I created a VPN(with n2n) between 2 servers and I configured lxd cluster;
as a result, I have now 2 different interfaces that I can use;
edge0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1400
inet 192.168.20.1 netmask 255.255.255.0 broadcast 192.168.20.255
inet6 fe80::d434:7fff:fef7:fd4c prefixlen 64 scopeid 0x20<link>
ether d6:34:7f:f7:fd:4c txqueuelen 1000 (Ethernet)
RX packets 176918 bytes 25393555 (25.3 MB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 239425 bytes 210900839 (210.9 MB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 9001
inet 10.0.1.26 netmask 255.255.255.0 broadcast 10.0.1.255
inet6 fe80::64:30ff:fe23:81b2 prefixlen 64 scopeid 0x20<link>
ether 02:64:30:23:81:b2 txqueuelen 1000 (Ethernet)
RX packets 318651 bytes 249442008 (249.4 MB)
TX packets 295534 bytes 247070172 (247.0 MB)
eth0 is the default one;
edge0 is the device created to use the VPN network;
How to specify with lxd to use edge0 to forward all the traffic between the node of the cluster?
Bests
Giuseppe
