[Overview] Features for Virtual Machines
Note: This post is supposed to collect information on the features for virtual machines.
It is work in progress.
Support for Virtual machines is a relatively new feature to LXD (see Running virtual machines with LXD 4.0 for initial information).
For now VM-Support is not feature-complete and more features will be added in the coming weeks and months.
The newest informations on recently added features can be found in the Release notes.
Feature List:
1. CLI:
You can use the usual lxc commands, including:
exec
file
console
config
and more
2. Configuration options:
Look out for the tags VM, vm or virtual machines in the Documentation about Instances, to see which configuration options are supported for VMs.
3. GUI/Graphics Console in VMs:
Supported via both a virtio-gpu device and Spice, available in all LXD VMs (since 4.4).
For instructions see:
[Howto] GUI in virtual machines
4. Windows VMs:
Take a look at Running virtual machines with LXD 4.0 (search for Running Windows).
5. Special Features:
  • LXD-agent (provides functionality, for example for interaction with lxc (LXD client) and more; included in cloud variants of the official images)
  • Apparmor for Qemu (since 4.6)
  • Instance API (since 4.4)
Sources:
https://discuss.linuxcontainers.org/t/lxd-4-7-has-been-released/9213
Release Notes Category in Forum
