Hi forum, I’ve started to use lxd to run my Windows Server 2019 vm.
But I found that I can’t find how many cpu / memory resources were being used by VM?
root@workstation:/home/linyu# lxc info server2019
Remote: unix://
Created: 2021/06/21 05:40 UTC
Status: Running
Type: virtual-machine
Profiles: default
Pid: 3496
Ips:
eth0: inet6 fe80::f5a4:7746:d621:15a0 tapa5499463
Resources:
Processes: -1
Disk usage:
root: 9.78GB
Network usage:
Bytes received: 824.66kB
Bytes sent: 1.46MB
Packets received: 6740
Packets sent: 4835
Also, by pylxd:
>>> for vm in allvm:
... cno = vm.state()
... cno.cpu
{'usage': 0}
>>> for vm in allvm:
... cno.memory
{'usage': 0, 'usage_peak': 0, 'swap_usage': 0, 'swap_usage_peak': 0}
Is there are any way to monitor the resource usage? Thank you.
