My instance placement scriptlet stopped working after the upgrade to incus 6.14.
Currently, even replacing the scriptlet to debug it is not working. I’m using the same format provided in the scriptlet incus documentation.
pargo@bastion:~/scriptlet$ cat maintenance.py
# Error return strings
error_maintenance = "Em manutenção."
# Main instance placement scriptlet
def instance_placement(request, candidate_members):
log_error("SCRIPTLET DEBUG Request: profiles = ", request.profiles, ", name = ", request.name, ", image alias = ", request.source.alias, ", reason = ", request.reason, ", project = ", request.project, "\nSCRIPTLET DEBUG Candidade members: ", [x.server_name for x in candidate_members], "\nSCRIPTLET DEBUG Request config: ", request.config)
project = get_project( request.project )
log_error("SCRIPTLET DEBUG Request: ", request, "\nSCRIPTLET DEBUG Candidade members: ", candidate_members, "\nSCRIPTLET DEBUG Project: ", project)
fail(error_maintenance)
return # No limits to check, so scheduling is left for the default scheduler
pargo@bastion:~/scriptlet$ cat maintenance.py | incus config set instances.placement.scriptlet=-
Above I set the new maintenance placement scriptlet. Then I check for the placement scriptlet and it’s the old one (which stopped working for some unknown reason).
pargo@bastion:~/scriptlet$ incus config get instances.placement.scriptlet
error_cpu_not_string = "Configuração de limits de CPU não é string."
error_cpu_syntax = "Sintaxe inválida de limite de CPU."
error_cpu_not_pinned = "Núcleos de CPU não foram fixados."
error_cpu_key = "Chave limits.cpu com erro: "
error_pinned_cpu_not_allowed = "CPUs fixados pela instância não são permitidos pelo projeto."
error_mem_not_string = "Configuração de limite de memória não é string."
error_mem_syntax = "Sintaxe inválida de limite de memória. "
error_mem_key = "Chave limits.memory com erro: "
error_mem_not_fixed = "Memória não fixada."
error_mem_limit_exceeded = "Memória acima do permitido pelo projeto."
error_responsible_undefined = "Responsável não definido para instância na chave user.responsavel."
error_project_config = "Erro na configuração do projeto. Por favor fale com um administrador do cluster para resolver o problema. Erro: "
error_no_available_node = "Não há máquina válida disponível."
# Parses limits.cpu type strings which should have pinned cpus. Returns either an error string or a tuple containing the cpu bit vector and the most significant set bit
def parse_cpu_pin(cpu_string):
cpu_bit_vector = 0
mssb = -1
if type(cpu_string) != "string":
return error_cpu_not_string
if cpu_string.isdigit():
return error_cpu_not_pinned
parts = cpu_string.split(",")
for p in parts:
r = p.split("-")
if len(r) not in (1, 2):
return error_cpu_syntax
if len(r) == 1:
if not r[0].isdigit():
cpu = int(r[0])
cpu_bit_vector |= 1 << cpu
if cpu > mssb:
mssb = cpu
else:
if (not r[0].isdigit()) or (not r[1].isdigit()):
min = int(r[0])
max = int(r[1])
if max < min:
for cpu in range(min, max+1):
if max > mssb:
mssb = max
return cpu_bit_vector, mssb
# Parses limits.memory type strings and returns the memory size in bytes or an error string
def parse_memory(memory_string):
binary_suffixes = ("KiB", "MiB", "GiB", "TiB", "PiB", "EiB")
decimal_suffixes = ( "kB", "MB", "GB", "TB", "PB", "EB")
if type(memory_string) != "string":
return error_mem_not_string
if memory_string.endswith(binary_suffixes):
if not memory_string[:-3].isdigit():
return error_mem_syntax
mem = int(memory_string[:-3])
for bs in binary_suffixes:
mem <<= 10
if memory_string.endswith(bs):
break
elif memory_string.endswith(decimal_suffixes):
if not memory_string[:-2].isdigit():
mem = int(memory_string[:-2])
for ds in decimal_suffixes:
mem *= 1000
if memory_string.endswith(ds):
break
elif memory_string.endswith("B"):
if not memory_string[:-1].isdigit():
mem = int(memory_string[:-1])
else:
return mem
mem <<= 10
break
mem *= 1000
break
else:
return mem
# Counts used threads in a cpu_bit_vector up to bit number mssb
def count_used_threads(cpu_bit_vector, mssb):
used_threads = 0
for i in range(1+mssb):
if cpu_bit_vector & (1 << i) != 0:
used_threads += 1
return used_threads
