Some days (or weeks) ago LXD stopped giving out ipv6 addresses. This affected both my production and development servers:
ns pts/0#lxc list [/home/rm 23:55 Fri 7]
| alp | RUNNING | 172.16.172.116 (eth0) | | CONTAINER | 0 |
| cms | RUNNING | 172.16.172.218 (eth0) | | CONTAINER | 0 |
| dd | RUNNING | 172.16.172.47 (eth0) | | CONTAINER | 0 |
| grr | RUNNING | 172.16.172.113 (eth0) | | CONTAINER | 0 |
| main | RUNNING | 172.16.172.233 (eth0) | | CONTAINER | 0 |
| static | RUNNING | 172.16.172.57 (eth0) | | CONTAINER | 0 |
ns pts/0#lxc network show lxdbr0
ipv4.address: 172.16.172.1/24
ipv4.nat: "true"
ipv6.address: fd42:dad8:c4ad:e744::1/64
ipv6.dhcp.stateful: "true"
ipv6.nat: "true"
type: bridge
- /1.0/instances/alp
- /1.0/instances/cms
- /1.0/instances/dd
- /1.0/instances/grr
- /1.0/instances/main
- /1.0/instances/static
- /1.0/profiles/default
managed: true
status: Created
locations:
- none
dnsmasq is still running:
lxd 1127 0.0 0.1 43632 1836 ? Ss Aug07 0:01 dnsmasq --keep-in-foreground --strict-order --bind-interfaces --except-interface=lo --pid-file= --no-ping --interface=lxdbr0 --quiet-dhcp --quiet-dhcp6 --quiet-ra --listen-address=172.16.172.1 --dhcp-no-override --dhcp-authoritative --dhcp-leasefile=/var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.leases --dhcp-hostsfile=/var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts --dhcp-range 172.16.172.2,172.16.172.254,1h --listen-address=fd42:dad8:c4ad:e744::1 --enable-ra --dhcp-range fd42:dad8:c4ad:e744::2,fd42:dad8:c4ad:e744:ffff:ffff:ffff:ffff,64,1h -s lxd -S /lxd/ --conf-file=/var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.raw -u lxd
One of the containers:
ns pts/0#lxc config show alp --expanded
image.architecture: amd64
image.description: Alpine 3.9 amd64 (20190321_13:00)
image.os: Alpine
image.release: "3.9"
image.serial: "20190321_13:00"
volatile.base_image: 0cbd911b5a203c7e475241b8b22cc5332d10fd30ae27916bae1558bcb118c9ce
volatile.eth0.host_name: veth561c9ec6
volatile.eth0.hwaddr: 00:16:3e:6b:04:12
volatile.idmap.base: "0"
volatile.last_state.idmap: '[{"Isuid":true,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000000000}]'
ipv4.address: 172.16.172.116
nictype: bridged
parent: lxdbr0
path: / [/home/rm 0:07 Sat 8]
pool: tank
Any ideas where to look for the source of the problem? I did not do anything with both servers during last weeks, the only thing that changed was snap updated lxd to 4.4…
