I have a small VPS with one external IPv4 address (ext_ip1) and would like to forward external ports to several instances. In order to use ACLs between these instances, I am using a separate (non-OVN) network brige for each container, which roughly looks as follows -
lxc list
| NAME | TYPE | MANAGED | IPV4 | |
| c1 | bridge | YES | 10.10.102.102 (eth0) | |
| c2 | bridge | YES | 10.10.101.101 (eth0) | |
| c3 | bridge | YES | 10.10.100.100 (eth0) | |
lxc network list
| n1 | bridge | YES | 10.10.102.1/24 | |
| n2 | bridge | YES | 10.10.101.1/24 | |
| n3 | bridge | YES | 10.10.100.1/24 | |
I can easily create a forward to one bridge / instance using lxd like this:
lxc network forward create n1 ext_ip1
Network forward ext1 created
… however, using the command for another network results in the following error:
lxc network forward create n2 ext_ip1
Error: Failed creating forward: Forward listen address "ext_ip1/32" overlaps with another network or NIC
This is probably intentional as the docs state that for regular bridge networks “any non-conflicting listen address is allowed”. It would be quite useful to be able to assign the the same external address to multiple bridge networks and define port forwardings for the instance(s) attached to them though; assuming that different ports are assigned to each bridge / instance of course.
There are several other ways to solve this - I could manually setup some netfilter rules (but I’d rather configure everything using LXD), could attach all the containers to the same bridge (ACL rules won’t work between instances) or switch to an OVN network (which seems overkill for a single host). In short: If possible, I’d rather stick with my current setup -
Which leads to the question: Is forwarding one external IP address to multiple bridges at all possible or is one of the other approaches necessary? Am I perhaps overlooking something else?
