Okay, so, I created a pair of custom volumes to be attached to a container:
lxc storage volume create ceph_pool DBTestSource size=1000GB
lxc storage volume create ceph_pool DBTestStorage size=1000GB
I then attached them to the container. All is well. However, later I found that the volumes were too small so I tried to grow them thusly:
lxc storage volume set ceph_pool DBTestSource size=1500GB
lxc storage volume set ceph_pool DBTestStorage size=1500GB
Thing is, no matter what I’ve tried the size of the file systems do not change. The various info commands swear they’ve been changed to 1.5TB. However, when I go in the container, no change. Resize2fs does nothing as the container doesn’t see the /dev/rbd* entries to be changed. Trying the same from the host results in a bad file system error. So, I’m stuck. Surely there has to be a way to do this, or should I just be doing it from the ceph side in the first place with rbd commands?
tomp
(Thomas Parrott)
May 20, 2020, 7:51am
2
Have you tried restarting the container, in some circumstances the resize can’t happen safely until the container is stopped, and we record the chance to occur on next start up.
Can you show output of lxc config show <container> --expanded before rebooting as that will show if the resize has been scheduled for next boot.
Unfortunately, I already did restart the container. No effect
That said, here’s the requested output anyway:
volatile.base_image: 94300c0d9cc90aeaafa460cf9a21bb5a0d6b7555a4d58d081890e0ecc8c53af9
volatile.eth0.host_name: veth96b87b25
volatile.eth0.hwaddr: 00:16:3e:d7:07:bc
volatile.idmap.base: “0”
volatile.idmap.current: ‘[{“Isuid”:true,“Isgid”:false,“Hostid”:1000000,“Nsid”:0,“Maprange”:1000000000},{“Isuid”:false,“Isgid”:true,“Hostid”:1000000,“Nsid”:0,“Maprange”:1000000000}]’
volatile.idmap.next: ‘[{“Isuid”:true,“Isgid”:false,“Hostid”:1000000,“Nsid”:0,“Maprange”:1000000000},{“Isuid”:false,“Isgid”:true,“Hostid”:1000000,“Nsid”:0,“Maprange”:1000000000}]’
volatile.last_state.idmap: ‘[{“Isuid”:true,“Isgid”:false,“Hostid”:1000000,“Nsid”:0,“Maprange”:1000000000},{“Isuid”:false,“Isgid”:true,“Hostid”:1000000,“Nsid”:0,“Maprange”:1000000000}]’
DBTestSTorage:
path: /dbstorage
pool: ceph_pool
source: DBTestSTorage
DBTestSource:
path: /dbsource
pool: ceph_pool
source: DBTestSource
nictype: bridged
parent: br0
pool: ceph_pool
description: “”
tomp
(Thomas Parrott)
May 20, 2020, 2:05pm
4
What did you mean by “The various info commands swear they’ve been changed to 1.5TB”, can you elaborate a bit on that please?
For instance, this:
block.filesystem: ext4
block.mount_options: discard
volatile.idmap.last: ‘[{“Isuid”:true,“Isgid”:false,“Hostid”:1000000,“Nsid”:0,“Maprange”:1000000000},{“Isuid”:false,“Isgid”:true,“Hostid”:1000000,“Nsid”:0,“Maprange”:1000000000}]’
description: “”
type: custom
- /1.0/containers/DBUpgradeTest
However, going into the container shows this:
root@DBUpgradeTest:~# df -h
/dev/rbd2 9.2G 1.9G 6.8G 22% /
none 492K 4.0K 488K 1% /dev
udev 7.8G 0 7.8G 0% /dev/tty
tmpfs 100K 0 100K 0% /dev/lxd
/dev/rbd0 916G 869G 688M 100% /dbsource
/dev/rbd1 916G 23M 870G 1% /dbstorage
tmpfs 100K 0 100K 0% /dev/.lxd-mounts
tmpfs 7.9G 12K 7.9G 1% /dev/shm
tmpfs 7.9G 188K 7.9G 1% /run
tmpfs 7.9G 0 7.9G 0% /sys/fs/cgroup
The ones in question being /dbsource and /dbstorage in the df output
tomp
(Thomas Parrott)
May 20, 2020, 4:31pm
7
So I just tried this on LXD 4.1 and it seems to be working OK, here’s my test:
lxc storage show default
ceph.cluster_name: ceph
ceph.osd.pg_num: "32"
ceph.osd.pool_name: persist-edfu
ceph.user.name: admin
volatile.pool.pristine: "true"
driver: ceph
lxc stop c1 # Existing container
lxc storage volume create default cust1
lxc storage volume attach default cust1 c1 cust1
lxc start c1
lxc exec c1 -- df -h | grep cust1
/dev/rbd1 9.2G 37M 8.6G 1% /cust1
lxc storage volume set default cust1 size=15GB
/dev/rbd1 14G 41M 13G 1% /cust1
lxc stop c1
lxc storage volume set default cust1 size=5GB
lxc start c1
/dev/rbd1 4.6G 33M 4.3G 1% /cust1
So that seems to be working OK.
What version of LXD are you running?
Also 4.1. Interesting. This is all with my work cluster. I’ll try it with my internal one and see if it behaves any differently
tomp
(Thomas Parrott)
May 20, 2020, 4:46pm
9
Are you using the snap, as I’m using the “stable” branch which may have some additional revisions beyond the 4.1 release tarball.
