I’m evaluating incus for the first time, so I’m sorry in advance for any beginner mistakes.
Everything is done on freshly installed machines in a test environment, there is nothing else installed except incus.
I’m incredibly impressed with and thankful for this software overall. Everything is so simple, and it Just Works!
Steps performed
- Fresh install of Ubuntu 24.04 server, bare metal on workstation class desktops.
- Fresh install incus from Zabbler stable apt repo.
- Initialized incus, no clustering, local storage pool type
diron root file system. - Created windows vm.
- Took one snapshot called
clean-install, while instance is stopped. - Installed some stuff in the vm and rebooted a few times.
- Took another snapshot called
clean-base-config-drivers, while instance is stopped. - May or may not have clicked stop button while creating the second snapshot. Really not sure whether I did this. But I definitely did not abort the first one.
- Enabled clustering on
outpost-001. - Added a couple of cluster members,
outpost-002,outpost-003.
Unexpected outcome
- Unable to delete the
clean-base-config-driverssnapshot. It fails with “read-only file system”.
Expected outcome
- Able to delete the
clean-installsnapshot without error.
Observations
- The snapshot is left in a mounted state. Not sure if this is expected, or if this is inconsistent state?
- There are no errors in
dmesg. - Everything else seems to work fine.
Questions
- What is going on with this snapshot this error?
- What are the expected file system permissions for machines and snapshots?
- Is it safe to override the permissions and delete the instances and snapshots manually from the filesystem?
- Is it possible to find a log of all incus operations?
Command outputs
outpost-001$ sudo incus snapshot delete win11test clean-base-config-drivers
Error: Failed to remove '/var/lib/incus/storage-pools/local/virtual-machines-snapshots/win11test/clean-base-config-drivers': unlinkat /var/lib/incus/storage-pools/local/virtual-machines-snapshots/win11test/clean-base-config-drivers/config: read-only file system
outpost-001$ incus storage ls
| NAME | DRIVER | DESCRIPTION | USED BY | STATE |
| local | dir | | 2 | CREATED |
outpost-001$ incus storage show local
config: {}
driver: dir
- /1.0/instances/win11test
- /1.0/profiles/default
status: Created
locations:
- outpost-001
- outpost-002
- outpost-003
outpost-001$ incus ls
| win11test | STOPPED | | | VIRTUAL-MACHINE | 2 | outpost-001 |
server-1$ incus snapshot ls win11test
| NAME | TAKEN AT | EXPIRES AT | STATEFUL |
| clean-install | 2025/10/21 09:26 UTC | | NO |
| clean-base-config-drivers | 2025/10/21 16:47 UTC | | NO |
Here is lsblk on the first server, and this looks weird to me.
I don’t think I have ever seen lsblk showing two mountpoints for one device like that.
I’m not sure not sure exactly what it means, or why this even happens when using dir storage driver.
outpost-001$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 50.8M 1 loop /snap/snapd/25202
loop1 7:1 0 73.9M 1 loop /snap/core22/2133
loop2 7:2 0 10.4M 1 loop /snap/distrobuilder/2114
loop3 7:3 0 73.9M 1 loop /snap/core22/2139
sda 8:0 0 232.9G 0 disk
├─sda1 8:1 0 1G 0 part /boot/efi
├─sda2 8:2 0 2G 0 part /boot
└─sda3 8:3 0 229.8G 0 part
└─ubuntu--vg-ubuntu--lv 252:0 0 100G 0 lvm /var/lib/incus/storage-pools/local/virtual-machines-snapshots/win11test/clean-base-config-drivers
Here is lsblk on another server. This output is expected, this looks normal to me.
outpost-003$ lsblk
sda 8:0 0 465.8G 0 disk
└─sda3 8:3 0 462.7G 0 part
Here is output of ls, showing that root is indeed lacking necessary permissions.
outpost-001$ sudo ls -la /var/lib/incus/storage-pools/local
total 40
drwx--x--x 10 root root 4096 Oct 20 16:39 .
drwx--x--x 3 root root 4096 Oct 20 16:39 ..
