https://askubuntu.com/questions/1041379/lxd-init-fails-on-ubuntu-16-04-xenial-xerus
When I use lxd, it fails on lxd init .
$ snap install lxd
lxd 3.0.0 from 'canonical' installed
$ lxd init
Error: Failed to connect to local LXD: Get http://unix.socket/1.0: dial unix
/var/snap/lxd/common/lxd/unix.socket: connect: no such file or directory
I have the following on my computer:
$ snapcraft --version
snapcraft, version 2.42.1
$ uname -a
4.13.0-43-generic #48~16.04.1-Ubuntu SMP Thu May 17 12:56:46 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
I don’t know if this is relevant, but my computer uses Intel i7-7500U and has Secure Boot UEFI.
Below is output of more commands:
$ snap services lxd
Service Startup Current
lxd.daemon enabled active
$ snap logs lxd.daemon
2018-05-28T22:22:42Z lxd.daemon[1404]: 5: fd: 11: pids
2018-05-28T22:22:42Z lxd.daemon[1404]: 6: fd: 12: perf_event
2018-05-28T22:22:42Z lxd.daemon[1404]: 7: fd: 13: hugetlb
2018-05-28T22:22:42Z lxd.daemon[1404]: 8: fd: 14: cpu,cpuacct
2018-05-28T22:22:42Z lxd.daemon[1404]: 9: fd: 15: freezer
2018-05-28T22:22:42Z lxd.daemon[1404]: 10: fd: 16: net_cls,net_prio
2018-05-28T22:22:42Z lxd.daemon[1404]: 11: fd: 17: name=systemd
2018-05-28T22:22:42Z lxd.daemon[1404]: lvl=warn msg="CGroup memory swap accounting is disabled, swap limits will be ignored." t=2018-05-28T22:22:42+0000
2018-05-28T22:22:42Z lxd.daemon[1404]: lvl=warn msg="Failed to update instance types: Get https://images.linuxcontainers.org/meta/instance-types/.yaml: lookup images.linuxcontainers.org on [::1]:53: dial udp [::1]:53: connect: cannot assign requested address" t=2018-05-28T22:22:42+0000
2018-05-28T22:22:43Z lxd.daemon[1404]: => LXD is ready
$ lxd init
Error: Failed to connect to local LXD: Get http://unix.socket/1.0: dial unix /var/snap/lxd/common/lxd/unix.socket: connect: permission denied
Does lxd snap requires ipv6? Can I force ipv4? Is something else wrong?
Edit:
$ groups myusername
myusername : myusername adm cdrom sudo dip plugdev lpadmin sambashare lxd
I am a member of lxd group. but
$ groups
has no lxd. What does it mean?
Also, whats the correct channel to get support on lxd ? (ubuntu forums, askubuntu, this forum, … ?)
