System
cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=16.04
DISTRIB_CODENAME=xenial
DISTRIB_DESCRIPTION="Ubuntu 16.04.4 LTS"
lxd --version
3.0.0
Init Parameters
$ sudo lxd init
Would you like to use LXD clustering? (yes/no) [default=no]:
Name of the storage backend to use (btrfs, ceph, dir, lvm, zfs) [default=zfs]: dir
Would you like to create a new local network bridge? (yes/no) [default=yes]:
What should the new bridge be called? [default=lxdbr0]:
What IPv4 address should be used? (CIDR subnet notation, “auto” or “none”) [default=auto]: auto
What IPv6 address should be used? (CIDR subnet notation, “auto” or “none”) [default=auto]: none
Would you like LXD to be available over the network? (yes/no) [default=no]:
Would you like stale cached images to be updated automatically? (yes/no) [default=yes]
Would you like a YAML "lxd init" preseed to be printed? (yes/no) [default=no]:
Behaviour
None of my LXD/LXC commands will run. They result in:
lxc list
LXD socket not found; is LXD installed and running?
Double checking Config
cat /etc/group | grep lxd
lxd:x:110:dustin
Running processes
dustin@lxd:~$ ps aux | grep lxd
root 1166 0.2 0.0 4504 1604 ? Ss 12:27 0:00 /bin/sh /snap/lxd/6862/commands/daemon.start
root 1448 0.0 0.0 95384 1396 ? Sl 12:27 0:00 lxcfs /var/snap/lxd/common/var/lib/lxcfs -p /var/snap/lxd/common/lxcfs.pid
root 1456 0.8 0.7 787164 30280 ? Sl 12:27 0:01 lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
dustin 1702 0.0 0.0 14224 1084 pts/0 S+ 12:29 0:00 grep --color=auto lxd
The daemon.start script looks odd to me. I would imagine that would go away once it started
Services
$ journalctl -u snap.lxd.daemon
-- Logs begin at Mon 2018-04-30 12:27:12 PDT, end at Mon 2018-04-30 12:36:15 PDT. --
Apr 30 12:27:19 lxd systemd[1]: Started Service for snap application lxd.daemon.
Apr 30 12:27:20 lxd lxd.daemon[1166]: => Preparing the system
Apr 30 12:27:20 lxd lxd.daemon[1166]: ==> Loading snap configuration
Apr 30 12:27:20 lxd lxd.daemon[1166]: ==> Setting up mntns symlink
Apr 30 12:27:20 lxd lxd.daemon[1166]: ==> Setting up kmod wrapper
Apr 30 12:27:20 lxd lxd.daemon[1166]: ==> Preparing /boot
Apr 30 12:27:20 lxd lxd.daemon[1166]: ==> Preparing a clean copy of /run
Apr 30 12:27:20 lxd lxd.daemon[1166]: ==> Preparing a clean copy of /etc
Apr 30 12:27:22 lxd lxd.daemon[1166]: ==> Setting up ceph configuration
Apr 30 12:27:22 lxd lxd.daemon[1166]: ==> Setting up LVM configuration
Apr 30 12:27:22 lxd lxd.daemon[1166]: ==> Rotating logs
Apr 30 12:27:22 lxd lxd.daemon[1166]: ==> Setting up ZFS (0.6)
Apr 30 12:27:22 lxd lxd.daemon[1166]: ==> Escaping the systemd cgroups
Apr 30 12:27:22 lxd lxd.daemon[1166]: ==> Escaping the systemd process resource limit
Apr 30 12:27:22 lxd lxd.daemon[1166]: ==> Increasing the number of inotify user insta
Apr 30 12:27:22 lxd lxd.daemon[1166]: => Starting LXCFS
Apr 30 12:27:22 lxd lxd.daemon[1166]: => Starting LXD
Apr 30 12:27:23 lxd lxd.daemon[1166]: mount namespace: 5
Apr 30 12:27:23 lxd lxd.daemon[1166]: hierarchies:
Apr 30 12:27:23 lxd lxd.daemon[1166]: 0: fd: 6: freezer
Apr 30 12:27:23 lxd lxd.daemon[1166]: 1: fd: 7: pids
Apr 30 12:27:23 lxd lxd.daemon[1166]: 2: fd: 8: perf_event
Apr 30 12:27:23 lxd lxd.daemon[1166]: 3: fd: 9: net_cls,net_prio
Apr 30 12:27:23 lxd lxd.daemon[1166]: 4: fd: 10: devices
Apr 30 12:27:23 lxd lxd.daemon[1166]: 5: fd: 11: memory
