One of my instance’s disk is full. So I need to resize it. It seems 5GB and I want grow it to 10GB.
lxc exec frappe12-dev -- df -h
default/containers/frappe12-dev 4.9G 4.0G 954M 81% /
lxc stop frappe12-dev
lxc config device override frappe12-dev root size=10GB
lxc config device set frappe12-dev root size 10GB
It doesn’t changed but
lxc config show frappe12-dev
Shows
boot.autostart: "0"
image.architecture: amd64
image.description: ubuntu 20.04 LTS amd64 (release) (20210119.1)
image.label: release
image.os: ubuntu
image.release: focal
image.serial: "20210119.1"
image.type: squashfs
image.version: "20.04"
limits.cpu.allowance: 20%
limits.memory: 4096MB
limits.memory.enforce: soft
volatile.base_image: 690801402e1d4e02c07ba2d1a29bb9a9b4825f037c12ccad8cb4d062d2450d2c
volatile.eth0.hwaddr: 00:16:3e:e3:ff:16
volatile.idmap.base: "0"
volatile.uuid: 7fb76eea-e5ec-48e6-90d1-9008d9d1cc99
myport80:
connect: tcp:127.0.0.1:80
listen: tcp:0.0.0.0:80
type: proxy
pool: default
root size as 10GB.
This answer states that
And also, there is a limitation of LVM, if there are snapshots from this volume, you can not resize it, until they are removed.
Does still the case?
