Is it possible to add remote zfs pool in lxd server?
@tomp could u help me?
I’m not quite sure what you mean, ZFS is a non-network filesystem (as far as I know), so there is no such thing as a remote ZFS pool, they are always local to the machine. LXD does not support exposing a local filesystem remotely.
However you can access a remote LXD machine using the lxc command by adding it as a remote, but that would just avoid the need to SSH into the remote machine and issue local lxc commands.
For truly networked filesystems we support ceph clusters.
