Hello LXD Family!
I got my self in a bit of a mess. I lost my underlying OVN cluster somehow and couldn’t get it back. So I resorted to recreating it… Now the problem is I want to recreate some of the same networks I have in my projects…but LXD expects those old things to be there and they are not… Is there anyway I can remove all my dependencies of my networks. I get router not found because it’s not…
Error: Failed deleting peer: Failed deleting OVN network peering: Failed getting static routes for local peer router "lxd-net15-lr": Failed to run: ovn-nbctl --timeout=10 --db tcp:192.168.20.51:6641,tcp:192.168.20.52:6641,tcp:192.168.20.53:6641 --wait=sb lr-route-list lxd-net15-lr: exit status 1 (ovn-nbctl: lxd-net15-lr: router name not found)
Thank you,
