus lxd[3852]: /build/lxd-0FDBXp/lxd-3.0.1/obj-x86_64-linux-gnu/src/github.com/spf13/cobra/command.go:852 +0x30a
Okt 02 12:45:40 cirrus lxd[3852]: github.com/spf13/cobra.(*Command).Execute(0xc4202cc000, 0xc4202b7e08, 0x1)
Okt 02 12:45:40 cirrus lxd[3852]: /build/lxd-0FDBXp/lxd-3.0.1/obj-x86_64-linux-gnu/src/github.com/spf13/cobra/command.go:800 +0x2b
Okt 02 12:45:40 cirrus lxd[3852]: main.main()
Okt 02 12:45:40 cirrus lxd[3852]: /build/lxd-0FDBXp/lxd-3.0.1/obj-x86_64-linux-gnu/src/github.com/lxc/lxd/lxd/main.go:159 +0xdca
Okt 02 12:45:40 cirrus systemd[1]: lxd.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Okt 02 12:50:14 cirrus systemd[1]: lxd.service: Failed with result 'exit-code'.
Okt 02 12:50:14 cirrus systemd[1]: Stopped LXD - main daemon.
Last time LXD failed to startup, was right last week after my hard-drive ran full. I came across a thread somewhere in the internet (github?), which suggested to delete the db file /var/lib/lxd/database/global/logs.db. I did that, afterwards lxd started. After that there was no reboot, until now.
Which log is meant by panic: log not found?
Update: After repeating the step from last time (removing logs.db), LXD started again, also after reboot. What is logs.db about, how can have a look at it?
Update 2: I’m now back at the state from the moment my hard-disk went full. Which is bad, since I moved my container to a zfs pool since then.
