it seems I have problems with file-timestamps in conjunction
with ShiftFS + unprivileged containers.
When copying files with “cp -p”, the source file shouldn’t be newer than the duplicate:
To reproduce, first I run the command with privileged containers, successfully:
lxc config set d1 security.privileged=true
lxc restart d1
lxc exec d1 -- bash -c "touch a; cp -p a b; if [ a -nt b ]; then echo FAIL; else echo OK; fi; rm a b"
# Output: OK
With unprivileged it fails:
lxc config set d1 security.privileged=false
lxc restart d1
# Output: FAIL
The hosts are Gentoo-Linux, kernel 5.4 with lxd 4.0.3, Shiftfs, ZFS 0.8.
I tried with Debian and Gentoo-Containers.
Is this a bug or is it config problem on my end?
__Update: ___
A stat a b outputs this, when running privileged:
File: a
Size: 0 Blocks: 1 IO Block: 131072 regular empty file
Device: 50h/80d Inode: 66000 Links: 1
Access: (0644/-rw-r--r--) Uid: ( 0/ root) Gid: ( 0/ root)
Access: 2020-11-07 20:10:28.072665559 +0000
Modify: 2020-11-07 20:10:28.072665559 +0000
Change: 2020-11-07 20:10:28.072665559 +0000
Birth: -
File: b
Device: 50h/80d Inode: 66001 Links: 1
Change: 2020-11-07 20:10:28.075998611 +0000
When running unprivileged:
File: a
Device: 50h/80d Inode: 65999 Links: 1
Access: 2020-11-07 20:10:30.789102206 +0000
Modify: 2020-11-07 20:10:30.789102206 +0000
Change: 2020-11-07 20:10:30.789102206 +0000
Birth: -
File: b
Access: 2020-11-07 20:10:30.000000000 +0000
Modify: 2020-11-07 20:10:30.000000000 +0000
Change: 2020-11-07 20:10:30.792435256 +0000
Birth: -
Looks like the sub-second-information went missing.
Thanks
Michael
