Hi
I tried installing LXD inside another container, parent is snap 3.4 and the child was also attempted with snap.
The child version fails
- Run install hook of “lxd” snap if present (run hook “install”: cannot perform operation: mount --rbind /lib/modules /tmp/snap.rootfs_pSGWXh//lib/modules: No such file or directory)
I’ve tried zfs, btrfs and dir storage all get the same error.
Also I’m setting security.privileged true.
Is this possible?
Cheers,
Jon.
