I was fiddling with nmcli and resolvectl trying to configure DNS forwarding to a container within the LXD network when noticed that my containers got no IP addresses.
lxdbr0 here is a managed bridge, and containers previously acquired DHCP leases normally.
When I assigned IP addresses inside containers they started pinging each other, but could not ping the bridge address. In the packets I captured on lxdbr0 with tshark I could see ARP requests for bridge’s address but no replies. And the same with pinging containers from the host: ARP requests for container’s address without replies.
I created another managed network and attached a couple of containers to it. They acquired addresses (after some reconfiguration), so it was possible to delete the default network, then recreate it, and it would presumably resolve the issue. But I wanted to find out the cause and fix it for real. This is where I decided to post on this forum asking for help.
But first I needed some more data to attach, and tshark’s interface isn’t very comfortable to drill into individual packets, so I fired up Wireshark and started capture on lxdbr0. Suddenly I noticed something tshark didn’t show me: packets from containers were VLAN tagged with VID 1, and packets from the bridge were untagged. I checked with another bridge: packets went untagged in both directions. What could have caused this pointless tagging? Cursory search on linux bridge vlan tags got me to this Unix StackExchange question: https://unix.stackexchange.com/questions/546136/bridged-interfaces-and-vlan-tags. So when I typed in the command to view current vlan configuration:
— it left me somewhat confused. Turns out everything is by default tagged, and my bridge somehow lost its PVID. Well, it could be fixed with this somewhat weird incantation: bridge vlan add dev lxdbr0 vid 1 pvid untagged self. Containers got their addresses straight away and could access the outside network.
The only questions left are how and why this happened and if this can happen again
By the way you describe it, it sounds like you’ve removed the address from the lxdbr0 interface.
Given that nmcli is used for configuring interface addresses (amongst other things), its likely that what ever you did with that has somehow remove the lxdbr0 config.
Please show output of ip a and ip r on the host, as well as the output of sudo ps aux | grep dnsmasq and sudo ss -ulpn from the host.
What’s more interesting is that new bridges are by default created with their “self” port added to VLAN 1, i.e.
> sudo ip link add tmpbr0 type bridge
> ip link show dev tmpbr0
26: tmpbr0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
link/ether 52:48:cf:93:3a:0f brd ff:ff:ff:ff:ff:ff
> bridge vlan show dev tmpbr0
port vlan ids
tmpbr0 1 PVID Egress Untagged
> bridge -d link show dev tmpbr0
26: tmpbr0: <BROADCAST,MULTICAST> mtu 1500 master tmpbr0 tmpbr0
Compare the output of last two commands to lxdbr0:
> bridge vlan show dev lxdbr0
port vlan ids
lxdbr0 None
> bridge -d link show dev lxdbr0
15: lxdbr0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 master lxdbr0
I’ve disabled nmcli settings connection.autoconnect and bridge.stp that were set by, I suspect, ansible’s nmcli module.
Let’s see what happens tomorrow after I turn the machine up again
Yes, I would prefer NetworkManager not touch it. But both of my current LXD bridges show up green in nmcli connections and nmcli devices. I guess my next step would be finding a way to make them “unmanaged”, if removing “autoconnect” would prove insufficient