drwx--x--x 2 root root 4096 Oct 20 16:39 buckets
drwx--x--x 2 root root 4096 Oct 21 14:48 containers
drwx--x--x 2 root root 4096 Oct 20 16:39 containers-snapshots
drwx--x--x 2 root root 4096 Oct 20 16:39 custom
drwx--x--x 2 root root 4096 Oct 20 16:39 custom-snapshots
drwx--x--x 2 root root 4096 Oct 20 16:39 images
drwx--x--x 3 root root 4096 Oct 20 16:55 virtual-machines
drwx--x--x 3 root root 4096 Oct 21 09:26 virtual-machines-snapshots
outpost-001$ sudo ls -la /var/lib/incus/storage-pools/local/virtual-machines
total 12
drwx--x--x 3 root root 4096 Oct 20 16:55 .
drwx--x--x 10 root root 4096 Oct 20 16:39 ..
d--x------ 4 incus root 4096 Oct 21 14:49 win11test
outpost-001$ sudo ls -la /var/lib/incus/storage-pools/local/virtual-machines-snapshots
total 12
drwx--x--x 3 root root 4096 Oct 21 09:26 .
drwx------ 4 root root 4096 Oct 21 16:47 win11test
outpost-001$ sudo ls -la /var/lib/incus/storage-pools/local/virtual-machines-snapshots/win11test
total 16
drwx------ 4 root root 4096 Oct 21 16:47 .
drwx--x--x 3 root root 4096 Oct 21 09:26 ..
d--x------ 4 incus root 4096 Oct 21 16:47 clean-base-config-drivers
d--x------ 4 incus root 4096 Oct 21 09:26 clean-install
outpost-001$ sudo ls -la /var/lib/incus/storage-pools/local/virtual-machines-snapshots/win11test/clean-base-config-drivers
total 24248892
d--x------ 4 incus root 4096 Oct 21 16:47 .
drwx------ 4 root root 4096 Oct 21 16:47 ..
-rw------- 1 incus root 540672 Oct 21 14:51 OVMF_VARS.4MB.ms.fd
-rw-r--r-- 1 root root 704 Oct 20 17:00 agent-client.crt
-rw------- 1 root root 288 Oct 20 17:00 agent-client.key
-rw-r--r-- 1 root root 741 Oct 20 17:00 agent.crt
-rw------- 1 root root 288 Oct 20 17:00 agent.key
-r-------- 1 root root 4767 Oct 21 14:02 backup.yaml
dr-x------ 6 incus root 4096 Oct 21 14:02 config
lrwxrwxrwx 1 root root 19 Oct 20 17:00 qemu.nvram -> OVMF_VARS.4MB.ms.fd
-rw------- 1 root root 68719476736 Oct 21 16:51 root.img
drwx------ 2 root root 4096 Oct 21 14:51 tpm.vtpm
outpost-001$ sudo ls -la /var/lib/incus/storage-pools/local/virtual-machines-snapshots/win11test/clean-install
total 17662520
d--x------ 4 incus root 4096 Oct 21 09:26 .
