Apologies for the tone, thanks for the explanation. Will keep your explanation in mind when eventually implementing it
This looks good to me, thanks!
@tomp @sdeziel example output:
2022-01-27T00:01:51Z|proto=tcp, src=141.98.10.63, dst=45.45.148.3, src_port=34749, dst_port=22, action=reject
2022-01-27T00:05:29Z|proto=tcp, src=89.248.163.173, dst=45.45.148.3, src_port=41927, dst_port=22, action=reject
2022-01-27T00:20:06Z|proto=tcp, src=104.244.74.253, dst=45.45.148.3, src_port=39264, dst_port=22, action=reject
2022-01-27T00:21:52Z|proto=tcp, src=68.185.134.97, dst=45.45.148.3, src_port=53806, dst_port=22, action=reject
2022-01-27T00:23:29Z|proto=tcp, src=45.141.84.10, dst=45.45.148.3, src_port=13393, dst_port=22, action=reject
2022-01-27T00:33:26Z|proto=tcp, src=222.186.180.130, dst=45.45.148.3, src_port=9090, dst_port=22, action=reject
2022-01-27T00:40:08Z|proto=tcp, src=46.101.25.187, dst=45.45.148.3, src_port=50203, dst_port=22, action=reject
2022-01-27T00:55:34Z|proto=tcp, src=222.186.42.7, dst=45.45.148.3, src_port=9090, dst_port=22, action=reject
2022-01-27T01:04:56Z|proto=tcp, src=65.49.20.89, dst=45.45.148.3, src_port=39920, dst_port=22, action=reject
2022-01-27T01:10:23Z|proto=tcp, src=141.98.10.63, dst=45.45.148.3, src_port=38526, dst_port=22, action=reject
2022-01-27T01:31:53Z|proto=tcp, src=141.98.10.63, dst=45.45.148.3, src_port=34183, dst_port=22, action=reject
2022-01-27T01:32:23Z|proto=tcp, src=107.189.12.34, dst=45.45.148.3, src_port=51762, dst_port=22, action=reject
2022-01-27T01:43:14Z|proto=tcp, src=207.244.233.167, dst=45.45.148.3, src_port=43343, dst_port=22, action=reject
2022-01-27T02:15:06Z|proto=tcp, src=141.98.10.47, dst=45.45.148.3, src_port=43952, dst_port=22, action=reject
2022-01-27T02:29:12Z|proto=tcp, src=222.187.232.10, dst=45.45.148.3, src_port=9090, dst_port=22, action=reject
2022-01-27T02:31:42Z|proto=tcp, src=164.90.227.119, dst=45.45.148.3, src_port=37352, dst_port=22, action=reject
2022-01-27T02:34:35Z|proto=tcp, src=172.105.96.215, dst=45.45.148.3, src_port=41173, dst_port=22, action=reject
2022-01-27T02:36:53Z|proto=tcp, src=141.98.10.60, dst=45.45.148.3, src_port=48505, dst_port=22, action=reject
2022-01-27T02:45:37Z|proto=tcp, src=107.189.31.191, dst=45.45.148.3, src_port=22698, dst_port=22, action=reject
2022-01-27T03:11:40Z|proto=tcp, src=141.98.11.27, dst=45.45.148.3, src_port=52628, dst_port=22, action=reject
2022-01-27T03:39:29Z|proto=tcp, src=185.246.130.20, dst=45.45.148.3, src_port=20868, dst_port=22, action=reject
2022-01-27T03:40:24Z|proto=tcp, src=209.141.32.88, dst=45.45.148.3, src_port=41020, dst_port=22, action=reject
2022-01-27T03:53:29Z|proto=tcp, src=209.141.54.15, dst=45.45.148.3, src_port=2845, dst_port=22, action=reject
2022-01-27T04:02:36Z|proto=tcp, src=61.177.172.107, dst=45.45.148.3, src_port=45478, dst_port=22, action=reject
