I am trying to setup a fedora container to run K3B. The software itself
runs great but I am having difficulties mounting the DVD RW device
in the container.
This is the information I get from the DVD RW device on the host:
udevadm info --query=env /dev/sr0
Yields this result:
EVPATH=/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.0/host0/target0:0:0/0:0:0:0/block/sr0
DEVNAME=/dev/sr0
DEVTYPE=disk
DISKSEQ=16
MAJOR=11
MINOR=0
SUBSYSTEM=block
USEC_INITIALIZED=8951945717
ID_CDROM=1
SYSTEMD_MOUNT_DEVICE_BOUND=1
ID_CDROM_CD_R=1
ID_CDROM_CD_RW=1
ID_CDROM_DVD=1
ID_CDROM_DVD_R=1
ID_CDROM_DVD_RAM=1
ID_CDROM_MRW=1
ID_CDROM_MRW_W=1
ID_CDROM_DVD_R_DL_SEQ=1
ID_CDROM_DVD_R_DL_JR=1
ID_CDROM_DVD_PLUS_R_DL=1
ID_CDROM_DVD_PLUS_R=1
ID_CDROM_DVD_PLUS_RW=1
ID_CDROM_DVD_RW_SEQ=1
ID_CDROM_DVD_RW_RO=1
ID_CDROM_CD=1
ID_CDROM_RW_REMOVABLE=1
ID_CDROM_DVD_RW=1
ID_CDROM_DVD_R_DL=1
SYSTEMD_READY=0
ID_BUS=usb
ID_MODEL=DVDRAM_GP57EB40
ID_MODEL_ENC=DVDRAM\x20GP57EB40\x20
ID_MODEL_ID=1887
ID_SERIAL=HL-DT-ST_DVDRAM_GP57EB40_K0DL2383936-0:0
ID_SERIAL_SHORT=K0DL2383936
ID_VENDOR=HL-DT-ST
ID_VENDOR_ENC=HL-DT-ST
ID_VENDOR_ID=0e8d
ID_REVISION=RF01
ID_TYPE=cd
ID_INSTANCE=0:0
ID_USB_MODEL=DVDRAM_GP57EB40
ID_USB_MODEL_ENC=DVDRAM\x20GP57EB40\x20
ID_USB_MODEL_ID=1887
ID_USB_SERIAL=HL-DT-ST_DVDRAM_GP57EB40_K0DL2383936-0:0
ID_USB_SERIAL_SHORT=K0DL2383936
ID_USB_VENDOR=HL-DT-ST
ID_USB_VENDOR_ENC=HL-DT-ST
ID_USB_VENDOR_ID=0e8d
ID_USB_REVISION=RF01
ID_USB_TYPE=cd
ID_USB_INSTANCE=0:0
ID_USB_INTERFACES=:080250:
ID_USB_INTERFACE_NUM=00
ID_USB_DRIVER=usb-storage
ID_PATH=pci-0000:00:14.0-usb-0:1:1.0-scsi-0:0:0:0
ID_PATH_TAG=pci-0000_00_14_0-usb-0_1_1_0-scsi-0_0_0_0
ID_FOR_SEAT=block-pci-0000_00_14_0-usb-0_1_1_0-scsi-0_0_0_0
DEVLINKS=/dev/cdrom /dev/disk/by-path/pci-0000:00:14.0-usb-0:1:1.0-scsi-0:0:0:0 /dev/disk/by-id/usb-HL-DT-ST_DVDRAM_GP57EB40_K0DL2383936-0:0 /dev/disk/by-diskseq/16
TAGS=:uaccess:seat:systemd:
I have tried mounting the device using the following container config:
dvd:
required: "false"
source: /dev/sr0
type: unix-block
This configuration sort of works, but is not recognized by K3B as a cdrom/dvd drive. This
is the output from the same udevadm as above, but from within the container:
DEVPATH=/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.0/host0/target0:0:0/0:0:0:0/block/sr0
DEVNAME=/dev/sr0
DEVTYPE=disk
DISKSEQ=16
MAJOR=11
MINOR=0
SUBSYSTEM=block
I suppose it is the lack of information tags such as ID_CDROM=1 which prevents
K3B from properly identifying the device.
I am using incus 6.0.1.
Any ideas on how to make this work?