-rw------- 1 incus root 540672 Oct 21 09:26 OVMF_VARS.4MB.ms.fd
-r-------- 1 root root 2538 Oct 21 09:24 backup.yaml
dr-x------ 6 incus root 4096 Oct 21 09:24 config
-rw------- 1 root root 68719476736 Oct 21 09:29 root.img
drwx------ 2 root root 4096 Oct 21 09:26 tpm.vtpm
Output of df and mount
outpost-001$ df -h
tmpfs 2.0G 1.4M 2.0G 1% /run
efivarfs 384K 100K 280K 27% /sys/firmware/efi/efivars
/dev/mapper/ubuntu--vg-ubuntu--lv 98G 81G 13G 87% /
tmpfs 9.8G 0 9.8G 0% /dev/shm
/dev/sda2 2.0G 101M 1.7G 6% /boot
/dev/sda1 1.1G 6.2M 1.1G 1% /boot/efi
tmpfs 9.8G 0 9.8G 0% /run/qemu
tmpfs 100K 0 100K 0% /var/lib/incus/shmounts
tmpfs 100K 0 100K 0% /var/lib/incus/guestapi
tmpfs 2.0G 16K 2.0G 1% /run/user/1001
outpost-001$ mount
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
udev on /dev type devtmpfs (rw,nosuid,relatime,size=10164364k,nr_inodes=2541091,mode=755,inode64)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=2040800k,mode=755,inode64)
efivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime)
/dev/mapper/ubuntu--vg-ubuntu--lv on / type ext4 (rw,relatime)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,inode64)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k,inode64)
cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=32,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=2645)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,nosuid,nodev,relatime,pagesize=2M)
mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
/dev/sda2 on /boot type ext4 (rw,relatime)
/dev/sda1 on /boot/efi type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
/var/lib/snapd/snaps/snapd_25202.snap on /snap/snapd/25202 type squashfs (ro,nodev,relatime,errors=continue,threads=single,x-gdu.hide,x-gvfs-hide)
/var/lib/snapd/snaps/core22_2133.snap on /snap/core22/2133 type squashfs (ro,nodev,relatime,errors=continue,threads=single,x-gdu.hide,x-gvfs-hide)
/var/lib/snapd/snaps/distrobuilder_2114.snap on /snap/distrobuilder/2114 type squashfs (ro,nodev,relatime,errors=continue,threads=single,x-gdu.hide,x-gvfs-hide)
tmpfs on /run/qemu type tmpfs (rw,nosuid,nodev,relatime,mode=755,inode64)
lxcfs on /var/lib/incus-lxcfs type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
tmpfs on /var/lib/incus/shmounts type tmpfs (rw,relatime,size=100k,mode=711,inode64)
tmpfs on /var/lib/incus/guestapi type tmpfs (rw,relatime,size=100k,mode=755,inode64)
/var/lib/snapd/snaps/core22_2139.snap on /snap/core22/2139 type squashfs (ro,nodev,relatime,errors=continue,threads=single,x-gdu.hide,x-gvfs-hide)
tmpfs on /run/user/1001 type tmpfs (rw,nosuid,nodev,relatime,size=2040796k,nr_inodes=510199,mode=700,uid=1001,gid=1001,inode64)
/dev/mapper/ubuntu--vg-ubuntu--lv on /var/lib/incus/storage-pools/local/virtual-machines-snapshots/win11test/clean-base-config-drivers type ext4 (ro,relatime)
Incus log and info
outpost-001$ sudo cat /var/log/incus/incusd.log
time="2025-10-20T16:40:52Z" level=warning msg="Rejecting request from untrusted client" ip="172.16.170.147:52148"
time="2025-10-20T16:58:04Z" level=warning msg="The backing filesystem doesn't support quotas, skipping set quota" driver=dir path=/var/lib/incus/storage-pools/local/virtual-machines/win11test pool=local size=69243764736 volID=2
time="2025-10-21T09:19:20Z" level=error msg="Failed writing error for HTTP response" err="http2: stream closed" url="/1.0/instances/{name}" writeErr="http2: stream closed"
time="2025-10-21T14:02:53Z" level=error msg="Failed to stop device" device=gpu1 err="Failed probing device \"0000:05:00.0\" via \"/sys/bus/pci/drivers_probe\": write /sys/bus/pci/drivers_probe: invalid argument" instance=win11test instanceType=virtual-machine project=default
time="2025-10-21T14:51:58Z" level=warning msg="Could not get VM state from agent" err="dial unix /run/incus/win11test/qemu.monitor: connect: connection refused" instance=win11test instanceType=virtual-machine project=default