Apr 30 12:27:23 lxd lxd.daemon[1166]: 6: fd: 12: cpuset
Apr 30 12:27:23 lxd lxd.daemon[1166]: 7: fd: 13: blkio
Apr 30 12:27:23 lxd lxd.daemon[1166]: 8: fd: 14: cpu,cpuacct
Apr 30 12:27:23 lxd lxd.daemon[1166]: 9: fd: 15: hugetlb
Apr 30 12:27:23 lxd lxd.daemon[1166]: 10: fd: 16: name=systemd
Apr 30 12:27:24 lxd lxd.daemon[1166]: lvl=warn msg="CGroup memory swap accounting is
Apr 30 12:27:24 lxd lxd.daemon[1166]: => LXD is ready
looks ok…
$ sudo systemctl status snap.lxd.daemon
● snap.lxd.daemon.service - Service for snap application lxd.daemon
Loaded: loaded (/etc/systemd/system/snap.lxd.daemon.service; enabled; vendor prese
Active: active (running) since Mon 2018-04-30 12:27:19 PDT; 9min ago
Main PID: 1166 (daemon.start)
Tasks: 0
Memory: 41.0M
CPU: 1.411s
CGroup: /system.slice/snap.lxd.daemon.service
‣ 1166 /bin/sh /snap/lxd/6862/commands/daemon.start
Looks like it is up…
$ sudo cat /var/snap/lxd/common/lxd/logs/lxd.log
lvl=info msg="LXD 3.0.0 is starting in normal mode" path=/var/snap/lxd/common/lxd t=2018-04-30T19:27:24+0000
lvl=info msg="Kernel uid/gid map:" t=2018-04-30T19:27:24+0000
lvl=info msg=" - u 0 0 4294967295" t=2018-04-30T19:27:24+0000
lvl=info msg=" - g 0 0 4294967295" t=2018-04-30T19:27:24+0000
lvl=info msg="Configured LXD uid/gid map:" t=2018-04-30T19:27:24+0000
lvl=info msg=" - u 0 1000000 1000000000" t=2018-04-30T19:27:24+0000
lvl=info msg=" - g 0 1000000 1000000000" t=2018-04-30T19:27:24+0000
lvl=warn msg="CGroup memory swap accounting is disabled, swap limits will be ignored." t=2018-04-30T19:27:24+0000
lvl=info msg="Initializing local database" t=2018-04-30T19:27:24+0000
lvl=info msg="Initializing database gateway" t=2018-04-30T19:27:24+0000
address= id=1 lvl=info msg="Start database node" t=2018-04-30T19:27:24+0000
lvl=info msg="Raft: Initial configuration (index=1): [{Suffrage:Voter ID:1 Address:0}]" t=2018-04-30T19:27:24+0000
lvl=info msg="Raft: Node at 0 [Leader] entering Leader state" t=2018-04-30T19:27:24+0000
lvl=info msg="LXD isn't socket activated" t=2018-04-30T19:27:24+0000
lvl=info msg="Starting /dev/lxd handler:" t=2018-04-30T19:27:24+0000
lvl=info msg=" - binding devlxd socket" socket=/var/snap/lxd/common/lxd/devlxd/sock t=2018-04-30T19:27:24+0000
lvl=info msg="REST API daemon:" t=2018-04-30T19:27:24+0000
lvl=info msg=" - binding Unix socket" socket=/var/snap/lxd/common/lxd/unix.socket t=2018-04-30T19:27:24+0000
lvl=info msg="Initializing global database" t=2018-04-30T19:27:24+0000
lvl=info msg="Initializing storage pools" t=2018-04-30T19:27:24+0000
lvl=info msg="Initializing networks" t=2018-04-30T19:27:24+0000
lvl=info msg="Loading configuration" t=2018-04-30T19:27:24+0000
lvl=info msg="Pruning expired images" t=2018-04-30T19:27:24+0000
lvl=info msg="Done pruning expired images" t=2018-04-30T19:27:24+0000
lvl=info msg="Updating instance types" t=2018-04-30T19:27:24+0000
lvl=info msg="Expiring log files" t=2018-04-30T19:27:24+0000
lvl=info msg="Updating images" t=2018-04-30T19:27:24+0000
lvl=info msg="Done updating images" t=2018-04-30T19:27:24+0000
lvl=info msg="Done expiring log files" t=2018-04-30T19:27:24+0000
lvl=info msg="Done updating instance types" t=2018-04-30T19:27:28+0000
Is the line with lvl=info msg="LXD isn't socket activated" t=2018-04-30T19:27:24+0000
anythign to worry about?
I must be missing something.
