How do I mount ZFS dataset into virtual machine ??
┌─[doskanoness@gentoo] - [~] - [2021-11-27 11:06:18]
└─[0] <> lxc start binpkgs-vps ⚡[▶▶▶▶▶▶▶▶▶▷]
Error: Failed to start device "binpkgs": Failed to setup virtfs-proxy-helper for device "binpkgs": Required binary "virtfs-proxy-helper" couldn't be found
Try `lxc info --show-log binpkgs-vps` for more info
┌─[doskanoness@gentoo] - [~] - [2021-11-27 11:17:12]
└─[1] <> lxc info --show-log binpkgs-vps ⚡[▶▶▶▶▶▶▶▶▶▷]
Remote: unix://
Created: 2021/11/27 20:54 UTC
Status: Stopped
Type: virtual-machine
Profiles: default, gentoo
Error: open /var/log/lxd/binpkgs-vps/qemu.log: no such file or directory
┌─[doskanoness@gentoo] - [~] - [2021-11-27 11:17:19]
└─[1] <> which virtfs-proxy-helper ⚡[▶▶▶▶▶▶▶▶▶▷]
virtfs-proxy-helper not found
┌─[doskanoness@gentoo] - [~] - [2021-11-27 11:07:57]
└─[130] <> equery u qemu ⚡[▶▶▶▶▶▶▶▶▶▷]
[ Legend : U - final flag setting for installation]
[ : I - package is installed with flag ]
[ Colors : set, unset ]
* Found these USE flags for app-emulation/qemu-6.0.1-r1:
U I
- - accessibility : Adds support for braille displays using brltty
+ - aio : Enables support for Linux's Async IO
+ + alsa : Enable alsa output for sound emulation
+ + bzip2 : Use the bzlib compression library
+ - caps : Use Linux capabilities library to control privilege
- - capstone : Enable disassembly support with dev-libs/capstone
+ - curl : Support ISOs / -cdrom directives via HTTP or HTTPS.
- - debug : Enable extra debug codepaths, like asserts and extra output. If you want to get meaningful backtraces see
https://wiki.gentoo.org/wiki/Project:Quality_Assurance/Backtraces
+ - doc : Add extra documentation (API, Javadoc, etc). It is recommended to enable per package instead of globally
+ - fdt : Enables firmware device tree support
+ - filecaps : Use Linux file capabilities to control privilege rather than set*id (this is orthogonal to USE=caps which uses capabilities at runtime e.g. libcap)
- - fuse : Enables FUSE block device export
- - glusterfs : Enables GlusterFS cluster fileystem via sys-cluster/glusterfs
- - gnutls : Enable TLS support for the VNC console server. For 1.4 and newer this also enables WebSocket support. For 2.0 through 2.3 also enables disk quorum
support.
+ + gtk : Add support for x11-libs/gtk+ (The GIMP Toolkit)
- - infiniband : Enable Infiniband RDMA transport support
+ - io-uring : Enable efficient I/O via sys-libs/liburing.
- - iscsi : Enable direct iSCSI support via net-libs/libiscsi instead of indirectly via the Linux block layer that sys-block/open-iscsi does.
- - jack : Add support for the JACK Audio Connection Kit
- - jemalloc : Enable jemalloc allocator support
+ + jpeg : Enable jpeg image support for the VNC console server
- - lzo : Enable support for lzo compression
- - multipath : Enable multipath persistent reservation passthrough via sys-fs/multipath-tools.
+ + ncurses : Enable the ncurses-based console
+ - nfs : Enable NFS support
+ + nls : Add Native Language Support (using gettext - GNU locale utilities)
- - numa : Enable NUMA support
+ + opengl : Add support for OpenGL (3D graphics)
+ - oss : Add support for OSS (Open Sound System)
+ - pin-upstream-blobs : Pin the versions of BIOS firmware to the version included in the upstream release. This is needed to sanely support
migration/suspend/resume/snapshotting/etc... of instances. When the blobs are different, random corruption/bugs/crashes/etc... may be observed.
- - plugins : Enable qemu plugin API via shared library loading.