time="2025-10-21T14:51:58Z" level=error msg="Failed to stop device" device=gpu1 err="Failed probing device \"0000:05:00.1\" via \"/sys/bus/pci/drivers_probe\": write /sys/bus/pci/drivers_probe: invalid argument" instance=win11test instanceType=virtual-machine project=default
time="2025-10-22T09:29:32Z" level=warning msg="Rejecting request from untrusted client" ip="172.16.170.147:37666"
outpost-001$ incus info
cluster.https_address: 172.16.170.147:8443
core.https_address: 172.16.170.147:8443
api_extensions:
- container_stop_priority
- container_syscall_filtering
- auth_pki
- container_last_used_at
- etag
- patch
- usb_devices
- https_allowed_credentials
- image_compression_algorithm
- directory_manipulation
- container_cpu_time
- storage_zfs_use_refquota
- storage_lvm_mount_options
- network
- profile_usedby
- container_push
- container_exec_recording
- certificate_update
- gpu_devices
- container_image_properties
- migration_progress
- id_map
- network_firewall_filtering
- network_routes
- storage
- file_delete
- file_append
- network_dhcp_expiry
- storage_lvm_vg_rename
- storage_lvm_thinpool_rename
- network_vlan
- image_create_aliases
- container_stateless_copy
- container_only_migration
- storage_zfs_clone_copy
- unix_device_rename
- storage_lvm_use_thinpool
- storage_rsync_bwlimit
- network_vxlan_interface
- storage_btrfs_mount_options
- entity_description
- image_force_refresh
- storage_lvm_lv_resizing
- id_map_base
- file_symlinks
- container_push_target
- network_vlan_physical
- storage_images_delete
- container_edit_metadata
- storage_driver_ceph
- storage_ceph_user_name
- resource_limits
- resources
- kernel_limits
- storage_api_volume_rename
- network_sriov
- console
- restrict_dev_incus
- migration_pre_copy
- infiniband
- dev_incus_events
- proxy
- network_dhcp_gateway
- file_get_symlink
- network_leases
- unix_device_hotplug
- operation_description
- clustering
- event_lifecycle
- nvidia_runtime
- container_mount_propagation
- container_backup
- dev_incus_images
- proxy_unix
- proxy_udp
- clustering_join
- network_state
- proxy_unix_dac_properties
- container_protection_delete
- unix_priv_drop
- pprof_http
- proxy_haproxy_protocol
- network_hwaddr
- proxy_nat
- network_nat_order
- container_full
- backup_compression
- nvidia_runtime_config
- storage_unmapped
- projects
- network_vxlan_ttl
- container_incremental_copy
- usb_optional_vendorid
- snapshot_scheduling
- snapshot_schedule_aliases
- container_copy_project
- clustering_server_address
- container_protection_shift
- snapshot_expiry
- snapshot_expiry_creation
- network_leases_location
- resources_cpu_socket
- resources_gpu
- resources_numa
- kernel_features
- id_map_current
- event_location
- network_nat_address
- container_nic_routes
- cluster_internal_copy
- seccomp_notify
- lxc_features
- container_nic_ipvlan
- network_vlan_sriov
- storage_cephfs
- container_nic_ipfilter
- resources_v2
- container_syscall_intercept
- container_disk_shift
- storage_shifted
- resources_infiniband
- daemon_storage
- instances
- image_types
- resources_disk_sata
- clustering_roles
- images_expiry
- resources_network_firmware
- ceph_data_pool_name
- compression_squashfs
- container_raw_mount
- container_nic_routed
- container_disk_ceph
- virtual-machines
- image_profiles
- clustering_architecture
- resources_disk_id
- storage_lvm_stripes
- vm_boot_priority
- unix_hotplug_devices
- api_filtering
- instance_nic_network
- clustering_sizing
- firewall_driver
- projects_limits
- limits_hugepages
- projects_restrictions
- volume_snapshot_scheduling
- trust_ca_certificates
- snapshot_disk_usage
- clustering_edit_roles
- resources_usb_pci
- resources_cpu_threads_numa
- resources_cpu_core_die
- api_os
- container_nic_ipvlan_mode
- resources_system
- images_push_relay
- network_dns_search
- container_nic_routed_limits
- instance_nic_bridged_vlan
- network_state_bond_bridge
- usedby_consistency
- custom_block_volumes