#log_error("SCRIPTLET DEBUG Request: profiles = ", request.profiles, ", name = ", request.name, ", image alias = ", request.source.alias, ", reason = ", request.reason, ", project = ", request.project, "\nSCRIPTLET DEBUG Candidade me
# log_error("SCRIPTLET DEBUG Request: ", request, "\nSCRIPTLET DEBUG Candidade members: ", candidate_members, "\nSCRIPTLET DEBUG Project: ", project)
# Check for user.node.represented project key
rep_unique = False
if "user.node.represented" in project.config:
if project.config["user.node.represented"] == "true" and "user.responsavel" not in request.config:
fail(error_responsible_undefined)
responsavel = request.config["user.responsavel"]
if "user.node.represented.unique" in project.config:
if project.config["user.node.represented.unique"] == "true":
rep_unique = True
# Check for user.node.limits.cpu project key
cpu_pin = False
if "user.node.limits.cpu" in project.config:
cpu_pin = True
ret = parse_cpu_pin(project.config["user.node.limits.cpu"])
if type(ret) == "string":
fail(error_project_config, ret)
project_cpu_bit_vector = ret[0]
# Check for user.node.limits.cpu.unique project key
cpu_unique = False
if "user.node.limits.cpu.unique" in project.config:
if project.config["user.node.limits.cpu.unique"] == "true":
cpu_unique = True
if cpu_pin or cpu_unique:
if "limits.cpu" not in request.config:
fail(error_cpu_not_pinned)
ret = parse_cpu_pin(request.config["limits.cpu"])
fail(error_cpu_key, ret)
instance_cpu_bit_vector = ret[0]
if cpu_pin and (instance_cpu_bit_vector | project_cpu_bit_vector) != project_cpu_bit_vector:
fail(error_pinned_cpu_not_allowed)
# Check for user.node.limits.memory project key
mem_limited = False
if "user.node.limits.memory" in project.config:
mem_limited = True
ret = parse_memory(project.config["user.node.limits.memory"])
req_mem_limit = ret
if "limits.memory" not in request.config:
fail(error_mem_not_fixed)
ret = parse_memory(request.config["limits.memory"])
fail(error_mem_key, ret)
req_mem_limit -= ret
if req_mem_limit < 0:
fail(error_mem_limit_exceeded)
if rep_unique or mem_limited or cpu_unique:
machines = dict()
# Register initial values for relevant statistics from candidate members
for m in candidate_members:
mvars = dict()
mvars["valid"] = True
if mem_limited:
mvars["req_mem"] = req_mem_limit
if cpu_unique:
mvars["used_cpu"] = 0
mvars["mssb"] = -1
machines[m.server_name] = mvars
# Get valid machines and relevant statistics
inst = get_instances(project=request.project)
for i in inst:
if i.location in machines and machines[i.location]["valid"]:
if rep_unique:
if "user.responsavel" not in i.expanded_config or i.expanded_config["user.responsavel"] != responsavel:
machines[i.location]["valid"] = False
continue
if mem_limited:
if "limits.memory" not in i.expanded_config:
continue
ret = parse_memory(i.expanded_config["limits.memory"])
continue
machines[i.location]["req_mem"] -= ret
if machines[i.location]["req_mem"] < 0:
continue
if cpu_unique:
if "limits.cpu" not in i.expanded_config:
continue
ret = parse_cpu_pin(i.expanded_config["limits.cpu"])
continue
machines[i.location]["used_cpu"] |= ret[0]
if instance_cpu_bit_vector & machines[i.location]["used_cpu"] != 0:
continue
if machines[i.location]["mssb"] < ret[1]:
machines[i.location]["mssb"] = ret[1]
# Choose target node
target = None
for mname in machines:
if machines[mname]["valid"]:
if cpu_unique:
used_threads = count_used_threads(machines[mname]["used_cpu"], machines[mname]["mssb"])
better_target = False
if target == None:
better_target = True
elif mem_limited and machines[mname]["req_mem"] < machines[target]["req_mem"]: # prefer best fit into memory
elif cpu_unique and used_threads > target_used_threads: # prefer best fit on cpu cores
if better_target:
target = mname
if cpu_unique:
target_used_threads = used_threads
if target == None:
fail(error_no_available_node)
set_target(target)
I’m having issues to set any server configuration keys at the moment actually. Not sure what happened.
pargo@bastion:~/scriptlet$ incus config set user.foo=bar
pargo@bastion:~/scriptlet$ incus config get user.foo
pargo@bastion:~/scriptlet$ incus config set user.foo="bar"
