Hi everyone.
I followed the instruction on https://github.com/lxc/lxd and built lxd on Ubuntu 16.04.
I removed default lxd(v 2.0) and tried
sudo -E $GOPATH/bin/lxd --group sudo).
WARN[04-06|13:46:49] CGroup memory swap accounting is disabled, swap limits will be ignored.
After it hangs.
Then I tried
sudo $GOPATH/bin/lxd init
Error: Failed to connect to local LXD: Get http://unix.socket/1.0: dial unix /var/lib/lxd/unix.socket: connect: no such file or directory
ls -l /var/lib/lxd/
total 160
drwx--x--x 2 root root 4096 Apr 6 12:37 containers
drwx--x--x 2 root root 4096 Apr 6 12:37 devices
drwxr-xr-x 2 root root 4096 Apr 6 12:37 devlxd
drwx------ 2 root root 4096 Apr 6 12:39 disks
drwx------ 2 root root 4096 Apr 6 12:37 images
-rw-r--r-- 1 root root 59392 Apr 6 12:39 lxd.db
-rw-r--r-- 1 root root 41984 Apr 6 12:39 lxd.db.bak
drwx--x--x 2 root root 4096 Apr 6 12:39 networks
drwx------ 3 root root 4096 Apr 6 12:39 raft
drwx------ 2 root root 4096 Apr 6 12:37 security
-rw-r--r-- 1 root root 1891 Apr 6 12:37 server.crt
-rw------- 1 root root 3243 Apr 6 12:37 server.key
drwx--x--x 2 root root 4096 Apr 6 12:37 shmounts
drwx------ 2 root root 4096 Apr 6 12:37 snapshots
drwx--x--x 2 root root 4096 Apr 6 12:39 storage-pools
Thanks.
