Objective: Have an IPv6 address on the container that does not change so that I can have stable proxy devices.
Subobjective: Set a static IPv6 address on a container.
I have a host with the following bridge configuration:
$ lxc network show lxdbr0
ipv4.address: 10.248.30.1/24
ipv4.nat: "true"
ipv6.address: fd42:8c31:4e11:e52b::1/64
ipv6.dhcp.stateful: "true"
ipv6.nat: "true"
type: bridge
- /1.0/instances/serv
- /1.0/profiles/default
managed: true
status: Created
locations:
- none
$ ip a show dev lxdbr0
3: lxdbr0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:63:58:65 brd ff:ff:ff:ff:ff:ff
inet 10.248.30.1/24 scope global lxdbr0
inet6 fd42:8c31:4e11:e52b::1/64 scope global
inet6 fe80::216:3eff:fe63:5865/64 scope link
$ lxc list
| serv | RUNNING | 10.248.30.20 (eth0) | fd42:8c31:4e11:e52b:d5a4:53b9:52a:aabb (eth0) | CONTAINER | 2 |
When I try to add an address to the container, however, I get an error message:
$ lxc config device set serv eth0 ipv6.address=[fd42:8c31:4e11:e52b::10]
Error: Invalid devices: Device validation failed for "eth0": Device IP address "[fd42:8c31:4e11:e52b::10]" not within network "lxdbr0" subnet
This doesn’t make sense to me. Checks with third-party networking tools confirm that the address fd42:8c31:4e11:e52b::10
is clearly within the lxdbr0 subnet, the lxdbr0 interface address is fd42:8c31:4e11:e52b::1/64
and the prefix address is fd42:8c31:4e11:e52b::
. Is there something wrong with my syntax? Am I using the wrong network or address type? What else might I have missed?