- clustering_failure_domains
- resources_gpu_mdev
- console_vga_type
- projects_limits_disk
- network_type_macvlan
- network_type_sriov
- network_type_ovn
- projects_networks
- custom_volume_backup
- backup_override_name
- storage_rsync_compression
- network_type_physical
- network_ovn_nat
- tpm_device_type
- gpu_mdev
- resources_pci_iommu
- resources_network_usb
- resources_disk_address
- network_ovn_dhcp
- projects_limits_instances
- network_state_vlan
- instance_bulk_state_change
- network_gvrp
- instance_pool_move
- gpu_sriov
- pci_device_type
- storage_volume_state
- network_acl
- migration_stateful
- disk_state_quota
- storage_ceph_features
- projects_compression
- certificate_project
- network_ovn_acl
- projects_images_auto_update
- images_default_architecture
- network_ovn_acl_defaults
- gpu_mig
- project_usage
- network_bridge_acl
- warnings
- clustering_join_token
- clustering_description
- server_trusted_proxy
- clustering_update_cert
- storage_api_project
- resources_gpu_usb
- clustering_evacuation
- network_ovn_nat_address
- network_bgp
- network_forward
- custom_volume_refresh
- network_counters_errors_dropped
- metrics
- image_source_project
- clustering_config
- network_peer
- linux_sysctl
- network_dns
- ovn_nic_acceleration
- certificate_self_renewal
- instance_project_move
- storage_volume_project_move
- cloud_init
- network_dns_nat
- database_leader
- instance_all_projects
- clustering_groups
- ceph_rbd_du
- instance_get_full
- qemu_metrics
- gpu_mig_uuid
- event_project
- clustering_evacuation_live
- instance_allow_inconsistent_copy
- network_state_ovn
- storage_volume_api_filtering
- image_restrictions
- storage_zfs_export
- network_dns_records
- storage_zfs_reserve_space
- network_acl_log
- storage_zfs_blocksize
- metrics_cpu_seconds
- instance_snapshot_never
- certificate_token
- instance_nic_routed_neighbor_probe
- event_hub
- agent_nic_config
- projects_restricted_intercept
- metrics_authentication
- images_target_project
- images_all_projects
- cluster_migration_inconsistent_copy
- cluster_ovn_chassis
- container_syscall_intercept_sched_setscheduler
- storage_lvm_thinpool_metadata_size
- storage_volume_state_total
- instance_file_head
- instances_nic_host_name
- image_copy_profile
- container_syscall_intercept_sysinfo
- clustering_evacuation_mode
- resources_pci_vpd
- qemu_raw_conf
- storage_cephfs_fscache
- network_load_balancer
- vsock_api
- instance_ready_state
- network_bgp_holdtime
- storage_volumes_all_projects
- metrics_memory_oom_total
- storage_buckets
- storage_buckets_create_credentials
- metrics_cpu_effective_total
- projects_networks_restricted_access
- storage_buckets_local
- loki
- acme
- internal_metrics
- cluster_join_token_expiry
- remote_token_expiry
- init_preseed
- storage_volumes_created_at
- cpu_hotplug
- projects_networks_zones
- network_txqueuelen
- cluster_member_state
- instances_placement_scriptlet
- storage_pool_source_wipe
- zfs_block_mode
- instance_generation_id
- disk_io_cache
- amd_sev
- storage_pool_loop_resize
- migration_vm_live
- ovn_nic_nesting
- oidc
- network_ovn_l3only
- ovn_nic_acceleration_vdpa
- cluster_healing
- instances_state_total
- auth_user
- security_csm
- instances_rebuild
- numa_cpu_placement
- custom_volume_iso
- network_allocations
- zfs_delegate
- storage_api_remote_volume_snapshot_copy
- operations_get_query_all_projects
- metadata_configuration
- syslog_socket
- event_lifecycle_name_and_project
- instances_nic_limits_priority
- disk_initial_volume_configuration
- operation_wait
- image_restriction_privileged
- cluster_internal_custom_volume_copy
- disk_io_bus
- storage_cephfs_create_missing
- instance_move_config
- ovn_ssl_config
- certificate_description
- disk_io_bus_virtio_blk
- loki_config_instance
- instance_create_start
- clustering_evacuation_stop_options
- boot_host_shutdown_action
- agent_config_drive
- network_state_ovn_lr
- image_template_permissions
- storage_bucket_backup
