Ubuntu 18.04 from apt, lxd version 3.0.3
TL/DR Update:
Just tested on virtualbox on new ubuntu installation and 3.0.3 with single cluster node, no weird mounts nothing, everything defaults except cluster=yes and lxc copy does full copy, and doesnt use btrfs snapshoting features.
Thats “killer” bug?feature?(i guess it works as intended) right here and in here Under Maintenance……. — lxd latest documentation it doesnt even mention that, I dont know any technical details why cluster works this way, but at least with btrfs driver there is just no point in using clustered mode at all as it works as with “dir” driver.
Hello, I made lxd cluster from two machines with btrfs. Now realised that “lxc copy xx xx2” does full copy (on same storage pool), it show transfer speeds like I would transfer to some remote. Lxc snapshot works fine.
I checked with
btrfs subvolume show xx ; btrfs subvolume show xx2
on test machine with default(no cluster) configuration and parent UUID matches just fine, but on clustered machine btrfs subvolume UUIDS doesnt match.
Clustered lxd actually uses “btrfs send” commands
Problem is I dont even know if this is normal lxd behavior (doubt it) or my configuration is fundamentally wrong or its a bug, sadly systems went semi “live”, I was about to add more machines to cluster. If you need any more info I can provide.
Info about storage
root@cluster-linux: lxc storage show ssd
config: {}
driver: btrfs
- /1.0/containers/salt-del
- /1.0/images/6700bee14eb3034ba4bd0c3d0165f938faa161d2690e919465aab2946490689b
- /1.0/profiles/default
- /1.0/profiles/disable_internet
status: Created
locations:
- cluster-linux
- dragon-ball-radar
root@cluster-linux: lxc storage show hdd
config: {}
driver: btrfs
- /1.0/containers/wiki
- /1.0/containers/zabbix
- /1.0/profiles/default_hdd
status: Created
locations:
- cluster-linux
- dragon-ball-radar
FSTAB
There is two two storages "ssd" and "hdd"
/ is on hdd
UUID=SSD /var/lib/lxd btrfs relatime,subvol=@var-lxd
UUID=HDD /var/lib/lxd/storage-pools/hdd btrfs relatime,subvol=@hdd-lxd
/var/lib/
