I’ve been wanting to try out a ceph backed LXD cluster but have run into the problem that the ceph nodes I’m using were deployed with Juju and already have LXD containers for the Mon and CephFs on them.
Obviously, my next step was to create a (very permissive) container and setup the cluster nested in this new container. After a few modifications I have it working with apt based lxd but using the snap based LXD I can’t get the rbd to map.
If there’s a better way to solve this problem, I’m interested but here’s how I’ve got it working if anyone can help me understand why the snap version is having issues that the apt lxd doesn’t have. I’ve tried the snap lxd w/o nesting (on a different machine) and that works just fine so it’s the combination of nesting and snap that’s just to much for me to untangle.
I’m using this profile for the container that I’m installing snap lxd in.
config: raw.lxc: |- lxc.cgroup.devices.allow = a lxc.cap.drop= lxc.apparmor.profile = unconfined lxc.mount.auto= lxc.mount.auto=sys:rw proc:rw cgroup:rw security.nesting: "True" security.privileged: "True" linux.kernel_modules: rbd user.network-config: | version: 1 config: - type: physical name: eth0 - type: bridge name: br0 bridge_interfaces: - eth0 subnets: - type: dhcp description: LXD Cluster profile devices: eth0: nictype: bridged parent: br-enp1s0f0 type: nic root: path: / pool: default type: disk name: lxd
After launching bionic in a container with this profile I
- Apt remove lxd lxd-client
- Snap install lxd
- apt install ceph-common
- setup /etc/ceph/*.keyring and ceph.conf
- add udev rules to mknod the new devices
- run lxd init
/etc/udev/rules.d/99-rbd.rules
# Skip items we don't want to deal with ACTION=="changed", GOTO="persistent_storage_end" SUBSYSTEM!="block", GOTO="persistent_storage_end" KERNEL!="rbd*", GOTO="persistent_storage_end" # Add partitions KERNEL=="rbd*", ACTION=="add", RUN+="/bin/sh -c '/bin/echo /bin/mknod $env{DEVNAME} b $env{MAJOR} $env{MINOR} >> /root/udev.log 2>&1'" KERNEL=="rbd*", ACTION=="add", RUN+="/bin/sh -c '/bin/mknod $env{DEVNAME} b $env{MAJOR} $env{MINOR} >> /root/udev.log 2>&1'" # Remove partitions KERNEL=="rbd*", ACTION=="remove", RUN+="/bin/sh -c '/bin/echo rm $env{DEVNAME} >> /root/udev.log 2>&1'" KERNEL=="rbd*", ACTION=="remove", RUN+="/bin/sh -c 'rm $env{DEVNAME} >> /root/udev.log 2>&1'" LABEL="persistent_storage_end"
The init completes, but when launching a container the image is never mapped by rbd. With this setup and not switching to the snap everything works as expected.
dmesg during the launch shows:
[ 2854.185360] libceph: mon0 252.2.185.54:6789 session established [ 2854.185722] libceph: client4572 fsid c0f8c69c-9cf6-11e9-a3b9-00163ecb4cd1 [ 2854.225812] rbd: rbd0: capacity 10000000000 features 0x1
Trying to map it myself
rbd map /dev/rbd0 rbd: sysfs write failed In some cases useful info is found in syslog - try "dmesg | tail". rbd: map failed: (2) No such file or directory # From dmesg all that prints is rbd: pool rbd does not exist
I’m not sure why the lxd snap vs apt affect how rbd map
runs inside these containers. That’s very strange to me and indicates I’m missing something about how snaps are operating.
What other information would be helpful to capture, or is there a much better way to accomplish this?