- storage_lvm_cluster
- shared_custom_block_volumes
- auth_tls_jwt
- oidc_claim
- device_usb_serial
- numa_cpu_balanced
- image_restriction_nesting
- network_integrations
- instance_memory_swap_bytes
- network_bridge_external_create
- network_zones_all_projects
- storage_zfs_vdev
- container_migration_stateful
- profiles_all_projects
- instances_scriptlet_get_instances
- instances_scriptlet_get_cluster_members
- instances_scriptlet_get_project
- network_acl_stateless
- instance_state_started_at
- networks_all_projects
- network_acls_all_projects
- storage_buckets_all_projects
- resources_load
- instance_access
- project_access
- projects_force_delete
- resources_cpu_flags
- disk_io_bus_cache_filesystem
- instance_oci
- clustering_groups_config
- instances_lxcfs_per_instance
- clustering_groups_vm_cpu_definition
- disk_volume_subpath
- projects_limits_disk_pool
- network_ovn_isolated
- qemu_raw_qmp
- network_load_balancer_health_check
- oidc_scopes
- network_integrations_peer_name
- qemu_scriptlet
- instance_auto_restart
- storage_lvm_metadatasize
- ovn_nic_promiscuous
- ovn_nic_ip_address_none
- instances_state_os_info
- network_load_balancer_state
- instance_nic_macvlan_mode
- storage_lvm_cluster_create
- network_ovn_external_interfaces
- instances_scriptlet_get_instances_count
- cluster_rebalance
- custom_volume_refresh_exclude_older_snapshots
- storage_initial_owner
- storage_live_migration
- instance_console_screenshot
- image_import_alias
- authorization_scriptlet
- console_force
- network_ovn_state_addresses
- network_bridge_acl_devices
- instance_debug_memory
- init_preseed_storage_volumes
- init_preseed_profile_project
- instance_nic_routed_host_address
- instance_smbios11
- api_filtering_extended
- acme_dns01
- security_iommu
- network_ipv4_dhcp_routes
- network_state_ovn_ls
- network_dns_nameservers
- acme_http01_port
- network_ovn_ipv4_dhcp_expiry
- instance_state_cpu_time
- network_io_bus
- disk_io_bus_usb
- storage_driver_linstor
- instance_oci_entrypoint
- network_address_set
- server_logging
- network_forward_snat
- memory_hotplug
- instance_nic_routed_host_tables
- instance_publish_split
- init_preseed_certificates
- custom_volume_sftp
- network_ovn_external_nic_address
- network_physical_gateway_hwaddr
- backup_s3_upload
- snapshot_manual_expiry
- resources_cpu_address_sizes
- disk_attached
- limits_memory_hotplug
- disk_wwn
- server_logging_webhook
- storage_driver_truenas
- container_disk_tmpfs
- instance_limits_oom
- backup_override_config
- network_ovn_tunnels
- init_preseed_cluster_groups
api_status: stable
api_version: "1.0"
auth: trusted
public: false
auth_methods:
- tls
auth_user_name: outpost
auth_user_method: unix
environment:
addresses:
- 172.16.170.147:8443
architectures:
- x86_64
- i686
certificate: |
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
certificate_fingerprint: ......................................
driver: lxc | qemu
driver_version: 6.0.5 | 10.1.1
firewall: nftables
kernel: Linux
kernel_architecture: x86_64
kernel_features:
idmapped_mounts: "true"
netnsid_getifaddrs: "true"
seccomp_listener: "true"
uevent_injection: "true"
unpriv_binfmt: "true"
unpriv_fscaps: "true"
kernel_version: 6.8.0-85-generic
lxc_features:
cgroup2: "true"
core_scheduling: "true"
devpts_fd: "true"
idmapped_mounts_v2: "true"
mount_injection_file: "true"
network_ipvlan: "true"
network_l2proxy: "true"
network_veth_router: "true"
pidfd: "true"
seccomp_notify: "true"
os_name: Ubuntu
os_version: "24.04"
project: default
server: incus
server_clustered: true
server_event_mode: full-mesh
server_name: outpost-001
server_pid: 24791
server_version: "6.17"
storage: dir
storage_version: "1"
storage_supported_drivers:
- name: truenas
version: 0.7.3
remote: true
- name: btrfs
version: 6.6.3
remote: false
- name: dir
version: "1"
remote: false
- name: lvm
version: 2.03.16(2) (2022-05-18) / 1.02.185 (2022-05-18) / 4.48.0
remote: false
