You describe how to migrate container between hosts on your website: https://stgraber.org/2016/04/12/lxd-2-0-remote-hosts-and-container-migration-612/
I was able to remove the bind (with setting it to empty) but I can’t see a way to remove the password. By the way the password is saved in the bash_history and maybe there should instead be a prompt from lxd to enter the password.
The lxd server is only bound to the core.https_address or are some other ports needed? I had some problems with the pull method and switched to the push method which worked.
Thanks for the great software.
