Hi again, that solution did indeed work when creating a new instance.
I have been looking into the lxc move instance --target node3
command to change the location of an instance and the closest I have found on the wiki was the migrate
option. However it seems to not allow moving from one host to another if the instance name does not change as it would already exist.
Following is the small script I used for testing:
from pylxd import Client
source_client = Client(endpoint='https://192.168.1.110:8443',verify=False)
destination_client = Client(endpoint='https://192.168.1.161:8443',verify=False)
container = source_client.instances.get('test')
container.migrate(destination_client, wait=True)
And the error output:
/usr/local/lib/python3.8/dist-packages/pylxd-2.2.11-py3.8.egg/pylxd/models/operation.py:76: UserWarning: Attempted to set unknown attribute "location" on instance of "Operation"
warnings.warn(
Traceback (most recent call last):
File "lxd-test.py", line 7, in <module>
File "/usr/local/lib/python3.8/dist-packages/pylxd-2.2.11-py3.8.egg/pylxd/models/instance.py", line 531, in migrate
res = getattr(new_client, self._endpoint).create(
File "/usr/local/lib/python3.8/dist-packages/pylxd-2.2.11-py3.8.egg/pylxd/models/instance.py", line 276, in create
response = client.api[cls._endpoint].post(
File "/usr/local/lib/python3.8/dist-packages/pylxd-2.2.11-py3.8.egg/pylxd/client.py", line 177, in post
self._assert_response(response, allowed_status_codes=(200, 201, 202))
File "/usr/local/lib/python3.8/dist-packages/pylxd-2.2.11-py3.8.egg/pylxd/client.py", line 117, in _assert_response
raise exceptions.LXDAPIException(response)
pylxd.exceptions.LXDAPIException: Failed creating instance record: Add instance info to the database: This instance already exists
The cluster and instance information is as follows:
$ lxc cluster list
| NAME | URL | DATABASE | STATE | MESSAGE | ARCHITECTURE |
| node1 | https://192.168.1.110:8443 | YES | ONLINE | fully operational | x86_64 |
| node2 | https://192.168.1.161:8443 | NO | ONLINE | fully operational | x86_64 |
$ lxc list
| test | STOPPED | | | CONTAINER | 0 | node1 |
I am guessing this is not the intended use case for the migrate
function. Could you point me in the right direction to mimic the behavior of lxc move instance --target
using pylxd?
