Overnight my laptop upgraded to the latest lxd 3.4.
$ snap change 968 | grep lxd
Done yesterday at 19:45 BST yesterday at 19:46 BST Ensure prerequisites for "lxd" are available
Done yesterday at 19:45 BST yesterday at 19:46 BST Download snap "lxd" (8415) from channel "stable"
Done yesterday at 19:45 BST yesterday at 19:46 BST Fetch and check assertions for snap "lxd" (8415)
Done yesterday at 19:45 BST yesterday at 19:46 BST Mount snap "lxd" (8415)
Done yesterday at 19:45 BST yesterday at 19:46 BST Run pre-refresh hook of "lxd" snap if present
Done yesterday at 19:45 BST yesterday at 19:47 BST Stop snap "lxd" services
Done yesterday at 19:45 BST yesterday at 19:47 BST Remove aliases for snap "lxd"
Done yesterday at 19:45 BST yesterday at 19:47 BST Make current revision for snap "lxd" unavailable
Done yesterday at 19:45 BST yesterday at 19:47 BST Copy snap "lxd" data
Done yesterday at 19:45 BST yesterday at 19:47 BST Setup snap "lxd" (8415) security profiles
Done yesterday at 19:45 BST yesterday at 19:47 BST Make snap "lxd" (8415) available to the system
Done yesterday at 19:45 BST yesterday at 19:47 BST Automatically connect eligible plugs and slots of snap "lxd"
Done yesterday at 19:45 BST yesterday at 19:47 BST Set automatic aliases for snap "lxd"
Done yesterday at 19:45 BST yesterday at 19:47 BST Setup snap "lxd" aliases
Done yesterday at 19:45 BST yesterday at 19:47 BST Run post-refresh hook of "lxd" snap if present
Done yesterday at 19:45 BST yesterday at 19:47 BST Start snap "lxd" (8415) services
Done yesterday at 19:45 BST yesterday at 19:47 BST Clean up "lxd" (8415) install
Done yesterday at 19:45 BST yesterday at 19:47 BST Run configure hook of "lxd" snap if present
Unfortunately this broke snapcraft
which uses lxd to build snaps.
I reverted back to 3.0 via snap refresh lxd --channel=3.0/stable
. This broke lxd, which now, no longer starts.
$ systemctl status snap.lxd.daemon.service
â—Ź snap.lxd.daemon.service - Service for snap application lxd.daemon
Loaded: loaded (/etc/systemd/system/snap.lxd.daemon.service; enabled; vendor preset: enabled)
Active: inactive (dead) (Result: exit-code) since Tue 2018-08-21 10:24:47 BST; 42s ago
Process: 31037 ExecStop=/usr/bin/snap run --command=stop lxd.daemon (code=exited, status=0/SUCCESS)
Process: 30936 ExecStart=/usr/bin/snap run lxd.daemon (code=exited, status=137)
Main PID: 30936 (code=exited, status=137)
Aug 21 10:24:47 KinkPad-K450 systemd[1]: snap.lxd.daemon.service: Unit entered failed state.
Aug 21 10:24:47 KinkPad-K450 systemd[1]: snap.lxd.daemon.service: Failed with result 'exit-code'.
Aug 21 10:24:47 KinkPad-K450 systemd[1]: snap.lxd.daemon.service: Service hold-off time over, scheduling restart.
Aug 21 10:24:47 KinkPad-K450 systemd[1]: Stopped Service for snap application lxd.daemon.
Aug 21 10:24:47 KinkPad-K450 systemd[1]: snap.lxd.daemon.service: Start request repeated too quickly.
Aug 21 10:24:47 KinkPad-K450 systemd[1]: Failed to start Service for snap application lxd.daemon.
