Objective: Have a remote incus instance to be used as an image repository. Most clients just need read-only access to the base images, a few need to be able to create/remove images.
I created a project “published” with features.images set to false. I create a client trust entry (TLS cert) restricted just to that one project.
Then I create a test image in the default project and check it shows up (on the repository host in the “published” project (it does).
From the client I can see the image with incus image list myrepo: --project=published but if I try to launch or copy the image I get an error about permissions for the default project.
$ incus launch --project=published myrepo:alp1x86 local:
Launching the instance
Error: User does not have permission for project "default"
I think I can see what is happening - the image is actually in the default project and when it tries to copy the image to the client permission is denied.
But… if that is the case, I don’t see how “features.x=false” is supposed to work (and clearly it does or it wouldn’t be there). So what have I misunderstood?
