eager
(Michael Eager)
January 14, 2026, 7:39pm
1
I’m trying to recover from a system crash and recover the incus LVM storage. I’ve installed Zabby Incus. I’m trying to follow the recovery tutorial ( How to recover or reconnect an Incus storage pool – Mi blog lah! ) but I’m having trouble translating from zfs to lvm.The VGname is lxd-pool. When I run “incus admin recover” I get the following:
# incus admin recover
This server currently has the following storage pools:
Would you like to recover another storage pool? (yes/no) [default=no]: yes
Name of the storage pool: lxd-pool
Name of the storage backend (btrfs, dir, lvm, truenas): lvm
Source of the storage pool (block device, volume group, dataset, path, … as applicable): /dev/lxd-pool
Additional storage pool configuration property (KEY=VALUE, empty when done):
The recovery process will be scanning the following storage pools:
NEW: “lxd-pool” (backend=“lvm”, source=“/dev/lxd-pool”)
Would you like to continue with scanning for lost volumes? (yes/no) [default=yes]:no
Scanning for unknown volumes…Error: Failed validation request: Failed mounting pool “lxd-pool”: Cannot mount pool as “lvm.vg_name” is not specified
One problem is that I don’t know what to specify for the source of the storage pool. /dev/lxd-pool doesn’t exist. If I specify /dev/nvme0n1p3, where the LVM pv is located I get the ame error message.
stgraber
(Stéphane Graber)
January 14, 2026, 9:23pm
2
eager:
That should be the VG name though the error you’re getting makes me think that we may be missing some LVM specific logic in there.
eager
(Michael Eager)
January 14, 2026, 9:39pm
3
I’ve tried Source = lxd-pool and I get the same error.
I noticed that the LVname is LXDThinPool, not lxd-pool. Using that doesn’t make any difference.
eager
(Michael Eager)
January 15, 2026, 1:25am
4
Is there a way to mount a container’s LV?
stgraber
(Stéphane Graber)
January 15, 2026, 7:44pm
5
Can you file an issue at Sign in to GitHub · GitHub ?
As for mounting a container’s LV, you should be able to do it with lvchange -ay -ky VG/LV and then mount the entry from under /dev/VG/LV.
eager
(Michael Eager)
January 15, 2026, 8:21pm
6
Created “Incus admin recover fails for LVM storage #2823 ” Incus admin recover fails for LVM storage · Issue #2823 · lxc/incus · GitHub
The “lvchange” command doesn’t appear to work:
#lvchange -ay -ky lxd-pool/containers_fedora37
Logical volume lxd-pool/containers_fedora37 changed.
WARNING: Combining activation change with other commands is not advised.
#ls /dev/lxd-pool
ls: cannot access ‘/dev/lxd-pool’: No such file or directory
lvdisplay doesn’t show any change in the LV.
(Splitting the lvchange into two commands to address the warning doesn’t make any difference.)
stgraber
(Stéphane Graber)
January 15, 2026, 8:23pm
7
Try lvchange -ay --ignoreactivationskip VG/LV
eager
(Michael Eager)
January 15, 2026, 8:27pm
8
Thanks. That worked.
Can I tar the directory and use it with “incus import”?
stgraber
(Stéphane Graber)
January 15, 2026, 8:40pm
9
Possibly. I think you’ll need to manually add in an index.yaml though as that’s something that’s in backups which isn’t in the instance folder.
eager
(Michael Eager)
January 15, 2026, 8:42pm
10
I’ll give it a try. What’s in index.yaml? Can you give me an example?
stgraber
(Stéphane Graber)
January 15, 2026, 8:49pm
11
stgraber@castiana:~$ incus create images:alpine/edge a1
Creating a1
stgraber@castiana:~$ incus export a1
Backup exported successfully!
stgraber@castiana:~$ mkdir a1
stgraber@castiana:~$ cd a1
stgraber@castiana:~/a1$ tar zxf ../a1.tar.gz
stgraber@castiana:~/a1$ cat backup/index.yaml
backend: zfs
pool: default
optimized: false
optimized_header: false
type: container
container:
image.architecture: amd64
image.description: Alpine edge amd64 (20260115_13:00)
image.os: Alpine
image.release: edge
image.requirements.secureboot: "false"
image.serial: "20260115_13:00"
image.type: squashfs
image.variant: default
volatile.apply_template: create
volatile.base_image: 08f4fdb05bbc429d0dc6a5c4f4b14b190f328349b4ccd8adb1138cd437e6ab1e
volatile.cloud-init.instance-id: da6d2777-bdb4-4a2f-805f-4516fff65768
volatile.eth0.hwaddr: 10:66:6a:0e:52:19
volatile.idmap.base: "0"
volatile.uuid: a6dc12b5-36a7-44de-b8ea-6f3d1cde6bea
volatile.uuid.generation: a6dc12b5-36a7-44de-b8ea-6f3d1cde6bea
devices: {}
created_at: 2026-01-15T20:48:25.742689264Z
expanded_config:
image.os: Alpine
image.release: edge
expanded_devices:
network: incusbr0
pool: default
status: Stopped
status_code: 102
last_used_at: 1970-01-01T00:00:00Z
type: container
project: default
pool:
source: castiana/incus
volatile.initial_source: castiana/incus
zfs.pool_name: castiana/incus
driver: zfs
used_by: []
status: Created
locations:
- none
- config: {}
network: incusbr0
pool: default
used_by: []
project: default
volume:
config: {}
type: container
used_by: []
content_type: filesystem
project: default
