I am trying to configure network forwarding such that the host’s external IP is forwarded to an instance’s IP, but with the incus-ui’s 8443
port excluded.
So let’s say I’ve got two instances.
- main - all ports forwarded except 8443
- web-server - port 80 forwarded
I want the host’s IP to forward to main
but exempt 8443 to access incus ui.
The network forwarding config is something like this and it works fine.
config: {}
ports:
- description: main
protocol: tcp
listen_port: "1-8442,8444-65535"
target_address: 10.221.18.7
- description: web server
protocol: tcp
listen_port: "80"
target_address: 10.167.36.91
listen_address: 192.168.65.6
However, I was hoping there would be a cleaner way, that would not require listing out ports 1-8442,8444-65535
manually.
Basically, build on the following config instead and be able to exempt only port 8443.
ports:
protocol: tcp
listen_port: "80"