+ + png : Enable png image support for the VNC console server
+ + pulseaudio : Enable pulseaudio output for sound emulation
- - python : Add optional support/bindings for the Python language
- - python_targets_python3_10 : Build with Python 3.10
- - python_targets_python3_8 : Build with Python 3.8
+ + python_targets_python3_9 : Build with Python 3.9
+ + qemu_softmmu_targets_aarch64 : ARM64 system emulation target
- - qemu_softmmu_targets_alpha : system emulation target
+ + qemu_softmmu_targets_arm : system emulation target
- - qemu_softmmu_targets_avr : system emulation target
- - qemu_softmmu_targets_cris : system emulation target
- - qemu_softmmu_targets_hppa : system emulation target
- - qemu_softmmu_targets_i386 : system emulation target
- - qemu_softmmu_targets_lm32 : LatticeMico32 system emulation target
- - qemu_softmmu_targets_m68k : system emulation target
- - qemu_softmmu_targets_microblaze : system emulation target
- - qemu_softmmu_targets_microblazeel : system emulation target
- - qemu_softmmu_targets_mips : system emulation target
- - qemu_softmmu_targets_mips64 : system emulation target
- - qemu_softmmu_targets_mips64el : system emulation target
- - qemu_softmmu_targets_mipsel : system emulation target
- - qemu_softmmu_targets_moxie : moxielogic system emulation target
- - qemu_softmmu_targets_nios2 : system emulation target
- - qemu_softmmu_targets_or1k : OpenRISC system emulation target
- - qemu_softmmu_targets_ppc : system emulation target
- - qemu_softmmu_targets_ppc64 : system emulation target
- - qemu_softmmu_targets_riscv32 : system emulation target
- - qemu_softmmu_targets_riscv64 : system emulation target
- - qemu_softmmu_targets_rx : Renesas RX system emulation target
- - qemu_softmmu_targets_s390x : system emulation target
- - qemu_softmmu_targets_sh4 : system emulation target
- - qemu_softmmu_targets_sh4eb : system emulation target
- - qemu_softmmu_targets_sparc : system emulation target
- - qemu_softmmu_targets_sparc64 : system emulation target
- - qemu_softmmu_targets_tricore : system emulation target
- - qemu_softmmu_targets_unicore32 : system emulation target
+ + qemu_softmmu_targets_x86_64 : system emulation target
- - qemu_softmmu_targets_xtensa : system emulation target
- - qemu_softmmu_targets_xtensaeb : system emulation target
+ + qemu_user_targets_aarch64 : ARM64 userspace emulation target
- - qemu_user_targets_aarch64_be : ARM64 big endian userspace emulation target
- - qemu_user_targets_alpha : userspace emulation target
+ + qemu_user_targets_arm : ARM (little endian) userspace emulation target
- - qemu_user_targets_armeb : ARM (big endian) userspace emulation target
- - qemu_user_targets_cris : userspace emulation target
- - qemu_user_targets_hexagon : Qualcomm hexagon userspace emulation target
- - qemu_user_targets_hppa : userspace emulation target
- - qemu_user_targets_i386 : userspace emulation target
- - qemu_user_targets_m68k : userspace emulation target
- - qemu_user_targets_microblaze : userspace emulation target
- - qemu_user_targets_microblazeel : userspace emulation target
- - qemu_user_targets_mips : userspace emulation target
- - qemu_user_targets_mips64 : userspace emulation target
- - qemu_user_targets_mips64el : userspace emulation target
- - qemu_user_targets_mipsel : userspace emulation target
- - qemu_user_targets_mipsn32 : MIPS N32 ABI userspace emulation target
- - qemu_user_targets_mipsn32el : MIPS N32 ABI LE userspace emulation target
- - qemu_user_targets_nios2 : userspace emulation target
- - qemu_user_targets_or1k : OpenRISC system emulation target
- - qemu_user_targets_ppc : PowerPC 32-bit big endian userspace emulation target
- - qemu_user_targets_ppc64 : PowerPC 64-bit big endian userspace emulation target
- - qemu_user_targets_ppc64abi32 : userspace emulation target
- - qemu_user_targets_ppc64le : PowerPC 64-bit little endian userspace emulation target
- - qemu_user_targets_riscv32 : userspace emulation target
- - qemu_user_targets_riscv64 : userspace emulation target
- - qemu_user_targets_s390x : userspace emulation target
- - qemu_user_targets_sh4 : userspace emulation target
- - qemu_user_targets_sh4eb : userspace emulation target
- - qemu_user_targets_sparc : userspace emulation target
- - qemu_user_targets_sparc32plus : userspace emulation target
- - qemu_user_targets_sparc64 : userspace emulation target
+ + qemu_user_targets_x86_64 : userspace emulation target
- - qemu_user_targets_xtensa : userspace emulation target
- - qemu_user_targets_xtensaeb : userspace emulation target
- - rbd : Enable rados block device backend support, see https://docs.ceph.com/en/mimic/rbd/qemu-rbd/
- - sasl : Add support for the Simple Authentication and Security Layer
+ + sdl : Enable the SDL-based console
- - sdl-image : SDL Image support for icons
+ + seccomp : Enable seccomp (secure computing mode) to perform system call filtering at runtime to increase security of programs
+ - slirp : Enable TCP/IP in hypervisor via net-libs/libslirp
- - smartcard : Enable smartcard support
- - snappy : Enable support for Snappy compression (as implemented in app-arch/snappy)
+ - spice : Enable Spice protocol support via app-emulation/spice
+ - ssh : Enable SSH based block device support via net-libs/libssh2
- - static : Build the User and Software MMU (system) targets as well as tools as static binaries
- - static-user : Build the User targets as static binaries
- - systemtap : Enable SystemTAP/DTrace tracing
- - test : Enable dependencies and/or preparations necessary to run tests (usually controlled by FEATURES=test but can be toggled independently)
+ + udev : Enable virtual/udev integration (device discovery, power and storage device support, etc)
+ + usb : Enable USB passthrough via dev-libs/libusb
+ - usbredir : Use sys-apps/usbredir to redirect USB devices to another machine over TCP
+ - vde : Enable VDE-based networking
+ - vhost-net : Enable accelerated networking using vhost-net, see https://www.linux-kvm.org/page/VhostNet
+ - vhost-user-fs : Enable shared file system access using the FUSE protocol carried over virtio.
+ - virgl : Enable experimental Virgil 3d (virtual software GPU)
+ - virtfs : Enable VirtFS via virtio-9p-pci / fsdev. See https://wiki.qemu.org/Documentation/9psetup
- - vnc : Enable VNC (remote desktop viewer) support
- - vte : Enable terminal support ( x11-libs/vte) in the GTK+ interface
+ + xattr : Add support for getting and setting POSIX extended attributes, through sys-apps/attr. Requisite for the virtfs backend.
- - xen : Enables support for Xen backends
+ - xfs : Support xfsctl() notification and syncing for XFS backed virtual disks.
- - zstd : Enable support for ZSTD compression
┌─[doskanoness@gentoo] - [~] - [2021-11-27 11:20:22]
└─[126] <> qemu-system-x86_64 --version ⚡[▶▶▶▶▶▶▶▶▶▷]
QEMU emulator version 6.1.0
Copyright (c) 2003-2021 Fabrice Bellard and the QEMU Project developers
