If we copy container from one node to another ,the mount point showing none .
zfs list
zpool 306G 818G 24K /data/zpool
zpool/default 306G 818G 24K none
zpool/default/containers 306G 818G 24K none
zpool/default/containers/CJava 1.37G 818G 1.37G none
zpool/default/containers/Java 11.5G 818G 10.8G none
zpool/default/containers/adminweb 16.1G 818G 16.0G /var/snap/lxd/common/lxd/storage-pools/default/containers/adminweb
But in some case the mount point is appearing correctly .
Kindly let me know reason for the same.