2022-01-27T04:17:29Z|proto=tcp, src=207.154.211.216, dst=45.45.148.3, src_port=49866, dst_port=22, action=reject
2022-01-27T04:32:56Z|proto=tcp, src=222.186.30.76, dst=45.45.148.3, src_port=9090, dst_port=22, action=reject
2022-01-27T04:36:06Z|proto=tcp, src=107.189.31.191, dst=45.45.148.3, src_port=3977, dst_port=22, action=reject
2022-01-27T04:38:25Z|proto=tcp, src=142.93.234.111, dst=45.45.148.3, src_port=51860, dst_port=22, action=reject
2022-01-27T05:02:50Z|proto=tcp, src=218.93.208.150, dst=45.45.148.3, src_port=9090, dst_port=22, action=reject
2022-01-27T05:16:17Z|proto=tcp, src=141.98.11.16, dst=45.45.148.3, src_port=49110, dst_port=22, action=reject
2022-01-27T05:17:50Z|proto=tcp, src=212.192.241.124, dst=45.45.148.3, src_port=44395, dst_port=22, action=reject
2022-01-27T05:17:57Z|proto=tcp, src=222.186.31.166, dst=45.45.148.3, src_port=9090, dst_port=22, action=reject
2022-01-27T05:27:19Z|proto=tcp, src=46.19.139.18, dst=45.45.148.3, src_port=35170, dst_port=22, action=reject
2022-01-27T05:58:47Z|proto=tcp, src=46.101.2.225, dst=45.45.148.3, src_port=61000, dst_port=22, action=reject
2022-01-27T05:59:55Z|proto=tcp, src=35.192.98.140, dst=45.45.148.3, src_port=9056, dst_port=22, action=reject
2022-01-27T06:11:53Z|proto=tcp, src=46.19.139.18, dst=45.45.148.3, src_port=47560, dst_port=22, action=reject
2022-01-27T06:19:32Z|proto=tcp, src=141.98.11.23, dst=45.45.148.3, src_port=39524, dst_port=22, action=reject
2022-01-27T06:20:29Z|proto=tcp, src=36.110.228.254, dst=45.45.148.3, src_port=34894, dst_port=22, action=reject
2022-01-27T06:22:13Z|proto=tcp, src=141.98.10.47, dst=45.45.148.3, src_port=33680, dst_port=22, action=reject
2022-01-27T06:40:33Z|proto=tcp, src=141.98.10.202, dst=45.45.148.3, src_port=57474, dst_port=22, action=reject
2022-01-27T06:45:12Z|proto=tcp, src=209.141.32.88, dst=45.45.148.3, src_port=35300, dst_port=22, action=reject
2022-01-27T06:52:04Z|proto=tcp, src=141.98.11.16, dst=45.45.148.3, src_port=34345, dst_port=22, action=reject
2022-01-27T07:01:01Z|proto=tcp, src=209.141.32.88, dst=45.45.148.3, src_port=39865, dst_port=22, action=reject
2022-01-27T07:05:22Z|proto=tcp, src=64.227.163.63, dst=45.45.148.3, src_port=57767, dst_port=22, action=reject
2022-01-27T07:07:31Z|proto=tcp, src=45.61.187.34, dst=45.45.148.3, src_port=2770, dst_port=22, action=reject
2022-01-27T07:10:29Z|proto=tcp, src=64.227.163.63, dst=45.45.148.3, src_port=56749, dst_port=22, action=reject
2022-01-27T07:21:49Z|proto=tcp, src=211.36.134.213, dst=45.45.148.3, src_port=37344, dst_port=22, action=reject
2022-01-27T07:32:34Z|proto=tcp, src=141.98.11.22, dst=45.45.148.3, src_port=36486, dst_port=22, action=reject
2022-01-27T07:36:25Z|proto=tcp, src=141.98.10.206, dst=45.45.148.3, src_port=36017, dst_port=22, action=reject
2022-01-27T07:36:48Z|proto=tcp, src=45.88.137.100, dst=45.45.148.3, src_port=11088, dst_port=22, action=reject
