I try to list all instances on a specific LXD project, but I only see the instance of the “default” project. The all() method not seems to accept a “project” attribute.
Can you help me to the code to use to list all instance? Thanks, Best regards
I have found the solution on the source code of pylxd.
On the client we can specify the project, it’s working
client = Client( endpoint=remote_endpoint, cert=(cert), verify=False, project=project )
Maybe the pylxd doc should be update to specify the params we can pass on the client.
I added the pylxd tag to try to get the attention of the folks maintaining the python binding. I agree better documentation would be good to have!
pylxd
Maybe @sdeziel can send a quick PR?
PR sent https://github.com/lxc/pylxd/pull/498
