There was a brief mention of work on the LXD GUI in one of the recent release videos and of course there is the git to follow. It seems like you’ll be launching something in the next few months. I’ve had a hunt around and I’m not quite clear what the overall project aims to deliver and what features are your MVP?
Perhaps it would also be interesting for users to feedback on the progress at some point without having to install the whole dev environment to run it. Would you consider building a trial instance the same way you can try out LXD itself and solicit some feedback if you’d find that beneficial?