2022-01-27T07:37:43Z|proto=tcp6, src=2001:470:1:c84::e3, dst=2602:fc62:a:1::3, src_port=60003, dst_port=22, action=reject
2022-01-27T07:42:56Z|proto=tcp, src=121.40.150.147, dst=45.45.148.3, src_port=48409, dst_port=22, action=reject
2022-01-27T07:44:28Z|proto=tcp, src=117.119.79.107, dst=45.45.148.3, src_port=18442, dst_port=22, action=reject
2022-01-27T07:48:42Z|proto=tcp, src=205.185.120.164, dst=45.45.148.3, src_port=32380, dst_port=22, action=reject
2022-01-27T07:50:08Z|proto=tcp, src=89.248.163.173, dst=45.45.148.3, src_port=49776, dst_port=22, action=reject
2022-01-27T07:50:50Z|proto=tcp, src=221.131.165.65, dst=45.45.148.3, src_port=9090, dst_port=22, action=reject
2022-01-27T08:20:51Z|proto=tcp, src=92.63.197.94, dst=45.45.148.3, src_port=50641, dst_port=22, action=reject
2022-01-27T08:39:28Z|proto=tcp, src=222.186.42.7, dst=45.45.148.3, src_port=9090, dst_port=22, action=reject
2022-01-27T08:55:54Z|proto=tcp, src=222.186.180.130, dst=45.45.148.3, src_port=9090, dst_port=22, action=reject
2022-01-27T09:04:13Z|proto=tcp, src=39.153.143.55, dst=45.45.148.3, src_port=6849, dst_port=22, action=reject
2022-01-27T09:09:23Z|proto=tcp, src=45.129.56.151, dst=45.45.148.3, src_port=61000, dst_port=22, action=reject
2022-01-27T09:11:24Z|proto=tcp, src=141.98.10.47, dst=45.45.148.3, src_port=54355, dst_port=22, action=reject
2022-01-27T09:15:15Z|proto=tcp, src=141.98.10.63, dst=45.45.148.3, src_port=58961, dst_port=22, action=reject
2022-01-27T09:36:13Z|proto=tcp, src=141.98.11.23, dst=45.45.148.3, src_port=43202, dst_port=22, action=reject
2022-01-27T09:40:48Z|proto=tcp, src=45.88.137.253, dst=45.45.148.3, src_port=41478, dst_port=22, action=reject
2022-01-27T09:51:27Z|proto=tcp, src=107.189.29.142, dst=45.45.148.3, src_port=7856, dst_port=22, action=reject
2022-01-27T10:05:15Z|proto=tcp, src=192.241.213.80, dst=45.45.148.3, src_port=51805, dst_port=22, action=reject
2022-01-27T10:26:29Z|proto=tcp, src=141.98.10.63, dst=45.45.148.3, src_port=38865, dst_port=22, action=reject
2022-01-27T10:31:39Z|proto=tcp, src=222.187.232.10, dst=45.45.148.3, src_port=9090, dst_port=22, action=reject
2022-01-27T10:57:20Z|proto=tcp, src=164.90.156.240, dst=45.45.148.3, src_port=40954, dst_port=22, action=reject
2022-01-27T10:58:48Z|proto=tcp, src=198.23.149.111, dst=45.45.148.3, src_port=41204, dst_port=22, action=reject
2022-01-27T11:05:02Z|proto=tcp, src=167.248.133.21, dst=45.45.148.3, src_port=33895, dst_port=22, action=reject
2022-01-27T11:13:54Z|proto=tcp, src=141.98.10.63, dst=45.45.148.3, src_port=36319, dst_port=22, action=reject
2022-01-27T11:30:34Z|proto=tcp, src=167.172.189.205, dst=45.45.148.3, src_port=16500, dst_port=22, action=reject
2022-01-27T11:40:35Z|proto=tcp, src=89.248.173.131, dst=45.45.148.3, src_port=43503, dst_port=22, action=reject
2022-01-27T11:43:57Z|proto=tcp, src=46.101.178.37, dst=45.45.148.3, src_port=1966, dst_port=22, action=reject
