TLDR How do run a if-up type script on lxd managed bridges? I need to disable nic offloading.
I need to disable nic offloading features on all my bridges. In earlier lxd versions I used ifupdown to manually configure my bridges and disable offloading features in if-up. With latest lxd versions we want to manage the network configuration via “lxd network”. How would I run if-up type scripts to disable nic offloading on lxd managed networks? If there a config setting that can be applied maybe?
