I am trying to add a gpu via passthrough to a vm, such that its output is rendered to a different monitor. However, the default qemu GPU is chosen as primary, and therefore does not output anything to the monitor.
If I comment out the qemu_gpu device in the qemu.conf file, and force it to load this config, everything works.
Are there any way to disable the default qemuGPU device/option?
This is the point I’m talking about in the code: https://github.com/lxc/lxd/blob/master/lxd/instance/drivers/driver_qemu.go#L2575
Thanks! LXD is awesome!