2022-01-27T11:46:15Z|proto=tcp, src=141.98.10.63, dst=45.45.148.3, src_port=44375, dst_port=22, action=reject
2022-01-27T12:02:30Z|proto=tcp, src=89.248.163.173, dst=45.45.148.3, src_port=44926, dst_port=22, action=reject
2022-01-27T12:03:12Z|proto=tcp, src=141.98.10.47, dst=45.45.148.3, src_port=38931, dst_port=22, action=reject
2022-01-27T12:40:45Z|proto=tcp, src=222.186.30.76, dst=45.45.148.3, src_port=9090, dst_port=22, action=reject
2022-01-27T12:43:01Z|proto=tcp, src=217.93.243.47, dst=45.45.148.3, src_port=59870, dst_port=22, action=reject
2022-01-27T12:46:55Z|proto=tcp, src=218.93.208.150, dst=45.45.148.3, src_port=9090, dst_port=22, action=reject
2022-01-27T13:38:55Z|proto=tcp, src=222.186.31.166, dst=45.45.148.3, src_port=9090, dst_port=22, action=reject
2022-01-27T14:08:35Z|proto=tcp, src=141.98.10.60, dst=45.45.148.3, src_port=49879, dst_port=22, action=reject
2022-01-27T14:23:32Z|proto=tcp, src=45.94.0.53, dst=45.45.148.3, src_port=49696, dst_port=22, action=reject
2022-01-27T14:25:46Z|proto=tcp, src=193.3.19.178, dst=45.45.148.3, src_port=61000, dst_port=22, action=reject
2022-01-27T14:46:33Z|proto=tcp, src=141.98.10.82, dst=45.45.148.3, src_port=49909, dst_port=22, action=reject
2022-01-27T15:24:24Z|proto=tcp, src=141.98.11.16, dst=45.45.148.3, src_port=33193, dst_port=22, action=reject
2022-01-27T15:40:16Z|proto=tcp, src=192.241.211.201, dst=45.45.148.3, src_port=41783, dst_port=22, action=reject
2022-01-27T15:45:46Z|proto=tcp, src=221.131.165.65, dst=45.45.148.3, src_port=9090, dst_port=22, action=reject
2022-01-27T16:06:02Z|proto=tcp, src=141.98.10.63, dst=45.45.148.3, src_port=37131, dst_port=22, action=reject
2022-01-27T16:10:09Z|proto=tcp, src=138.199.32.100, dst=45.45.148.3, src_port=55464, dst_port=22, action=reject
2022-01-27T16:17:08Z|proto=tcp, src=212.192.241.124, dst=45.45.148.3, src_port=60419, dst_port=22, action=reject
2022-01-27T16:22:48Z|proto=tcp, src=222.186.42.7, dst=45.45.148.3, src_port=9090, dst_port=22, action=reject
2022-01-27T16:29:22Z|proto=tcp, src=141.98.11.16, dst=45.45.148.3, src_port=57879, dst_port=22, action=reject
2022-01-27T16:36:47Z|proto=tcp, src=141.98.11.16, dst=45.45.148.3, src_port=49515, dst_port=22, action=reject
2022-01-27T16:47:36Z|proto=tcp, src=46.19.139.18, dst=45.45.148.3, src_port=59288, dst_port=22, action=reject
2022-01-27T17:10:05Z|proto=tcp, src=219.146.152.154, dst=45.45.148.3, src_port=46527, dst_port=22, action=reject
2022-01-27T17:14:53Z|proto=tcp, src=178.73.215.171, dst=45.45.148.3, src_port=40117, dst_port=22, action=reject
2022-01-27T17:16:22Z|proto=tcp, src=46.19.139.18, dst=45.45.148.3, src_port=48886, dst_port=22, action=reject
2022-01-27T17:20:03Z|proto=tcp, src=222.186.180.130, dst=45.45.148.3, src_port=9090, dst_port=22, action=reject
2022-01-27T17:35:52Z|proto=tcp, src=89.248.173.131, dst=45.45.148.3, src_port=44887, dst_port=22, action=reject
