You are not giving a lot of info on what is your config, what was working before, what happened that could have triggered a change…It’s not really useful to speculate on what could have gone wrong…
how many containers before ? did you try to restart the computer ? what’s the version of lxd ? what is the OS ? any error message in syslog when you restart the service ?
debian 9 with lxd 3.8 but not snap version ? where did you find deb packages for lxd 3.8 ? in some unofficial repo ? (since lxd is not packaged by debian) or did you compile it yourself ? if it’s not packaged by debian, it’s because it’s really hard to do it right. If you use unofficial debs or compiled by hand lxd, search no further for the reason of your problems. If you did backups, install snap version and restore the backups.
If you use in fact snap lxd (I hope so, but if you were using snap you would be at 3.13 version…), there is nothing obviously wrong in your log. By any chance, did you create persistent containers ?
I am on mobile now, not having read the whole thread. I strongly believe that you have more than one installations of LXD and somehow you got switched to an empty installation (so not containers).
The lxc command looks into a Unix socket in order to connect to the LXD server. Can you find that Unix socket? Then, check which LXD process uses that socket (command: fuser -u mysocket).
Anyone wanting to compile lxd for debian should begin by reading the debian trackre showing five years of effort at packaging LXD in deb format. in particular this message that shows the best LXD expert dismissing at futile efforts at packaging anything beyond the LTS release.
Then the most recent messages show that recent LXD (not LTS, that is > 3.0x) use packaged versions of ZFS, BTRFS, SQLITE. So anyone wanting to compile LXD > 3.0x should either know very well the innards of SQLITE, ZFS or BTRFS, so that they know if and when they can use their own system version with LXD, or take the Ubuntu patches and compile these libraries to the same level as the compiled LXD version. If not they are using an untested configuration.
So in a few words: good luck ! I am not good enough to help you, sorry.
Edit: I said ‘ubuntu patches’, but the appropriate word is ‘snap lxd patches’
There is something wrong with the updates in ubuntu that breakthe debian package. Even in 18.04. It has happen to me before, and now I have a big clusterf$$k. And LXD just turns to crap after the upgrade. It becomes useless. It is even impossible to export container. As someone mentioned it seems to want to run two LXD, but it also lose connectivity on to each other perhaps because there are two LXD one that is hanging. So far developer is not seeing the problem or have a fix for it.
If I had only 5 or 6 containers, I would look at the possibility of backing them up by mounting a ZFS and rebuilding from them from scratch on a new LXD init with a new pool.
I tell you this because I have been working on this problem since Friday, but unfortunately I have several 5 LXD servers with over 50 containers. And right now I am rebuilding.
Actually, it is easy to compile LXD. The difficulty in packaging LXD is that in Debian they have rules (and it’s good) that requires to break down the single LXD deb package into the individual sub-packages.
Reading the debian bug, I don’t think that is the only problem; i see a wide range of compatibility problems with existing packages. That’s the whole point of snap of working around this kind of problem. Just compiling LXD can be easy, getting the rest of the system to a good working state is the main difficulty. Even with all libraries fixed, LXD being an Ubuntu project can help with having the stock Ubuntu kernel compatible. Not the case with Debian. If one use LXD long term version, the kernel issues are hopefully not too bad since no advanced feature is used.
I’m trying to trace down the problem now. It seems when you do an app upgrade it is loading the snap version of LxD together with the Debian version. I’m finding the snap version on my servers after the upgrade when I did not install them.
Then the whole thing craps out. Unfortunately there’s no way to reinstall lxd without losing your storage pool.
I have used deb lxd (please use correct denomination, Ubuntu deb packages are Ubuntu packages in deb format, not ‘Debian’ packages) and I have upgraded everything to snap and I have never found snap lxd installing by itself. I have never found or heard of a deb package upgraded automatically to a snap version without user intervention. On future Ubuntu versions, more packages will be snap by default and there will not be a deb package version, but automatic upgrading to snap don’t exist for LXD.
