Earlier in 2020 this root container worked, but now after upgrade of kernel and lxc it doesn’t start
--logpriority=debug --logfile
lxc-start test2 20221208133322.704 WARN conf - ../lxc-5.0.1/src/lxc/conf.c:lxc_rootfs_overmounted:1459 - Invalid argument - Rootfs seems to have changed after setting up mounts
lxc-start test2 20221208133322.704 ERROR conf - ../lxc-5.0.1/src/lxc/conf.c:lxc_setup:4403 - Rootfs overmounted
lxc-start test2 20221208133322.704 ERROR start - ../lxc-5.0.1/src/lxc/start.c:do_start:1272 - Failed to setup container "test2"
# uname -r
5.15.80-gentoo-x86_64
lxc-checkconfig
LXC version 5.0.1 --- Namespaces --- Namespaces: enabled Utsname namespace: enabled Ipc namespace: enabled Pid namespace: enabled User namespace: enabled Network namespace: enabled— Control groups —
Cgroups: enabled
Cgroup namespace: enabledCgroup v1 mount points:
Cgroup v2 mount points:
/sys/fs/cgroupCgroup v1 systemd controller: missing
Cgroup v1 freezer controller: missing
Cgroup ns_cgroup: required
Cgroup device: enabled
Cgroup sched: enabled
Cgroup cpu account: enabled
Cgroup cpuset: enabled— Misc —
Macvlan: enabled, not loaded
Vlan: enabled, not loaded
Bridges: enabled, loaded
Advanced netfilter: enabled, not loaded
CONFIG_NETFILTER_XT_TARGET_CHECKSUM: enabled, not loaded
FUSE (for use with lxcfs): enabled, not loaded— Checkpoint/Restore —
checkpoint restore: enabled
CONFIG_FHANDLE: enabled
CONFIG_EVENTFD: enabled
CONFIG_EPOLL: enabled
CONFIG_UNIX_DIAG: enabled
CONFIG_INET_DIAG: enabled
CONFIG_PACKET_DIAG: enabled
CONFIG_NETLINK_DIAG: enabled
File capabilities:Note : Before booting a new kernel, you can check its configuration
/var/lib/lxc/test2/config
/var/lib/lxc/test2 # grep -vE "(^#.*$)|(^$)" config lxc.net.0.type = veth lxc.net.0.veth.pair=test2ext lxc.net.0.veth.mode=bridge lxc.net.0.link=br0 lxc.net.0.name=test2int lxc.net.0.hwaddr=12:34:56:78:xx:xx lxc.rootfs.path = dir:/var/lib/lxc/test2/rootfs lxc.mount.entry=/dev/sda4 . btrfs subvol=vm/test2 0 0 lxc.mount.entry=/dev/sda4 var/db/repos btrfs subvol=portage/repos 0 0 lxc.mount.entry=/dev/sda4 var/cache/distfiles btrfs subvol=portage/distfiles 0 0 lxc.mount.entry=/dev/sda4 var/cache/binpkgs btrfs subvol=portage/binpkgs 0 0 lxc.arch = amd64 lxc.uts.name = test2 lxc.tty.max = 1 lxc.include = /usr/share/lxc/config/gentoo.common.conf lxc.cgroup.devices.allow = lxc.cgroup.devices.deny =
btrfs subvolume list .
... ID 288 gen 790745 top level 5 path portage/distfiles ID 289 gen 790769 top level 5 path portage/binpkgs ID 334 gen 790769 top level 5 path portage/repos ID 336 gen 790773 top level 5 path vm/test2 ...