2022-01-27T17:58:42Z|proto=tcp, src=45.88.137.100, dst=45.45.148.3, src_port=31550, dst_port=22, action=reject
2022-01-27T18:00:14Z|proto=tcp, src=141.98.10.47, dst=45.45.148.3, src_port=49525, dst_port=22, action=reject
2022-01-27T18:00:38Z|proto=tcp, src=205.185.120.140, dst=45.45.148.3, src_port=57087, dst_port=22, action=reject
2022-01-27T18:16:23Z|proto=tcp, src=141.98.11.16, dst=45.45.148.3, src_port=46170, dst_port=22, action=reject
2022-01-27T18:27:14Z|proto=tcp, src=62.8.79.2, dst=45.45.148.3, src_port=60000, dst_port=22, action=reject
2022-01-27T18:34:16Z|proto=tcp, src=222.187.232.10, dst=45.45.148.3, src_port=9090, dst_port=22, action=reject
2022-01-27T18:35:39Z|proto=tcp, src=164.90.156.240, dst=45.45.148.3, src_port=48533, dst_port=22, action=reject
2022-01-27T18:50:21Z|proto=tcp, src=85.209.0.186, dst=45.45.148.3, src_port=43024, dst_port=22, action=reject
2022-01-27T18:50:22Z|proto=tcp, src=85.209.0.186, dst=45.45.148.3, src_port=43024, dst_port=22, action=reject
2022-01-27T18:50:24Z|proto=tcp, src=85.209.0.186, dst=45.45.148.3, src_port=43024, dst_port=22, action=reject
2022-01-27T18:50:28Z|proto=tcp, src=85.209.0.186, dst=45.45.148.3, src_port=43024, dst_port=22, action=reject
2022-01-27T18:56:19Z|proto=tcp, src=141.98.11.16, dst=45.45.148.3, src_port=48959, dst_port=22, action=reject
2022-01-27T19:00:56Z|proto=tcp, src=141.98.11.22, dst=45.45.148.3, src_port=54577, dst_port=22, action=reject
2022-01-27T19:15:25Z|proto=tcp, src=46.19.139.18, dst=45.45.148.3, src_port=35562, dst_port=22, action=reject
2022-01-27T19:24:24Z|proto=tcp, src=183.201.193.63, dst=45.45.148.3, src_port=58914, dst_port=22, action=reject
2022-01-27T19:25:12Z|proto=tcp, src=46.19.139.18, dst=45.45.148.3, src_port=33099, dst_port=22, action=reject
2022-01-27T19:28:14Z|proto=tcp, src=104.244.79.120, dst=45.45.148.3, src_port=47220, dst_port=22, action=reject
2022-01-27T19:31:18Z|proto=tcp, src=141.98.11.27, dst=45.45.148.3, src_port=35867, dst_port=22, action=reject
2022-01-27T19:36:44Z|proto=tcp, src=89.248.163.173, dst=45.45.148.3, src_port=52162, dst_port=22, action=reject
2022-01-27T19:39:33Z|proto=tcp, src=141.98.10.63, dst=45.45.148.3, src_port=41229, dst_port=22, action=reject
2022-01-27T19:40:06Z|proto=tcp, src=164.90.227.119, dst=45.45.148.3, src_port=37707, dst_port=22, action=reject
2022-01-27T19:44:04Z|proto=tcp, src=61.177.172.107, dst=45.45.148.3, src_port=52779, dst_port=22, action=reject
2022-01-27T20:08:48Z|proto=tcp, src=141.98.10.63, dst=45.45.148.3, src_port=35711, dst_port=22, action=reject
2022-01-27T20:20:49Z|proto=tcp, src=104.129.8.135, dst=45.45.148.3, src_port=33128, dst_port=22, action=reject
2022-01-27T20:20:49Z|proto=tcp, src=34.138.157.247, dst=45.45.148.3, src_port=36362, dst_port=22, action=reject
