The error is only with the alpine / 3.13 / cloud image.
Well my question was not answered and I end up solving an image problem.
Going back to your initial question, there are some things that might have caused issues.
First, your config doesnât appear to have security.secureboot=false
which is necessary as Alpine Linux doesnât support secureboot.
Second, Alpine Linux doesnât have /bin/bash
so that will fail. Instead, you need to use /bin/sh
Third, you need to set the user.user-data
config before starting the VM for the first time. You can do this by running
lxc init images:alpine/3.13/cloud v1 --vm -c security.secureboot=false
lxc config edit v1
lxc start v1
