Hello, i am seeking some help with my lxd container configurations. I am looking to have about 5 containers on the default private network that lxd creates and 1 container facing public ip with mac vlan but still having access to the default private containers. Is there anyway that would be possible to do?
i am trying to made a vpn client that is accessible from devices on the network and then delegate different logins to separate networks on the private side of lxd
Thanks
i previously posted this on the git hub page and received this response
“stgraber
In any case, I suspect the easiest way to do what you want here is to simply put two network interfaces on your container, one normally connected to your LXD bridge and the other a macvlan device attached to your public facing interface.”
i did wanna continue this conversation as to how i would be able to create a profile to allow me to do that, i have tried to use this profile
config: {}
description: “”
eth1:
nictype: bridged
parent: lxdbr0
nictype: macvlan
parent: eno1
pool: default
used_by: []
after adding that profile to a fresh new container i still only got a ip address from the private side and nothing from the macvlan side. i suppose im doing this wrong and would need a little guidance
Thanks.