2022-01-27T20:30:54Z|proto=tcp, src=218.93.208.150, dst=45.45.148.3, src_port=9090, dst_port=22, action=reject
2022-01-27T20:33:52Z|proto=tcp, src=85.221.160.242, dst=45.45.148.3, src_port=37065, dst_port=22, action=reject
2022-01-27T20:47:07Z|proto=tcp, src=76.177.197.140, dst=45.45.148.3, src_port=34299, dst_port=22, action=reject
2022-01-27T20:48:30Z|proto=tcp, src=222.186.30.76, dst=45.45.148.3, src_port=9090, dst_port=22, action=reject
2022-01-27T20:50:01Z|proto=tcp, src=180.97.83.146, dst=45.45.148.3, src_port=42594, dst_port=22, action=reject
2022-01-27T20:53:09Z|proto=tcp, src=141.98.10.202, dst=45.45.148.3, src_port=41752, dst_port=22, action=reject
2022-01-27T21:59:41Z|proto=tcp, src=222.186.31.166, dst=45.45.148.3, src_port=9090, dst_port=22, action=reject
2022-01-27T22:01:30Z|proto=tcp, src=69.163.82.74, dst=45.45.148.3, src_port=46325, dst_port=22, action=reject
2022-01-27T22:12:27Z|proto=tcp, src=141.98.11.16, dst=45.45.148.3, src_port=53722, dst_port=22, action=reject
2022-01-27T22:25:29Z|proto=tcp, src=141.98.10.60, dst=45.45.148.3, src_port=49165, dst_port=22, action=reject
2022-01-27T22:26:58Z|proto=tcp, src=141.98.10.47, dst=45.45.148.3, src_port=38069, dst_port=22, action=reject
2022-01-27T22:39:02Z|proto=tcp, src=45.88.137.253, dst=45.45.148.3, src_port=18498, dst_port=22, action=reject
2022-01-27T22:42:05Z|proto=tcp, src=141.98.11.22, dst=45.45.148.3, src_port=44319, dst_port=22, action=reject
2022-01-27T22:57:42Z|proto=tcp, src=124.79.245.13, dst=45.45.148.3, src_port=46678, dst_port=22, action=reject
2022-01-27T23:02:18Z|proto=tcp, src=49.88.112.109, dst=45.45.148.3, src_port=9090, dst_port=22, action=reject
2022-01-27T23:13:04Z|proto=tcp, src=141.98.10.63, dst=45.45.148.3, src_port=34825, dst_port=22, action=reject
2022-01-27T23:25:58Z|proto=tcp, src=141.98.11.16, dst=45.45.148.3, src_port=42361, dst_port=22, action=reject
2022-01-27T23:32:01Z|proto=tcp, src=141.98.11.23, dst=45.45.148.3, src_port=39385, dst_port=22, action=reject
2022-01-27T23:39:44Z|proto=tcp, src=89.248.163.173, dst=45.45.148.3, src_port=46783, dst_port=22, action=reject
2022-01-27T23:40:16Z|proto=tcp, src=221.131.165.65, dst=45.45.148.3, src_port=9090, dst_port=22, action=reject
2022-01-27T23:59:10Z|proto=tcp, src=31.7.57.130, dst=45.45.148.3, src_port=42311, dst_port=22, action=reject
Does that look readable enough?
The tcp6
caught my attention, I’m used to tcp
but maybe that’s a Go thing
When looking at Network ACL configuration - LXD documentation, I was reminded of icmp4
and icmp6
which require a slightly different treatment due to not using ports. Do you have an example output for ICMP?
It’s not a Go thing, it’s an OVN thing. I’m currently passing through the protocol as it’s logged by OVN.
For the source and destination ports, the fields are omitted when not present in the original log.
I’ll try an ICMP ACL to see what OVN will get us in this case.