Here’s the journal…
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[31813]: => Preparing the system
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[31813]: ==> Loading snap configuration
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[31813]: ==> Setting up mntns symlink (mnt:[4026532423])
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[31813]: ==> Setting up kmod wrapper
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[31813]: ==> Preparing /boot
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[31813]: ==> Preparing a clean copy of /run
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[31813]: ==> Preparing a clean copy of /etc
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[31813]: ==> Setting up ceph configuration
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[31813]: ==> Setting up LVM configuration
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[31813]: ==> Rotating logs
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[31813]: ==> Setting up ZFS (0.7)
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[31813]: ==> Escaping the systemd cgroups
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[31813]: ==> Escaping the systemd process resource limits
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[4570]: mount namespace: 7
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[4570]: hierarchies:
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[4570]: 0: fd: 8: perf_event
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[4570]: 1: fd: 9: freezer
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[4570]: 2: fd: 10: memory
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[4570]: 3: fd: 11: pids
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[4570]: 4: fd: 12: hugetlb
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[4570]: 5: fd: 13: rdma
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[4570]: 6: fd: 14: net_cls,net_prio
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[4570]: 7: fd: 15: cpu,cpuacct
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[4570]: 8: fd: 16: blkio
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[4570]: 9: fd: 17: devices
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[4570]: 10: fd: 18: cpuset
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[4570]: 11: fd: 19: name=systemd
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[4570]: lxcfs.c: 105: do_reload: lxcfs: reloaded
Aug 21 10:27:15 KinkPad-K450 lxd.daemon[31813]: => Re-using existing LXCFS
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: => Starting LXD
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: lvl=warn msg="CGroup memory swap accounting is disabled, swap limits will be ignored." t=2018-08-21T09:27:16+0000
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: panic: wal frames txn 13202 (1): out of memory
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: trace:
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: 2018-08-21 09:27:16.04016: fsm: restore=13196 start
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: 2018-08-21 09:27:16.04016: fsm: restore=13196 database size: 4096
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: 2018-08-21 09:27:16.04017: fsm: restore=13196 wal size: 304912
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: 2018-08-21 09:27:16.04033: fsm: restore=13196 filename: db.bin
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: 2018-08-21 09:27:16.04033: fsm: restore=13196 transaction ID:
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: 2018-08-21 09:27:16.04072: fsm: restore=13196 open follower: db.bin
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: 2018-08-21 09:27:16.04158: fsm: restore=13196 done
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: 2018-08-21 09:27:16.08639: fsm: term=1 index=13205 cmd=frames txn=13202 pages=0 commit=1 start
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: 2018-08-21 09:27:16.08655: fsm: term=1 index=13205 cmd=frames failed: wal frames txn 13202 (1): out of memory
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: goroutine 35 [running]:
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: github.com/CanonicalLtd/dqlite/internal/trace.(*Tracer).Panic(0xc42027a140, 0xfff699, 0x2, 0xc4203d3d20, 0x1, 0x1)
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: /build/lxd/parts/lxd/go/src/github.com/CanonicalLtd/dqlite/internal/trace/tracer.go:59 +0x12c
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: github.com/CanonicalLtd/dqlite/internal/replication.(*FSM).Apply(0xc4202a1c60, 0xc420524990, 0x0, 0x0)
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: /build/lxd/parts/lxd/go/src/github.com/CanonicalLtd/dqlite/internal/replication/fsm.go:84 +0x137
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: github.com/hashicorp/raft.(*Raft).runFSM.func1(0xc4201947b0)
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: /build/lxd/parts/lxd/go/src/github.com/hashicorp/raft/fsm.go:57 +0x15a
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: github.com/hashicorp/raft.(*Raft).runFSM(0xc420224580)
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: /build/lxd/parts/lxd/go/src/github.com/hashicorp/raft/fsm.go:120 +0x2fa
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: github.com/hashicorp/raft.(*Raft).(github.com/hashicorp/raft.runFSM)-fm()
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: /build/lxd/parts/lxd/go/src/github.com/hashicorp/raft/api.go:506 +0x2a
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: github.com/hashicorp/raft.(*raftState).goFunc.func1(0xc420224580, 0xc4201955e0)
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: /build/lxd/parts/lxd/go/src/github.com/hashicorp/raft/state.go:146 +0x53
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: created by github.com/hashicorp/raft.(*raftState).goFunc
Aug 21 10:27:16 KinkPad-K450 lxd.daemon[31813]: /build/lxd/parts/lxd/go/src/github.com/hashicorp/raft/state.go:144 +0x66
Aug 21 10:27:17 KinkPad-K450 lxd.daemon[31813]: => LXD failed to start
Aug 21 10:27:17 KinkPad-K450 systemd[1]: snap.lxd.daemon.service: Main process exited, code=exited, status=137/n/a
Aug 21 10:27:17 KinkPad-K450 lxd.daemon[31914]: => Stop reason is: crashed
Aug 21 10:27:17 KinkPad-K450 systemd[1]: snap.lxd.daemon.service: Unit entered failed state.
Aug 21 10:27:17 KinkPad-K450 systemd[1]: snap.lxd.daemon.service: Failed with result 'exit-code'.
Aug 21 10:27:17 KinkPad-K450 systemd[1]: snap.lxd.daemon.service: Service hold-off time over, scheduling restart.
Aug 21 10:27:17 KinkPad-K450 systemd[1]: Stopped Service for snap application lxd.daemon.
-- Subject: Unit snap.lxd.daemon.service has finished shutting down
-- Unit snap.lxd.daemon.service has finished shutting down.
Aug 21 10:27:17 KinkPad-K450 systemd[1]: snap.lxd.daemon.service: Start request repeated too quickly.
Aug 21 10:27:17 KinkPad-K450 systemd[1]: Failed to start Service for snap application lxd.daemon.
-- Subject: Unit snap.lxd.daemon.service has failed
-- Unit snap.lxd.daemon.service has failed.
